Old 22nd October 2013, 13:52   #16
Vid6639's Avatar
Thanked: 21,078 Times
Default re: Renault Scala (keyless go) : Just dies, and refuses to start
Originally Posted by mmxylorider View Post
This is interesting and a pretty useful bit of information. Going little OT, is this setup present in most cars, regardless of fuel gauge reading?
Originally Posted by Soumyajit9 View Post
OT:: My Beat and my parents' Wagon R - Whistling noise Confirmed.
So, I guess I can safely say that the whistling noise is there in Petrol powered cars. Unaware of technology difference in Diesel powered engines and ignition.
Yes it's there in all cars. The sound is not of some release from furl tank but the whistling sound of the fuel pump that pumps the fuel from the tank to the intake.
Vid6639 is offline   (3) Thanks Reply With Quote
Old 22nd October 2013, 15:06   #17
Thanked: 103,565 Times
Default Re: Renault Scala (keyless go) : Just dies, and refuses to start
If you hit the engine start button and there wasn't any starter motor sound at all, I suspect it's a failure of the start button and / or the car's security system.
Here's another thread (Problems/Complication arising from "keyless go") where a Micra suffered an issue with its keyless entry.
Originally Posted by hawrie View Post
I first called the Trident Renault service guy
He then advised me to call the Toll-free number
Then I got a call from a Trident service guy
The mechanic arrived with another chap in tow and both got down to investigating.
I got several repeated assurances from the shift in-charge
I called the Trident guy a few times to follow up on the towing and he said that he was trying to arrange from his side as well.
a Mitsubishi Lancer turned up mysteriously and two men approached my car.
Finally, a tow truck arrived and my fears doubled. It was not a flat-bed tow truck but one with the old-school crane. Thankfully, the driver turned out to be one sent by Trident to wait with me until the flat-bed arrived.
a flat-bed truck arrived
I don't know whether to or
You interacted with ALL OF NINE PEOPLE before your car got towed? The last time I used a 24x7 helpline, I spoke to all of ONE PERSON before the tow truck arrived.
Originally Posted by bblost View Post
Please check your instruction manual. It would have a warning that this should never be done on a ECU controlled car.
Imran, agreed. However, there are times when a push start is the only option available. I do have a pair of jumper cables on me, but will confess that I've also push-started my cars from time to time.
GTO is offline   (1) Thanks Reply With Quote
Old 22nd October 2013, 21:59   #18
hawrie's Avatar
Received a call from the Service Center in the afternoon that the root cause is identified. Apparently the Electronic Control Module (ECM) has malfunctioned and needs to be replaced. I believe it costs Rs. 1.2L and will be replaced free as part of warranty.
I went to the Trident service center to discuss options, ETA, etc., and met the manager of service there. He said the same thing as the service advisor but was explained more specifically that the component that manages the accelerator function has failed in the ECM. This is an imported part and as it only fails in the rarest of rare cases, there is no ready stock. However, I asked him if he can source the part from another dealer in India to which he promised to check. I also expressed my disappointment with the entire episode with towing yesterday and he appeared to be genuinely concerned. He promised speedy action and has asked for time until 12pm tomorrow before confirming availability of the new ECM and/or the time required to return the fixed car.
BTW, I made it a point to mention that I am a member of Team BHP, an important forum for car enthusiasts.
Lets see how it goes.
hawrie is offline   (2) Thanks Reply With Quote
Old 22nd October 2013, 22:03   #19
Vid6639's Avatar
You should also request for a replacement car during the time your car is out of service.
Vid6639 is offline   (2) Thanks Reply With Quote
Old 23rd October 2013, 12:10   #20
Soumyajit9's Avatar
Thanked: 1,679 Times
Impressed with the prompt action taken towards identifying the problem. Hopefully they are 100% correct in their diagnosis.
Indeed rarest of rare case of the ECM failing in a car that's less than a year old !! I hope that they send the faulty part back to Renault for diagnosis and identifying the problem, which could easily become common if not fixed in other Renault products.
Happy that they did not linger over the issue for long and the response was quick. Should instil confidence in Renault customers.
Road assistance is a pain area for all car manufacturers, I guess. Chevy's road assistance is a horror. I learnt it when my car didn't start, as said earlier.
It's a good idea to have some numbers of Private Tow Services, apart from manufacturer 24x7 road assistance.
Soumyajit9 is offline   (1) Thanks Reply With Quote
Old 23rd October 2013, 12:23   #21
Maverick5490's Avatar
Thanked: 671 Times
Hope the ECM did not fail when the guys disconnected and reconnected the battery, and the fault would be something else. You should alert that to the service manager also.
Maverick5490 is online now   (2) Thanks Reply With Quote
Old 28th October 2013, 19:26   #22
Soumyajit9's Avatar
Just curious, is the new ECM fixed on your Scala ?
How was the experience ?
Incase, not fixed, what is the current status ?
Soumyajit9 is offline   Reply With Quote
Old 28th October 2013, 19:38   #23
akshay4587's Avatar
Thanked: 1,686 Times
How can a ECM/ECU, fail by just disconnecting and re connecting the battery?
Old 30th October 2013, 07:34   #24
hawrie's Avatar
Apologies for the silence, I was tied up at work. The ECM part arrived on Thursday evening as promised and the Trident service manager messaged me around Friday mid-morning to say that the car was ready. I picked up the car in the evening and was glad to see the car all cleaned and ready to go. I asked the service guys to follow up on the issue to see what caused the ECM failure in the first place.
It has been 4 days now and about 250km of driving and so far, there has been no repeat incidents. Yesterday afternoon, I received a call from the Trident service manager with the TVS towing relationship manager in conference. The TVS chap apologised profusely for the drunken technicians episode but tried to hint that they "don't drink at all" and this is the first such incident. I countered this and he promised that he would take "stern action" and apologised again for the inconvenience.
On the whole, I was happy with the way the service manager handled my case and showed a sense of urgency in resolving the issue. But I still feel that the on-road experience during the breakdown could have been handled much more professionally, had there been some good technicians on duty rather than people with a casual approach.
hawrie is offline   Reply With Quote
Verna refuses to start at times sajands Technical Stuff 21 18th December 2011 07:12
07 Civic refuses to start raghav.carfreak Technical Stuff 12 27th January 2011 19:58
Accent viva - refuses to start at signals bijuks Technical Stuff 21 22nd January 2010 10:53
Brand New Fiesta refuses to start! anachronix Technical Stuff 50 13th November 2009 19:58
i10 Kappa refuses to start. Battery flat? jango Technical Stuff 39 21st May 2009 13:28
