Old 22nd October 2016, 11:05   #31
devrajman's Avatar
Thanked: 116 Times
Default Re: On Board Diagnostics (OBD) for Dummies
Originally Posted by Surojit View Post
I need an urgent information. For all of BS4 compliant TATA and ALeyland trucks, what are the OBD2 port pinout configurations? What are the manufacturer specific PID's which can be retrieved?
Many thanks in advance
*** Surojit M
These are OBDII, however they are 24V (please confirm using multimeter)
Will work on EOBD 24V scanners. However there will always be few PIDs and few DTC which can be seen only on service tool than open source OBDII.
devrajman is offline   (1) Thanks Reply With Quote
Old 23rd October 2016, 00:02   #32
Thanks Dev. If we can get some specific PID's which are assigned by manufacturers, it would be nice. Are we saying that these are never available publicly?
Surojit is offline   Reply With Quote
Old 23rd October 2016, 20:33   #33
devrajman's Avatar
Thanked: 116 Times
80%+ is available in public domain, the rest professionals do reverse engg to find it out, this is just seeing live PIDs and DTCs.
However there is 2-way commands like Activation Test, Programming, etc are more complex to reverse engg
Old 23rd October 2016, 21:08   #34
Great / thanks indeed Dev. I am presuming that for TATA which has Cummins BS IV engines, the pinout is for the 9PIN round diagnostic connector. This is translated to a 16pin connector and communication to is via the CAN bus and scanning is still via LM 327 IC. Please correct if the understanding is wrong. Many thanks again...
Old 23rd October 2016, 22:37   #35
devrajman's Avatar
Thanked: 116 Times
First Things First, I think its 16pin connector and not 9 pin round.
Best is to personally go and connect to a TATA vehicle of your interest. ELM327 will work for few minutes before its blown off on 24V system!
Using Torque any other app, create a dump of Live PIDs u can see. DTC will be tricky as u need to generate those errors to read.
Old 15th January 2017, 20:37   #36
Shashankjk's Avatar
Thanked: 41 Times
A dumb question but I could not get answer in earlier posts.
I have a torque app and elm327 Bluetooth obd reader.
I need to find answers to two problems
1. The Bluetooth adaptor remains on and blinking even after car is switched off. Won't it drain the battery? I don't want to plug and unplug the adaptor everytime. Can anyone suggest options? So I have just unplugged it and not using as of now. Not optimal use of the device I would say.
2. The torque app shows data/stats when you view it live on your cell phone. Is there a way by which it can store data which you can review later? I tried to explore a lot but want able to figure out a way.
Any help appreciated.
Shashankjk is offline   Reply With Quote
Old 15th January 2017, 21:51   #37
lordvader's Avatar
Thanked: 69 Times
1. I have been leaving it plugged for as long as I have had it. Hasn't been a problem ever. Moreover, Bluetooth and an led, in principle, should not drain so much battery to be of any problem.
2. In Torque settings there is an option to enable logging - 'toggle logging'. It will create a log of the selected PIDs which can be then emailed / uploaded in csv format for review later on.
lordvader is offline   Reply With Quote
Old 16th January 2017, 23:59   #38
Shashankjk's Avatar
Thanked: 41 Times
Thanks. That's a relief. Have left it plugged in today since morning. Let's see.
Regarding logging.
I was able to log it now. Thanks. Got worried since it never asked me a location to store logs. But have realised now that it stores logs in default folder 'torquelogs'.
Last edited by FlyingSpur : 17th January 2017 at 04:52. Reason: Broken quote tags fixed.
Old 20th January 2017, 17:41   #39
johnda's Avatar
Thanked: 11 Times
Hi folks.
My dad's Celerio Auto shift. Jus refused to engage gears. Everything was working. Except that the car refused to move. (From N to D)
The Maruthi authorised service center did an OBD and this is the errors there got pls help decode this.
DTC - P188C
B1189
Any help will be valuable. They are clueless
johnda is offline   Reply With Quote
Old 20th January 2017, 20:39   #40
el lobo 6061's Avatar
Thanked: 983 Times
DTC - P188C
B1189
P188C - All wheel drive relay module communication circuit
P188C - Audio [+] output #17 (TBD) circuit open
More info on following links
1
2
el lobo 6061 is offline   Reply With Quote
OBD (On-board diagnostics) for Indian Cars sharathjeppu Technical Stuff 1389 8th January 2018 10:37
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Inspiration: Sign Board @ Silk Board. Drive to Tamil Nadu kaushik_ak Travelogues 17 3rd January 2014 20:37
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
