| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| View Poll Results: I have TRIED IT and have found that ... | |||
| It works wonders for my car/bike. I highly recommend it. | | 15 | 36.59% |
| Slight improvement, but I recommend it. | | 7 | 17.07% |
| No difference at all. Don't bother trying this non-sense stuff. | | 11 | 26.83% |
| It screwed my car!!! Stay away from all boron compounds!!! | | 8 | 19.51% |
| Voters: 41. You may not vote on this poll | |||
| | Thread Tools |
| | #121 (permalink) | |
| BHPian | Quote:
__________________ "The greatest trick the devil ever pulled was convincing the world he didn't exist ." | |
| | #123 (permalink) | |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Quote:
Hi elf, Thanks for sharing your reading difficulties but I think what you mentioned is very different from my style of writing.....I used to go this way only after a sentence is over like we do when we talk normally.....pausing in between.....I think when we read very long para we used to miss many words & lines if reading fast.....this way I think we can avoid it.....what can I say more?...anyway I will try to change this habit.... Enjoy... | |
| | #124 (permalink) | |
| Quote:
Graphite is good old solid lubricant which was used in automobiles until Boron discovery.....graphite is very slippery but it doesnt chemically bond to metal surface like boron and is very toxic.....the byproduct of graphite itself is corrosive to metal surface and also degrades the lubricating property of existing liquid oil......when it comes to stringent environmental norms products like graphites and molybdenum and chlorines doesnt comes into picture even though they are good lubricant....for example sulpher is good lubricant and was used in fuels till now but the current trend is using low sulpher fuel or zero sulpher fuel because of its emission charecteristics...its where this wonderful & promising powder comes into life...it doesnt degrade itself over time & improves the lubricating aspect of base lubricant..... Enjoy.... | |
| | #125 (permalink) |
| BHPian | I had treated my engine with boric acid less than a month ago. Earler every time i used to change my oil at around 4000 kms but this time i changed it at 2000. The oil was black on account of the carbon deposits I added fresh oil and a fresh dose of boric acid , when i drove the car after that there was a a marked difference the engine was much more smoother & silent. I even added boric to the gear box. I have only driven 10-12 kms after this but the gear shifting is a bit smoother.
| | #126 (permalink) |
| BHPian Join Date: Jun 2005 Location: ERNAKULAM
| Browse through these pages especially the one about material safety data sheet where they give the amount or rather concentration in the synthetic base oil. LuBoron - Advanced Lubrication Technology Bye and wear your seat belts. |
| | #127 (permalink) |
| These guys have gone and even applied for a patent to exhibit their Boron free lubricants. If Boron was such a good thing why have they applied for a patent for their gear oil which is supposedly boron free. Though the article does mention that Boron was a requirement earlier for passing the tests they feel the detrimental properties of Boron required them to remove it completely from their new batch of lubricants. I have bought a 500gram jar of Boric acid but do not have the courage to use it on my Junkindica because of the negative write ups about it on the net.India BigPatents -- "BORON FREE AUTOMOTIVE GEAR OIL†Boron free automotive gear oil patent invention Bye and wear your seat belts. Last edited by drpullockaran : 1st April 2007 at 20:29. |
| | #128 (permalink) |
| I think there is nothing negative about using boron......its the invention for lubrication without boron.....as boron contained lubricants have extremely less coefficient of friction that they easily beat industry standards.....invention goes on & on.....also if we study the scope of patents we can find them of "circuler nature" like the meaning of any word in english dictionary......they have circuler meaning.....same way patents do arise from some original ideas with & without inclusion of certain things....that makes them altogether different one...... Enjoy.... |
| | #129 (permalink) | |
| BHPian | Quote:
The gear shifting is really smooth.
| | #130 (permalink) |
| BHPian | The gear shifting is smooth on all gears except when i have to move to 1st its very stiff but when i move to 3rd 4th or 5th even the reverse gear is extremely smooth, any reason why the 1st feels so different? GD wonder if you faced the same problem?
| | #131 (permalink) |
| Senior - BHPian | Actually, now that you have mentioned this, I started noticing and I find a little stiffness in shifting to 1st from a stationery position. Now, I had not noticed or paid attention before 'boricing' the gear box, so can't say for sure if the stiffness was the same or increased etc. In any case, engaging 1st gear is little sticky most of the times. But yes, shifting to other gears is like slicing the butter with a hot knife..!! And after driving for about 1-2 Kms, the smoothness increases.
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx |
| | #132 (permalink) | |
| BHPian | Quote:
| | #133 (permalink) |
| BHPian | Hi Finetuning, As I had already informed you that I have added boric to my bike in a very little quantity and wanted to tell all of the bhpians that I have really enjoyed the ride after the treatment. The bike has just changed, lot of smoothness in gear change, engine noise is lesser and less of knocking of the engine. Man this is great and would try it out in my car too (Only after meeting you )
__________________ ========================== Indica Vista Aura - 2009 PULSAR 220 DTS-Fi 2007 Baleno VXi 2006 Avenger 2005 |
| | #134 (permalink) | |
| BHPian | Quote:
How are you i am back in bombay you can take another test drive in my zen.
| | #135 (permalink) |
| Hi Kaizer, I think first gear is always slight stiff compard to others in stock cars......this I noticed in many cars without any such boron.....boron to work inside gear box needs high temperature and this can be achieved only by connsistant driving.....hence its always desirable to run car for at least 20 km or so after adding such things....you will never forget the smoothness of gears once this works totally....but it takes time....I m waiting to test your car as early as possible..... Hi Kailashnj, I think whatever amount you added is just right for your bike.....slight more not advisable....its very difficult to find right amount for bikes....you now never need to repeat this.....you can change oil after few hundred km.....but benefits will be there forever untill opening of engine...so when to meet?? Enjoy... Last edited by finetuning : 6th April 2007 at 03:40. |
« Nissan Quest - Intermittent air-con blower speed
Different Service Schedules for Different Cars »
| Thread Tools | |
Similar Threads | ||||
| What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? | D.V.R | Technical Stuff | 22 | 10th November 2009 22:31 |
| My Experience Of Adding 2T Oil In Fuel | finetuning | Technical Stuff | 107 | 29th May 2009 23:06 |
| Adding Engine oil with Diesel. | chanapli | Technical Stuff | 39 | 18th August 2008 21:35 |
| My Experience Of Adding Boric Acid In Petrol | finetuning | Technical Stuff | 50 | 24th June 2008 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
Junkindica(iron block) in the morning but am having second and third and fourth thoughts after reading this article. Bye and wear your seat belts.
