Old 7th November 2013, 13:47   #1
Thanked: 9 Times
Unhappy Bolero: Repositioning the handbrake
Is there a way to alter the positioning of the Hand Brake? When the reverse gear is on, you cannot manage the hand brake. I was driving into a car park and was on a slope. I needed to reverse to steer the car away from the wall. So, when I shifted the gear to reverse, I needed to manage the hand break and since there was no space, I could not do and ended scraping the bumper.
ratsharm is offline   Reply With Quote
Old 7th November 2013, 18:09   #2
Thanked: 103,654 Times
Default Re: Bolero: Repositioning the handbrake
In terms of ergonomics, the Bolero is one messed up ride.
Good news for you is, it's very easy to change the handbrake position. Any competent mechanic should be able to do the same for you. If it helps, the Bolero DI has its handbrake to the right of the driver's seat. See if that position works for you.
GTO is offline   (1) Thanks Reply With Quote
Old 7th November 2013, 19:37   #3
zalaps's Avatar
Thanked: 239 Times
Last week only I Visited Mahindra showroom. I've seen bolero pickups with hand brake at right hand side. Have a look at those as well.
zalaps is offline   (1) Thanks Reply With Quote
Old 7th November 2013, 20:00   #4
dhanushs's Avatar
Thanked: 4,506 Times
I'm surprised that you still have your hand-brakes working.. While owning a Mahindra please make it a habit of not relying on any add-on's other than the engine and drivetrain.
Jokes apart, when you change the hand brake location, please make sure you get the correct cable to match it with.
dhanushs is offline   (3) Thanks Reply With Quote
Old 7th November 2013, 21:13   #5
Thanked: 52 Times
I am doubtful if relocation of hand brake would help completely. I have a Bolero since last 4 years and found handbrake never effective enough to hold the vehicle's weight. During the initial one year, i kept trying to adjust it many times but it could never hold.
As dhanushs said, you rely only on the engine and gearbox in a Mahindra!
But otherwise Bolero is a no nonsense work horse, always keeps going.
Herbie98 is offline   (1) Thanks Reply With Quote
Old 8th November 2013, 11:25   #6
Thanked: 14,609 Times
If I remember correctly wasn't the handbrake under the left side of the steering wheel? If yes, can't it be repositioned there?
If standstill and you need the handbrake then there is the Jugaad anyway - Stones to be placed under the tyre to hold it + handbrake.
Anurag.
a4anurag is offline   (1) Thanks Reply With Quote
Old 8th November 2013, 12:19   #7
Thanked: 9 Times
That is scary! But thanks for the tip!!!
Does overuse of Handbrake cause wear? tanwaramit Technical Stuff 73 19th May 2016 12:59
Careful - Handbrake Lever!! getsurya Street Experiences 20 28th January 2009 14:07
Hydraulic Handbrake! SirAlec Technical Stuff 22 10th April 2008 14:35
Doing a handbrake turn to avoid an accident in an ABS vehicle? gopinathann Street Experiences 9 7th April 2008 01:30
Bill of materials for a handbrake assembly? ag501 Technical Stuff 0 29th November 2007 22:35
