Old 9th November 2013, 17:03   #31
scofield's Avatar
Thanked: 131 Times
Good to know that the issue is sorted but did suggest you to do this at first as I experienced the same.
scofield is offline   (1) Thanks Reply With Quote
Old 10th November 2013, 00:57   #32
Travelbug's Avatar
Default Re: Linea Diesel: No one is able to solve engine problem EDIT: Now solved !
Originally Posted by pdma View Post
Thank you for the update Travelbug. Good to know the issue is sorted out.This thread indeed turned out to be a good discussion where I learned quite a number things.
Also just for information sake may I know the cost of the repair and if the car in under warranty did they cover this as part of the same.
Hi pdma,
I just had to pay 900 Rs for that inlet hose and yes not to forget they burned 1000 Rs Diesel for their hit and trial testing again and again while going for numerous test drives but I feel in the end it was worth it. I do have valid extended warranty but the part was not covered under it so I had to pay.
Thanks,
Travelbug
Travelbug is offline   Reply With Quote
Old 10th November 2013, 01:27   #33
Thanked: 14,602 Times
Originally Posted by Travelbug View Post
Hi All,
Thanks for all your inputs. They were unable to identify the problem hence they cleaned up everything related TC and Exhaust manifold. In the end they just replaced the inlet hose and now all error codes are gone and car is running fine. They were also unable to tell me that why they have changed inlet hose when they told it was fine.
All is well that ends well.
Good that the problem is solved How does the car feel now? The driving feel?
Good that they cleaned everything and set all as normal so it does say that the sensors were not working properly or not getting the right input to communicate to the ECU hence the error codes and the loss of power, excess smoke etc.
So the problem was solved in a fluke attempt. Congrats any way.
Anurag.
a4anurag is offline   (1) Thanks Reply With Quote
Old 10th November 2013, 01:31   #34
Travelbug's Avatar
Anurag.
Thanks Anurag, It feels like I'm driving a LINEA full of Boost at around 2200 RPM as for last 6 months I felt like I was driving a truck with no TC
Old 10th November 2013, 05:37   #35
phamilyman's Avatar
Thanked: 3,526 Times
FYI - you should not have driven the Linea like that for six months. Do ask them to extend your warranty for six months lest this lead to any turbo/engine issues down the road - their incompetence in solving this issue means they should extend the warranty to give you as much peace of mind ownership as before.
Old 21st November 2013, 23:39   #36
Travelbug's Avatar
Just an update, after they did all the cleaning of intake manifold and various other parts I'm getting constant mileage of 22-23 kmpl in the city. Pretty happy to see engine getting back in shape. Also I'll upgrading the suspension as per the new Linea specs
Travelbug is offline   (1) Thanks Reply With Quote
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
OHC trouble after engine flush. EDIT : Now Solved! ankitahuja Technical Stuff 78 10th December 2012 16:52
Strange problem with my petrol Swift. EDIT : NOW SOLVED abhaybakshi Technical Stuff 50 11th June 2012 13:01
Idling problem in my WagonR Lxi..EDIT : Now solved. ramki067 Technical Stuff 8 17th December 2007 11:19
Swift Diesel - excessive engine vibration when Idle. EDIT : Solved by MUL DieselFan Technical Stuff 36 2nd May 2007 11:37
