Thread Tools
Old 23rd June 2006, 12:18   #1 (permalink)
panky12345's Avatar
Default Diesel --> CNG/ LPG??
i tried searching but couldnt find an answer. can i fit a CNG/LPG kit in my diesel vehicle? i talked to one of the guyz here and he told me that i CAN NOT. any nputs?
__________________
SINGH IS KINNNNNNNG..
Old 23rd June 2006, 12:43   #2 (permalink)
Team-BHP Moderator
Zappo's Avatar
I do not know about the LPG part of it but I guess CNG is possible after all. Look at all those buses and trucks in Delhi... That should give you a cue. How easy or difficult that will be is an entirely different question though.
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here.
Zappo is offline   Reply With Quote
Old 23rd June 2006, 18:24   #3 (permalink)
wolfinstein's Avatar
May I suggest that you get in touch with a CNG Installer- Infact Since you own an Indica- You may want to speak with the TATA Authorised CNG Installer in Okhla called Shri Manker..Contact details are available on IGL Onlines Page...!
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 23rd June 2006, 18:47   #4 (permalink)
A CNG powered engine requires spark plugs for ignition, just like a petrol engine does. Hence conversion from petrol to CNG is easy. You also retain the option to run the vehicle on petrol when you desire.
Converting a diesel engine into CNG is also possible but requires considerable modification to the engine. You would need to provide for spark plugs for instance. If you want to run a "diesel-converted-into-CNG" on a fuel other than CNG, then, that fuel will have to be petrol, not diesel.
Converting diesel into CNG does not make any economic sense, though it may make sense environmentally.
directinjection is offline   Reply With Quote
Old 23rd June 2006, 22:09   #5 (permalink)
As far as i know, Petrol to CNG/LPG is too easy, but from diesel its too tough.
U need to modify the whole engine. Asked a mechanic, he said clear NO.
Prefer Petrol car & then convert to LPG
prakash2757 is offline   Reply With Quote
Old 24th June 2006, 11:30   #6 (permalink)
sumitkalindi's Avatar
Diesel can be converted to only CNG, not LPG. But it needs works. Though a good CNG convertion workshop should be able to do it without to much ado.
sumitkalindi is offline   Reply With Quote
Thread Tools
My experiments with LPG and CNG .anshuman Long-Term Ownership Reviews 33 4th January 2008 11:07
CNG Vs LPG VishalMukherjee Technical Stuff 2 10th December 2007 16:34
WagonR - LPG or CNG? imran_kasu Technical Stuff 9 17th July 2007 23:03
LPG / CNG kits amu1983 Modifications & Accessories 6 27th February 2007 22:13
Cng Vs LPG.. Rice_tuner Modifications & Accessories 1 27th February 2005 13:20
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
