Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
View Poll Results: I have TRIED IT and have found that ...
It works wonders for my car/bike. I highly recommend it. 15 36.59%
Slight improvement, but I recommend it. 7 17.07%
No difference at all. Don't bother trying this non-sense stuff. 11 26.83%
It screwed my car!!! Stay away from all boron compounds!!! 8 19.51%
Voters: 41. You may not vote on this poll
Thread Tools
Old 5th August 2006, 15:33   #46 (permalink)
Hi all,
After adding boric acid powder in engine oil & completed running almost 2000km I decided to change the oil.....as soon as boric acid comes in contact with inside metal parts under high temparature it starts working forming boric oxide which sticks to the metal surface( this process itself is called matal treatment)....by this it starts removing age old carbon deposites....this works to every corner..crevices...minute openings from where its almost impossible to remove carbon deposits....so carbon debris keep on accumulating in oil....when I drained oil it was much more black...I assume it almost cleared most of carbon deposites & new seal is developed with boron particles which will never pile off until engine openeing.....
I m using castrol magnatec oil...now my earlier FE is back....almost getting 600+km on 45 kg of lpg....initially my mileage went down...but I kept running....
Enjoy....
finetuning is offline   Reply With Quote
Old 31st August 2006, 21:27   #47 (permalink)
gd1418's Avatar
Default Boric Acid
By your own calculation how much Boric acid powder needs to be added in 7 ltrs of engine oil?? And does one need to mix it well or just simply add and pour in the engine?
Originally Posted by finetuning
Hi all,
I decided to try it on my own.....prepared a mixture of 5% powder with engine oil.....I made concentrated mixture of 175gramms powder with one liter of engine oil to be added in 3.0 liter of engine oil.....stirred it for half an hour by hand mixture....then added directly to engine oil.....Enjoy.....
Old 31st August 2006, 21:55   #48 (permalink)
gd1418's Avatar
Default Motor Silk
Anybody here knows if the above product is available in India? if yes, then where and what cost? Is there any outlet in and around Delhi?
Old 2nd September 2006, 00:34   #49 (permalink)
I added in tha ratio of 5% of weight of engine oil...means for every 1000ml roughly 1 Kg of engine oil I added 50gms of powder.Since my engine oil capacity is 3.5 liter......I prepared concentrated mixture of 1 liter oil with 175gm powder to be added in 3.5 liter oil........I added powder after breaking lumps into 1 liter oil....mixture was stirred by hand mixture for about half an hour......it was then filtered with double layered cotton cloth many times to take out undissolved particles......then added into engine....
IMO it took almost 3000 km to give complete benefit......my car is so smooth right now......this difference quite noticeable at highway driving....I changed oil & oil filter after 2000 km....I had to retune my carbureted car instantly after adding this....changing of oil & filter is a must after 2000 km...as its during this time most of particles works inside engine removing lotsf carbon debris.......
My engine oil feels clean now....waiting to see whether this can extend the oil change interval as mentioned......
If u want more information kindly PM me....
U can ask company for shipment at ur address.......I think they dont have any dealer here.....
Enjoy......
Old 2nd September 2006, 22:24   #50 (permalink)
gd1418's Avatar
Default making the concoction
Phew..!!! quite an effort; but as they say - "no gain without pain"..My Safari holds 7 ltrs of engine oil and that means 350 gms of Boric acid.....hmmm
[quote=finetuning]I added in tha ratio of 5% of weight of engine oil...means for every 1000ml roughly 1 Kg of engine oil I added 50gms of powder.Since
Old 24th January 2007, 21:33   #51 (permalink)
Encouraged by the benefits I m getting of boric acid in engine oil few of friends decided to use in their bikes & scooters....
Earlier I added powder after mixing it in engine oil but then I found good way to dissolve this stuff.......I dissolved in pure acetone......it doesnt dissolves fully but I think it reduces the particle size of powder.....added 8 gm powder dissolving in 30 ml acetone solution in 500 ml watr bottle......kept it for a night.....then added 100 ml engine oil of bike & poured in Suzuki Fiero F2 bike.........
Its almost 10 days now and result is so encouraging....there is remarkable smoothness of engine.....also its running slightly cooler now....bike now takes higher gear at low rpm & also there is noticeable increase in power......It normally takes at least few hundred km for best benefits....
Also done in same manner in our scooty pep & same wonderful result.....its running very smooth now...I m amazed with the way boric powder performs for friction reduction....I havent enountered any ill effect as of now...
Also adding few ml acetone in engine oil might react with engine oil....I ruled out this possibility as boiling point of acetone is just 57 deg centrigrade and within few minutes of engine running it will be sucked by pcv valve into combustion chamber.....
Enjoy....
Old 1st February 2007, 10:45   #52 (permalink)
Thumbs up I said... "Lets do it"
I read this thread almost 3 times... and after listening to (reading) a lot of criticism, doubts, and euphoria... and after a long hard thought, I decided to give this stuff a try.
I usually don't care much about the way a car should be treated... and believe that new technology is meant to make life easier. Just switch on, press the pedal and zoom away... So, rather than taking pains to dissolve the boric powder in acetone/oil etc, I just put about a tablespoon of the powder in my engine oil tank. I think it shud mix own as the oil is churned inside. Also... since the amount is only a t.spoon, think, it shudn't dry and block up the area where the local conc. is high.
