Old 8th November 2005, 23:35   #76
ananthkamath's Avatar
Thanked: 63 Times
You are forgetting that manufacturers look at every single nut & bolt with an eye towards cost. This does not mean that they use substandard materials everywhere.
The 3 examples that you gave: a majority of people will likely not even notice the improvement due to the usage of these....So the manufacturers dont see the point in reducing their profit margin by a good 4k unless they are convinced that the customer perceives it as substantial added value. In other words, perceived value always makes it way onto a product.
About the 4-1 vs. 4-2-1, I think you mean stock exhaust manifold vs. 4-2-1 header. The former does not qualify as a 4-1 header though it looks like one.
ananthkamath is offline   Reply With Quote
Old 9th November 2005, 22:34   #77
Kaizer Sozay's Avatar
I was Watching this TV serial called Overhaulin which airs on Discovery Travel & Living, Where they modify cars, They focus a lot on body work and less on engine mods. but i have seen that in most cases they fit an air filter that looks a lot like the typhoon intake K&N. And these guys are supposedly the best.
Kaizer Sozay is offline   Reply With Quote
Old 9th November 2005, 22:45   #78
Thanked: 63 Times
That pretty much shows what they are the best at.
So that doesnt prove anything.
Old 10th November 2005, 02:02   #79
nitrous's Avatar
Thanked: 285 Times
Ananth, lets forget K&N for a moment. Lets discuss about the concept of these gauze filters. Just using these oiled gauze filters make a positive difference from the stock paper or foam material. Can u explain about this??
The reason i'm asking is because there should be a logical reason why the K&Ns show some improvement in a few factors just by the difference in the material used.
Old 10th November 2005, 09:22   #80
Thanked: 63 Times
What kind of positive difference? Can you please explain...
Old 10th November 2005, 09:32   #81
One reason why the manufacturers don't install these filters might be because of the increased noise levels, with which they may not be able to meet the standards.
But is this discussion restricted to just K&N filters or any intake filter in general? I'm sure an increase in air-flow would show some improvement in the power output. If that's the case, why are K&N filters eliciting such mixed-bag of responses? Incorrect installation?
rzoster is offline   Reply With Quote
Old 10th November 2005, 20:14   #82
fieroid's Avatar
Thanked: 287 Times
Originally Posted by ananthkamath
But wont that reduce the airflow capability you gained on account of the K&N?
What was the situation with the stock filter...did you find any dirt with that?
My only argument here is that, if the question is of cost vs. gain, then I am sure the K&N loses out.
On the technical front, personally (I repeat, personally) I feel that a good, large-diameter (larger than stock) foam filter is more than enough to do the job (because thats what I have used all the time, even on high-rpm race 2-strokes). K&Ns are no good at all on the dirt track.
fieroid, as an aside, do our hosur friends use K&N? I think not, though I am not sure....
Ananth
ok, lemme answer one by one..
using foam wraps do restrict a bit of flow, bit will def keep more dust away and since k&n is known to improve airflow by 300%, its fine if its just 200% to me!
on my stock filter i def see some dust settled and yes the k&n was also dust, but was filtering better than a stock filter for sure....
yeah, the k&n looses on the cost vs gain battle, however some still prefer them..
i frankly might not buy a k&n anymore, would prefer a UNI instead...
nope, the hosur boys dont use k&n!
fieroid is offline   Reply With Quote
Old 12th November 2005, 15:19   #83
protege's Avatar
What's this Hosur guy stuff? Am I missing something?
BTW, I also have a K&N stock filter.. although I can't prove whether the BHP have gained or not.. I feel it has.. anyway.. my FE got improved by 2kmpl.. previously I used to get 12-13kmpl in my carb zen.. now it gives 14-14.4.. and I travel through the ver congested 100ft/Ring road in koramangla, B'ghatta road for my daily commute.. Probably.. K&N may be good for carb engines which are not optimally tuned as in MPFI. So MPFI engines don't see the gain.. and carb engines can see that.. any thoughts?
protege is offline   Reply With Quote
Old 12th November 2005, 18:17   #84
revtech's Avatar
Thanked: 35 Times
hey protege i have a similar question as yours.when a K&N filter is installed in a carb engine it also makes more noise than when installed in an mpfi engine.whats the reason for that ??
rev
revtech is offline   Reply With Quote
Old 12th November 2005, 19:20   #85
Thanked: 817 Times
Default K&N ...
