Old 28th October 2013, 11:33   #1
Thanked: 145 Times
Default Seatbelt buckle installed the other way round. What to do?
I recently found out that the seatbelt on my A-Star has its buckle installed the other way round.
To wear the seatbelt, it has to be twisted, which I don't think is such a good idea. What am I to do?
amolbh is offline   (1) Thanks Reply With Quote
Old 28th October 2013, 11:43   #2
bblost's Avatar
Thanked: 6,980 Times
Default re: Seatbelt buckle installed the other way round. What to do?
I have faced this issue.
By turning the seat belt and rotating it around we got the buckle fixed right.
The bar in the middle is the seatbelt buckle.
One side of the seat belt in red and other in blue.
Sorry but this is the best I could come up with.
bblost is offline   (15) Thanks Reply With Quote
Old 28th October 2013, 12:20   #3
Thanked: 145 Times
Thanks for the solution.
Is there a chance that the belt can get damaged while folding and rotating it?
Will try it out and post the result. Thanks!
amolbh is offline   Reply With Quote
Old 28th October 2013, 12:23   #4
bblost's Avatar
I had to do did this is in a hired cab. The seat belt did not look any worse after this twisting stuff.
bblost is offline   (1) Thanks Reply With Quote
Old 28th October 2013, 12:35   #5
tsk1979's Avatar
Thanked: 16,422 Times
I have seen this in many brand new Maruti cars.
tsk1979 is offline   (2) Thanks Reply With Quote
Old 28th October 2013, 14:15   #6
wanderernomad's Avatar
Thanked: 806 Times
Default Re: Seatbelt buckle installed the other way round. What to do?
It is easily done. Only ensure that you keep moving the buckle systematically while folding the strap till the entire side gets flipped. The seat belt doenst suffer nay damage. It happens many a times to a normal belt as well, as to why and how it happens accidently I am not clear but the reversal is equally easier.
wanderernomad is offline   Reply With Quote
Old 28th October 2013, 14:22   #7
S5157's Avatar
Thanked: 163 Times
I had this issue in my i10. I have reported this to service center , they removed and re-fitted the seat belt assembly to fix it.
S5157 is offline   Reply With Quote
Old 28th October 2013, 14:35   #8
rohanjf's Avatar
Thanked: 686 Times
I think it is better try DIY instruction of bblost first, than get it fixed at the authorized service centre. In case the mechanics do not fit the seatbelt correctly, you could compromise your safety during emergencies. I would trust an A.S.S. mechanic to fit a tyre properly but not a seatbelt because most mechanics do not consider seatbelts to be important (despite receiving necessary trainings).
rohanjf is offline   (2) Thanks Reply With Quote
Old 28th October 2013, 14:57   #9
sagarpadaki's Avatar
Thanked: 1,337 Times
I faced this problem too in my i20 .
Apply some cooking oil so that the twisting and sliding becomes easier. You can wipe it off once the operation is done!
sagarpadaki is offline   (1) Thanks Reply With Quote
Old 29th October 2013, 16:33   #10
Rehaan's Avatar
Thanked: 25,043 Times
Probably not the case, but for others reading this - just make sure that the twist isn't actually further up / out of view and hidden behind the fold-down rear seats.
cya
R
Rehaan is offline   (1) Thanks Reply With Quote
Old 29th October 2013, 23:25   #11
thoma's Avatar
Thanked: 1,112 Times
My in laws' i10 have a twisted belt and I did try the trick in bblost's post. But the buckle didn't have the space to turn the belt back. Will try it with oil as another member mentioned. We were using it with the twist; is that an issue?
thoma is offline   Reply With Quote
Old 30th October 2013, 01:30   #12
Thanked: 14,609 Times
I guess it would if there is a mishap and moreover it would be having an uncomfortable feel while it is strapped on.
Anurag.
Old 30th October 2013, 09:40   #13
Sankar's Avatar
Thanked: 4,655 Times
We had this problem in our i10, Astar and new Swift. It puzzles me why the belt buckle comes this way from the factory?
To bring the buckle forward do this:
1) Take the buckle to its top position near the B pillar anchor
2) Fold the seat belt like its mentioned in BBlost's diagram
3) Make the fold atleast a quarter of the width of the belt, the fold should start from within the buckle.
4) Pull down the buckle slowly down the belt, as the buckle comes down keep folding the belt in front of the buckle's path
5) Buckle will be reversed
I did this to all the above mentioned cars, it doesn't damage the seat belt.
Sankar is offline   (3) Thanks Reply With Quote
Old 30th October 2013, 11:43   #14
Thanked: 145 Times
Just make sure that the twist isn't actually further up / out of view and hidden behind the fold-down rear seats.
Had checked this, will still check again.
Also, the rear belt is too low, it directly comes in front of my mom's neck, which seems risky. I have seen people wearing seatbelts with some kind of cushion wrapped around it, especially shorter drivers. Are they for the same reason? If so, what are they called and where do you get them in Mumbai?
EDIT:
Check that the seatbelt is not twisted, if so the area restraining you is small increasing injury in this region. The belt when twisted can cut into you or leave permanent scarring.
Source: http://www.sdt.com.au/safedrive-directory-SEATBELTS.htm
Old 1st November 2013, 09:26   #15
Sankar's Avatar
The belt shouldn't come around the neck area, but since we don't get height adjustable belts on most variants the fit is always a compromise. Increasing the seat height might be an option.
Those cushions are called seat belt pads/cushions and its purpose is mentioned in the link you posted.
Quoting from the link: "Extra seatbelt padding or covers can improve the distribution of forces"
You might be able to find them in car accessory shops if not try ebay. Its a simple cushion pad and any seat or cushion guy can make a custom one for you. The pad is wrapped around the belt and closed with a velcro. The cushion will prevent chafing and be a great relief for those who has the belt near the neck area.
Sankar is offline   (2) Thanks Reply With Quote
Issue with Seatbelt Height (non-adjustable) Rocky_Balboa Modifications & Accessories 24 31st May 2014 19:43
Airbags don't activate if you aren't wearing a seatbelt? throttleking The Indian Car Scene 31 5th January 2013 20:12
Seatbelt pretensioners not standard on i10 Era? heinrici Hatchbacks 0 5th May 2008 12:21
Vendor quote: "The key for good sound quality is the way its installed" harmon_bro In-Car Entertainment 36 26th March 2008 11:12