About 10kms later, I felt noticeable smoothness kicking in. Felt as if the tyre pressure is really low and the car is rolling on a cushion. But wonder, what's the suspension's got to do with engine oil???
On the flip side, felt a little over-oiled-ness in the engine, and pick up was slightly affected... again the same effect that one wud get when the tyre pressure is low.
I checked the tyre pressure. It was normal.
Anyways... Has any1 else, other than the 'inventor', has tried this stuff? Cud they plz, share their experiences?
Also.. can any1 tell me, why the sluggishness, and
why the hell my car's suspension is better suddenly?
It's tempting to add another t.spoon of powder... Should I do it? Or, mix it with little engine oil first, and then add?
amu1983 is offline   Reply With Quote
Old 2nd February 2007, 01:02   #53 (permalink)
Your initial sluggishness is because of working of powder........but you need to at least dissolve in acetone.....there is no need to add powder direct into sump......
1 table spoon is very less quantity so you need not worry about any ill effect.......infact after 300 km you need to change your oil filter without fail to get best benefit........
Apart from smoothness of running which is because of micro layered boric oxide plates....you will feel very free engine.....but this technique takes time to pass on full benefit..so keep running till 1500 & more km & dont change oil in between.......you can safely change oil after 1500 km........
I used this METAL TREATMENT in at least 40 vehicles without any ill effect & result is just superb.....we need to dissolve in acetone for better result....
If your car hold 3 ltr oil then can add 100 gm dissolving in 100 ml acetone first.......if by any means powder is dissolved then its good idea......
Feeling of smoothness is right............but initially since boric acid tends to seek metal surfaces & starts removing carbons we feel litle loss of power but thats I think not even noticeable...afterwards car engine becomes very smooth.there is gentle hum sound on highways & feeling of gliding......car tends to run with higher gear....do check this.......
Old 3rd February 2007, 19:15   #54 (permalink)
Kaizer Sozay's Avatar
Originally Posted by finetuning View Post
Please Throw some light Why i need to change the oil filter after 300 Kms?
Also if i change the oil filter I will have to do a top up also?
__________________
"The greatest trick the devil ever pulled was convincing the world he didn't exist ."
Kaizer Sozay is offline   Reply With Quote
Old 4th February 2007, 12:30   #55 (permalink)
Boron tends to stick to metal surfaces, so the powder will replace the carbon deposits on the inside walls of the engine. These carbon particles will then get filtered in the oil filter. [Source: earlier posts in this thread]
I don't think so, unless the mechanic does a poor job and there's significant loss of oil in the process.
Old 8th February 2007, 09:05   #56 (permalink)
Any Update on the changes after you added the boric acid?
FE Or Power Difference?
__________________
Old 8th February 2007, 10:27   #57 (permalink)
hi finetunig,
i tried the above on my CBZ. the result was amazing. The bike was already havin' a engine on great condition. But after using this mixture the performance is shattering. There is considerable increase in power, speed and MAKHAN like smoothness. great therapy mann. i owe u a treat someday.
cheers.
__________________
HORN...OK...PLEASE.....
vichu_zen is offline   Reply With Quote
Old 8th February 2007, 17:48   #58 (permalink)
kaizer,
After adding boric powder into engine it starts removing carbons & its therefor advisable to replace oil filter after say 300 km onwards.....its not neccessary but advisable........full effect will be seen after we change oil with new fresh one with again new filter......by the time we complete say 1000 km this treatment is applied & starts giving best possible benefits....
I see this as a breakthrough in friction reduction.....recently to my Gujarat trip I used this treatment in at least 15 bike....pulsars...hero hondas...honda activas.....& scooty peps to name a few.....result is astonishing......
After adding this into bike instantly we feel rise in idle rpm & within few km running can feel smoothness & calmness of engine......also kick pedal becomes very smooth......this was more evident in pulsars.....I also observed that with new bikes this effect is more & with old bikes this takes time to clean carbon deposites but effective......in one of the Honda activa I observed such a great power & smoothness......its as if there is no engine sound at all......also observed less engine temp......
Hi vichu_zen,
Make sure not to change engine oil for at least 800 to 1000 km.....this is a must.....also do not change any carburetor setting.....you must be feeling extremly smooth bike I can imagine.....do check FE & engine temp. too.....
In bikes I think 10 gm powder is sufficient......I always prefer 10 gm powder in bikes......there is some consideration using such amount......
Enjoy...
Old 8th February 2007, 17:51   #59 (permalink)
No, I didn't add any more powder after 2nd Feb. Actually, I think my clutch plate is wearing away (not coz of boric treatment), and therefore the car is getting a kinda sluggish now-a-days. No point experimenting on a sick car :-(
But, I'm gonna try the boric treatment on my dad's bike soon. Will post those results.
Old 16th February 2007, 21:16   #60 (permalink)
gd1418's Avatar
Did you manage to lay your hands on your dad's bike and make that guinae pig? If yes, then the results of the chemical reaction?
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Thread Tools
What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? D.V.R Technical Stuff 22 10th November 2009 22:31
My Experience Of Adding 2T Oil In Fuel finetuning Technical Stuff 107 29th May 2009 23:06
Adding Engine oil with Diesel. chanapli Technical Stuff 39 18th August 2008 21:35
My Experience Of Adding Boric Acid In Petrol finetuning Technical Stuff 50 24th June 2008 22:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
