| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| View Poll Results: I have TRIED IT and have found that ... | |||
| It works wonders for my car/bike. I highly recommend it. | | 15 | 36.59% |
| Slight improvement, but I recommend it. | | 7 | 17.07% |
| No difference at all. Don't bother trying this non-sense stuff. | | 11 | 26.83% |
| It screwed my car!!! Stay away from all boron compounds!!! | | 8 | 19.51% |
| Voters: 41. You may not vote on this poll | |||
| | Thread Tools |
| | #77 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| No arguments here about any claims as these were reported by actual users.....it seems so difficult to digest but its true......entire concept of friction reduction is so beneficial to engines.....there is neither placebo effect nor psychological feeling......this works best with new engines....if we are able to stop mechnical wear and tear in the initial stage then its beneficial for the life of an engine...... Enjoy... |
| | #78 (permalink) | |
| BHPian | Quote:
I also got the oil filter changed. Some points to be noted. When i start the car in the morning the RPM rises to around 1500. it stays that way till around 1kms then it settles down to the normal rpm of 700-800. The smoothness in the engine is very noticeable. ![]()
__________________ "The greatest trick the devil ever pulled was convincing the world he didn't exist ." | |
| | #79 (permalink) | |
| Senior - BHPian | If it is a MPFI engine then this is quite normal. Coz on a cold start the RPM increases with a rich mixture being let in and also the oil is circulated to every place quite fast. Once the little warm-up temp is achieved the mixture leans out and the engine smoothens and settles out.. I hope, my theory is right or am I shooting my mouth off..?? Quote:
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx | |
| | #80 (permalink) |
| BHPian Join Date: Feb 2007 Location: Pune
| sameer_dg >> Are you joking here!! No, we are not. This is real stuff. gd1418 >> I hope, my theory is right or am I shooting my mouth off..?? Am not sure whether MPFI engines rev up automatically on cold-start. Didn't observe this on my MPFI Zen. But, one thing is for sure about MPFI... they are crazy. The engine rpms rise and drop on their own. Almost as if they have their own brain. When I start in the morning, the rpms will be low at first, but as soon as I rev up a little, they rise and stay high for a few seconds, then drop again. After a long drive, as I idle at a signal, the rpms will drop again automatically, stay low for a few seconds and rise again. PS - I'm sure, I'm not confusing the fan noise with the engine rpms. |
| | #82 (permalink) |
| BHPian | Last night i went out with a couple of friends for a drive, we were four guys in the car. some very notable points was that the car picked up very easily from 60 to 100. there was no timing noise that i used to experience when i reved above 80. At 110 The engine was very silent. The smoothness is unbelieveable. It must say that the boron treatment takes a bit of time but the more i drive the effect starts improving. I will be doing a long drive in the next 15 days from Nagpur to Bombay will test for FE and other things during this run
| | #83 (permalink) |
| Hi Kaizer, Enjoy BEST friction reduction method available for automobiles.....more you log on km more you will notice benefits......now after 2000 km you can change your engine oil......do look out for extra carbon debris in drained oil...there after you can add fresh oil with new filter...... Enjoy your ride..... |
| | #84 (permalink) |
| Hi kaizer, One question to you, Did you notice rise in RPM up to 1500 at morning start up before adding boron?...If its no then really this treatment is working so well.....normal mpfi car starts at high rpm say up to 1500 then settle down to 600 or so....if you havent observed this till now then I m sure your car is really really getting better & better just as new car....isnt this the BEST decarbonising agent?? When very old carbon layers starts getting removed then cars tends to behave just like a new one.....if comression is restord to original one by this method then there is definitely increase in performance as well as FE....thanks for your input.... Enjoy... |
| | #85 (permalink) | |
| BHPian | Quote:
| | #86 (permalink) |
| Why don't we add a poll to this topic.. with options like 1. Yes, it has helped me a lot. 2. Slight improvement. 3. No noticeable improvement at all. 4. Negative results. Stay away from this stuff! This would give an instant statistics to new readers, who now have to go though the entire thread to see how people have responded. |
| | #87 (permalink) | |
| BHPian | Quote:
Mods pls help
| | #88 (permalink) |
| I m very sure that boron treatment works well beyond any doubt.....more I went deep into thhis subject more I ralised its tremendous potential in current senario.....there are exhaustive study materials available for this.....with the introduction of zero sulpher fuel this will have major role to play....my aim & intentions were to find out beneficial elements from our surroundings..... Even if a single personn is benefited I m happy.....few years onwards autoworld will be riding boron waves.....it makes much sense to sudy a little then implement such thing hence I wish that those who are keen to try this must go through links......there is no substitute for knowledge....this techniques is so different hence rejected by most......but those who tried are enjoying the benefits that cant be gained by any other means........ignorance is bliss many times but not always.......infact many times its opposite...... Enjoy..... |
| | #89 (permalink) |
| The treatment is scientific, I agree. But, most people have only one car and if it breaks down, for whatever reason, their work/business gets affected. So, they will always hesitate before trying anything like this. I read this thread 3-5 times, and carefully searched for any ill-effects, and then tried it on my car on a weekend. So, a poll will be very beneficial to the first-time-readers of this thread. And.. am sure most people will choose the first (very good, or helpful) option. |
| | #90 (permalink) | |
| BHPian | Quote:
« Nissan Quest - Intermittent air-con blower speed
Different Service Schedules for Different Cars »
| Thread Tools | |
Similar Threads | ||||
| What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? | D.V.R | Technical Stuff | 22 | 10th November 2009 22:31 |
| My Experience Of Adding 2T Oil In Fuel | finetuning | Technical Stuff | 107 | 29th May 2009 23:06 |
| Adding Engine oil with Diesel. | chanapli | Technical Stuff | 39 | 18th August 2008 21:35 |
| My Experience Of Adding Boric Acid In Petrol | finetuning | Technical Stuff | 50 | 24th June 2008 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
, I'd say your theory is right!
