Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
View Poll Results: I have TRIED IT and have found that ...
It works wonders for my car/bike. I highly recommend it. 15 36.59%
Slight improvement, but I recommend it. 7 17.07%
No difference at all. Don't bother trying this non-sense stuff. 11 26.83%
It screwed my car!!! Stay away from all boron compounds!!! 8 19.51%
Voters: 41. You may not vote on this poll
Thread Tools
Old 7th March 2007, 22:11   #91 (permalink)
Have already posted on Page 5.
Now, after over 1000 kms, it's still good. There's noticeable difference when I drive my friends' cars and similarly, when they drive mine. But, when I tell them about my 'secret', they are too scared to try it. That's why I suggested the poll.
amu1983 is offline   Reply With Quote
Old 7th March 2007, 23:51   #92 (permalink)
Hi amu1983,
Do change oil filter now......its a must I think....as most of dirt,varnish & carbons will be collected in oil & in filter....you will get yet improved performance after changing filter.....also after 1000 km more you need to drain oil & add fresh one with again new oil filter.....this powder has great tendency to stick to metals under heat & pressure making very fine & slippery layers.....
Keep sharing.......
Enjoy.....
finetuning is offline   Reply With Quote
Old 9th March 2007, 21:29   #93 (permalink)
Question
hi guys,
I own Safari 2001 model.
I have gone through the acetone thread and added acetone in the fuel.Saw immediate improvement in the power and the reduction in the engine noise.
Thanks Fine tuning for such wonderful research you are carrying on
I am taking my car for complete engine oil and gear oil change in couple of days.
After going through the thread 4-5 times, I am thinking of putting the boric powder in the gear oil as well as the engine oil.
I had a one question for engine oil you can remove the carbon deposits by just changing the oil and the filter after 1000 kms , what about the carbon deposits in the gear oil,how would you remove that
Hi GD, Suman, have you tried the boric powder treatment in your Safari or should I go Delvac oil for turbo diesel engines before putting boric powder in my engine oil
Also should I go for change in the oil seal of the engine, there is a slight leak there before going for oil change.
regards
sammy
sammykhan is offline   Reply With Quote
Old 10th March 2007, 11:29   #94 (permalink)
gd1418's Avatar
It is good to know Sammy that you have benefited with the acetone treatment. Boric powder under high pressure and temperature reacts to remove carbon deposits. No such phenomen occurs in the gearbox though and the carbon deposits in gear box is quite miniscule. However, when you add boric powder to the gear oil then after 2000 kms change the oil again. During this time the boric powder would have clung and acted to remove carbon.
Nw regarding your second query, first plug all the leaks coz later situation may aggravate. You can add boric powder to Delvac oil for turbo diesel engines. I've done the boric powder treatment to my Safari but since it is driven by my wife and I haven't touched it for long, would not be able to comment.
But I've also done the boric treatment in my Scorpio and I find it very smooth.
Originally Posted by sammykhan View Post
hi guys,
I am taking my car for complete engine oil and gear oil change in couple of days. After going through the thread 4-5 times, I am thinking of putting the boric powder in the gear oil as well as the engine oil.
regards
sammy
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 10th March 2007, 15:37   #95 (permalink)
manson's Avatar
Originally Posted by Sutra View Post
Was busy in office, almost forgot the boric acid thing for almost 2 weeks, took the car out over the weekend, didn’t realized any difference till I stopped for the red light, Was surprised to note the engine much smoother and quite, tried overtaking few cars and engine felt much more responsive.
Its funny that you didnt realise the difference all thriugh the two weeks of driving, and the change in performance caught your eye, mind, senses, etc when you stopped at a red light. From where i see it, the boric acid probably helped you brake better.
Sutra, its as simple as this, if there was any seriosu difference in the working, it would have come to your notice no matter how low on memory you were.
I doubt i'll return to this thread, so don't bother quoting me.
manson.
__________________
Robin
manson is offline   Reply With Quote
Old 10th March 2007, 16:51   #96 (permalink)
Arrow Does boric powder in engine oil really work?
I see that the boric powder stuff is quickly gaining popularity. But, understandably almost everyone is skeptical of trying it. So, I've created this poll, with a hope that it will give a statistical input to a first-time reader, and he/she can decide accordingly.
Old 10th March 2007, 19:04   #97 (permalink)
Kaizer Sozay's Avatar
Thanks for the long awaited poll, would think its better if it is merged with the thread on Boric acid so everyone can read about it.
__________________
"The greatest trick the devil ever pulled was convincing the world he didn't exist ."
Kaizer Sozay is offline   Reply With Quote
Old 10th March 2007, 22:06   #98 (permalink)
Rehaan's Avatar
Done.
Thanks for the suggestion, and thanks for the idea of the poll amu.
Please vote again as i had to start a new poll.
cya
R
Old 10th March 2007, 23:42   #99 (permalink)
Rehaan, could you plz do the same for the threads -
1. My Experience With Adding Acetone in Petrol
2. My Experience Of Adding Boric Acid In Petrol
Old 11th March 2007, 14:58   #100 (permalink)
Originally Posted by amu1983 View Post
Yes Rehaan request you to please do the same.
__________________
Old 11th March 2007, 15:13   #101 (permalink)
rks
rks's Avatar
In all such polls, I suggest we include another option -- "Not willing to try risky experiments with additives to ----" (where ---- stands for engine oil, fuel, etc.). I will vote for this option if available.
Old 11th March 2007, 18:48   #102 (permalink)
Ha Ha... If we add that option... I'm sure it would consume 99% of the votes! That's why the poll states -
I have TRIED it and have found that ...
The idea is to give a fair statistical input to guys like you who are hesitant. After all... everyone's scared of jumping into the water before they learn to swim. And.. there's no point asking the non-swimmers about the joys/perils of swimming, is there?
Old 19th March 2007, 16:00   #103 (permalink)
Default how can i add boric acid
as i have tried acetone i am very eager to try boric acid. I am very much confused on its use. So explain me how to add boric acid on my amby(5.5 ltr oil). will it have some adverse effect on engine( b coz it being a diesel engine)
swathyd is offline   Reply With Quote
Old 19th March 2007, 20:57   #104 (permalink)
Manson, I am using my bike as daily mode of transportation, car is only used for weekend outings with family. Took the car out only after two weeks of the experiment. Had forgotten about the experiment when I took the car out. Hope that explains...
Sutra is offline   Reply With Quote
Old 21st March 2007, 13:48   #105 (permalink)
gd1418's Avatar
Evidence recorded & accepted. Acquitted...
__________________
Thread Tools
What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? D.V.R Technical Stuff 22 10th November 2009 22:31
My Experience Of Adding 2T Oil In Fuel finetuning Technical Stuff 107 29th May 2009 23:06
Adding Engine oil with Diesel. chanapli Technical Stuff 39 18th August 2008 21:35
My Experience Of Adding Boric Acid In Petrol finetuning Technical Stuff 50 24th June 2008 22:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
