Old 23rd June 2006, 12:13   #16
panky12345's Avatar
Thanked: 149 Times
thats SAD LBM.....i agree with iraghava not to show ur ICE, anyways all the very best for your replacement.
Old 24th June 2006, 23:21   #17
Thanked: 9 Times
Originally Posted by low_bass_makker
Since you have these readings all the time, whats the reading when you start the car first thing in the morning and how much does it reduce as you move on. In your case I feel that one of the cells would have packed up. You mentioned about 14.5 to 14.7 V this is pretty high and only a poor battery would give you those readings. Are these the charging current readings or the battery output Voltage. As you increase your engine RPM the reading should come down gradually subsequently stabalizing at around 12.5V. Sometimes if you carry out any Arc welding on your car without disconnecting your battery terminals the Diode in the Alternator blows out and when this happens the charging current to the battery stalled.
So long....
varunroy is offline   Reply With Quote
Old 25th June 2006, 01:50   #18
Thanked: 294 Times
Man thanks for the detail nothing like this happens I have corrected the above reading by reducing .4 volts from it and that is the real voltage now in idle situation the voltage remains at 14.2 and when i switch some thing on it drops to 13.2 or some thing and return back to the idle state that is 14.2.
Now i am running the car with a lead acid battery and it is running fine from the last 5 days till now no problem in the car has occured. So I think I was the battery fault..........
Will be getting the battery on tuesday .......
Old 25th June 2006, 08:54   #19
aZa
aZa's Avatar
Thanked: 17 Times
LBM bhai, i thought you had given the battery for recharging. So what happenned after that ? And OPtima comes with what warranty?
Old 25th June 2006, 11:07   #20
Thanked: 294 Times
Ya man I tried charging it no luck , and give it to amron dealer here in fbd he said he will change it any give back on tuesday...... (he did not asked for the warranty card)
Old 25th June 2006, 12:44   #21
kb100's Avatar
hmmmmmmmmm... and I was thinking of going in for the Yellow top myself...
kb100 is offline   Reply With Quote
Old 25th June 2006, 12:47   #22
jkdas's Avatar
Thanked: 1,436 Times
lbm's was a rare case and you do have warranty.
Old 25th June 2006, 21:18   #23
Thanked: 294 Times
ya I think everone who has good ICE setup in there car should get Yellow top
Old 28th April 2010, 10:41   #24
Thanked: 294 Times
Could not update the thread. I did not got the battery back. I had to fight with the service guys and got two ordinary batteries with one year warrenty. It was a bad deal buying a 11000/- battery and ending up with nothing.
I would not recommend yellow top to anyone.
Old 28th April 2010, 11:03   #25
ghpk's Avatar
Thanked: 193 Times
LBM paa ji, you updated a lost thread after 4 years.
Anyway which battery are you using now ?
Amaron Optima Yellow Top: Can they be used for off-roading? swastikviji 4x4 Technical 40 13th December 2010 06:42
Skoda RS ICE - Re-Done: Carbon + Steg + Ground Zero + Stinger + Optima BHAGWAN In-Car Entertainment 142 4th June 2008 14:53
A Horrible Accident Of NHC..2 Died on the spot. Mugen_Power Street Experiences 62 27th October 2007 15:01
Top Gear 2006 Survey : Fiat zooms into top 10, Honda, Skoda top list. amit The International Automotive Scene 10 8th March 2007 12:31
Optima Battery Installation for Skoda RS in Calcutta blueraven316 Modifications & Accessories 10 12th February 2007 17:22
