| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) |
| BHPian Join Date: Jul 2005 Location: Dehradun
| dude get the head facing done..... its the only way out.....a similar thing happened to my santro....i asked them not to touch the head....they didn't.....the performance went down and the fuel efficiancy went down.... then i asked them to get the head faced and got it done in front of me.....and now the performance is back to normal and the fuel efficiancy is also good enough..... so get it done.... |
| | #32 (permalink) |
| Newbie Join Date: Aug 2007 Location: Mumbai
| Yesterday, while driving (Santro Xing 2003) to Pune on expressway I noticed engine temperature moving towards ‘H’. Immediately I stopped and found coolant boiling and being thrown out from the vent of the coolant-tank. Car was serviced recently at Hyundai service center, so low coolant level was not expected. However, surprisingly, water in the coolant tank was ordinary water (not green) filled with rust. After the temperature became normal I found that driving upto 60 kmph without AC did not lead to heating. I showed the car to roadside mechanic who removed the thermostat valve and topped the coolant. However, later I found that the same problem still persisted. I have given the car for trouble shooting today to the Hyundai workshop. But surprisingly, the mechanic tells me that fixing thermostat valve would solve the problem. I understand that thermostat valve plays role only in cold environment. Since the heating problem has persisted despite removing thermostat valve the valve-malfunctioning is not the cause for over-heating. I am told that this valve costs 1000/- excluding labor charges. Hyundai advisor is sure that the problem would be solved by fitting thermostat valve (which was removed). Am I being taken for ride? Look forward for advise. 1- Do not use external editors (like Word). They put in unrenderable HTML tags. 2- Give some breaks and use punctuations when you type. Makes it easy to read. 3- Search for existing threads and post in them rather than opening new ones. Post cleaned up, formatted and merged. |
| | #33 (permalink) | |
| BHPian Join Date: Feb 2005 Location: Loveland, OH (cincinnati area), jabalpur, chennai
| Quote:
if you mean the overflow tube of the reservoir, most probably your radiator cap is gone. this is the one that maintains the pressure, and allows to "bleed" coolant once the pressure is above a limit. Looks like it is releasing all the pressure. Change it and it shud be fine. About the thermostat, for proper functioning you need to have a working thermostat. in your present condition, the coolant will start cooling the engine even before it's warmed up (engine operating temperature is much higher than environment....you do not need warming up only in cold areas), and your ECU will start screwing up with the fuel mixture.
__________________ ______________________________________ with great power, comes great responsibility. bigger the car, longer the cleaning time. Last edited by vivekiny2k : 27th August 2007 at 18:44. | |
| | #35 (permalink) | |
| BHPian | Quote:
hi viper, but isn't this the way most garages or service stations change the coolant? or do you mean if the water bubbles up immediately from a cold engine, ... then the gasket is blown?
__________________ ...looking forward to sit a few feet above mean road level and away from potholes... | |
| | #36 (permalink) |
| BHPian | Isn't it the problem with the radiator fan not working ,thats making the engine over heated? During emergencies, I have seen people using regular water in case the engine is heated up when the coolant levels are low.
__________________ Abhi Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves. |
| | #37 (permalink) | |
| BHPian Join Date: Mar 2007 Location: Bangalore / Boise
| Quote:
However, in your case, i guess a different thermostat needs to be replaced - the one which switches on the fan when the half way mark is reached on the temp guage. | |
| | #39 (permalink) | |
| Quote:
[FONT=Times New Roman][SIZE=3]This is 4-year-old car with about 50000 km running. Car is well maintained with servicing every 3 months. Why should radiator go bad so early? Why it was not noticed earlier during regular servicing? When removing thermostatic valve had not solved the overheating problem the valve was obviously not the cause. How a professional mechanic could miss this logic?[/SIZE][/FONT] | |
| | #40 (permalink) | |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
Infractions: 0/1 (4) | Quote:
And since the problem seems to be happening only at high speeds, there is something much more to it than what your current diagnosis shows. (Points to a leaky head gasket). The AC service is a bit baffling. Possibly only the heat exchanger for cabin heating (being in the coolant circuit) would need cleaning. Nothing else in the cooling circuit should need to be touched and of course you should not be billed for gas/refrigerant charging. Please confirm this. | |
| | #42 (permalink) |
| Thanks Anup. Changing radiator seems to have helped. I drove 250 km yesterday on expressway with no problem. The color of coolant looks fine. Hyundai workshop actually chaged 6300/- and not 10000/- as was estimated earlier. AC servicing with gas refilling was anway due. They say that radiator cleaning by applying pressure is difficult as there are changes of rupturing the thin metal sheet. Hence radiator choking problems are not noticed during servicing. |
| | #43 (permalink) |
Infractions: 0/1 (4) | djag, good that your problem is sorted out for now. I would recommend you keep a sharp watch on the radiator and the colour of the coolant. I do not believe that this is the end of the problem - how come there was carbon in your radiator? As I've mentioned in my earlier post, there is high possibility that your head gasket 'leaks' at higher pressures. |
| | #44 (permalink) |
| Newbie Join Date: Oct 2007 Location: Navi Mumbai
| If you start the car with the radiator cap open and the water inside starts to bubble or thrown out ......i am faced this problem yesterday with my esteem ...what can be the reason ...i have just changed the clutch plate and the thermosata is bypassed temprorarly ...ill see the meshanic today ....want quick help |
| | #45 (permalink) | |
| Senior - BHPian | Quote:
__________________ "She may not look like much, but she's got it where it counts, kid." | |
| Thread Tools | |
Similar Threads | ||||
| Ford Fusion : 8K with No Nonsense!!! | gemithomas | Long-Term Ownership Reviews | 19 | 11th October 2007 22:46 |
| Why isn't anybody talking about Civic on TeamBHP now? | salilpawar1 | The Indian Car Scene!! | 35 | 2nd July 2007 16:58 |
| New F1 rules...nonsense | The Wolf | Motor-Sports!! | 21 | 18th February 2005 11:11 |
| Dealership Nonsense | RJK | The Indian Car Scene!! | 23 | 2nd September 2004 14:01 |
| Now we are talking | _Crazi4Speed_ | The International Automotive Scene | 6 | 13th May 2004 03:04 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