Haven't used K&N(planning to) so cannot speak from personal experience. But based on what I have read on this forum and from the K&N site here are a few of my opinions:
- on the dust filteration aspect I think the oil applied to the K&N filter has an important part to play. And yes a K&N filter does need maitainence. It is not as if you can dump it in your engine bay and forget it.You will have to wash and re-oil it periodically. Only..while you throw away the stock filter and replace it with a new one you can reuse the K&N filter.
- on the value for money. You buy a K&N and I think you might break even on the cost if you use your car for 1 million miles as K&N says their filters are good for. . If you gain any improvement in FE then you'll break even on the cost faster. But then nobody said performance came cheap:-D. And engines are mechanical devices..the more performance you extract out of the stock engines by modification(depending on the type of mods of course) the more wear and tear and consequently less life. Why do you think F1 engines are good for only 1000 kms or so after which they have to be completely rebuilt. Performance is not about value for money it is about value for the soul
- Manufacturers have to cater to the majority of car buyers not the minority which we petro heads are...so assume Maruti decides to put in 2500/- K&N air filters in the M800. This is in place of the stock one which costs 90/-. I don't think the majority of the population care whether it is K&N or stock ...what they might care about though is the 2400/- increase. So too with free flow exhausts...my parents hate the sound .
whaddya say to these ramblings?
Drive on,
Shibu. l
shibujp is offline   Reply With Quote
Old 14th November 2005, 19:40   #86
fieroid's Avatar
Thanked: 287 Times
hosur guys means TVS!
in a carb'd engine, u will have to tune the carb to get the maximum benefit from a freeflow filter and u will have to play wid air/fuel ratio...
however in an MPFI engine there is no tuning required!
a freeflow filter works better on a fuel injected engine!
Old 20th November 2005, 22:35   #87
Can someone pls. tell me how much difference a K&N conical filter would make in a Baleno?
Slash is offline   Reply With Quote
Old 24th November 2005, 10:18   #88
Reading this thread and various others on K&N on this forum, i have got the impression that it will be more safer to put the stock replacement filter in the Baleno instead of the Conical one. I think the filtration of the stock replacement filter might be better than the conical one and it might be less risky in rains.There is also the matter of installing the conical filter properly for optimum function.
But then the performance of the conical filter would obviously be better. So your choice.
imjimmy is offline   Reply With Quote
Old 24th November 2005, 10:40   #89
Thanked: 44 Times
I contacted the local K&N dealer in Goa, for a stock size filter for my Baleno. To my surprise, he did not talk about the oil used for cleaning the filter, and told me it was to be cleaned by dusting it with a compressor. When I insisted, he disclosed that nobody uses the oil and anyway nobody knows much about these filters... the approach was so casual, I am appalled!
filcord is offline   Reply With Quote
Old 24th November 2005, 10:55   #90
MrBoombastic's Avatar
This is just one reason why I have often said modifying and fiddling with cars in India is not always a good idea. Not saying that there aren't a few out there who can really do a great job technically, but most are really not reliable. The same applies when people want to increase tyre size by 2" or more without proper research.
MrBoombastic is offline   Reply With Quote
K&N filters & protection from water shazikon Modifications & Accessories 23 22nd December 2011 20:13
K&N Filters adityapd Technical Stuff 35 2nd November 2009 18:49
K&N filters V/S Proton filters mail4ajo Modifications & Accessories 1 25th April 2006 00:34
Does K&N Filters really enhance performance? finneyp Modifications & Accessories 2 12th December 2005 17:56
K&N Filters... help needed spdemon Modifications & Accessories 36 15th September 2005 15:44
