Old 11th December 2005, 12:44   #106
binz's Avatar
Thanked: 411 Times
As you know i bought a k&n for my kinetic.The filter was fitted in the original air filter box and we didnt close it.The sound has improved but not much change in performance(very little on the top end).Please note that i have a larger carb as the bike is the jap version.I have a doubt whether the ''cold air intake'' applies to this too.Should i get new piping and place the filter outside the bike???plzzz help!!!!!!!
binz
Old 12th December 2005, 18:21   #107
binz's Avatar
Thanked: 411 Times
could someone plzz clear me doubts below
binz
Old 12th December 2005, 18:33   #108
Thanked: 43 Times
Thanks, I read the test report, and I'm blowing my money on something else this Christmas, certainly not an aftermarket air filter.
filcord is offline   Reply With Quote
Old 13th December 2005, 21:13   #109
idnani's Avatar
From my experience, I have seen, and have been told by professionals that K&N 'drop in' filters DO NOT enhance performance to any noticible extend, and with respect to most indian cars, not at all! Sorry for the disappointment, here is the reasoning.
Unless the car's intake system has some MAJOR flaws in it, and its very restrictive in nature, then a K&N will help it 'breathe' better and give it the air it was designed for, and there might be a power gain, but you dont normally see this unless some nut designed the intake system and all production cars dont generally have such oversights.
Secondly, most indian cars dont have more than 100 - 140 BHP and the gain from an intake (CAI, HFI etc) is a generally a percentage of total power, say a 2% gain (which is a lot!) etc and thats really not very noticible on a low HP, low torque car to begin with.
So a drop in K&N filter on most cars is pretty useless, and in say a Honda city 1.5, you wont see even 1-2HP increase. I have personally witnessed a 3 liter lexus IS300 on a dyno, tested with K&N drop in (ZERO GAINS), and then with an HFI intake (2HP gain) and then the same HFI intake with a race ECU (aka chip) which gave a 12HP gain. This proves that K&N drop in filters are worthless, an intake gives little performance gain, and you really need to recalibrate the air/fuel ratio to get the maximum gain. In this example, an SRT HFI was used, which is pretty much the most advanced intake system available for the 2JZ engine on the lexus IS300 (same engine as the toyota supra), with a chip and the gains were 5% overall HP. Also, the lexus IS300 is very conservative from the factory, and shows a good amount of gain from aftermarket mods, so its not maxed out basically.
In general, intakes without a chip just add an agressive sound / tone to the car, and the placebo effect plays a greater role. There might be some power gain with just an intake but dont expect it to be much. I have read threads where people brag about their intakes, and claim their car is much faster etc etc...
idnani is offline   Reply With Quote
Old 13th December 2005, 21:17   #110
idnani's Avatar
I just went back and read some ealier posts, what I said mainly applies to fuel injected cars...
Old 25th January 2006, 22:24   #111
karthik247's Avatar
Thanked: 16 Times
Guys just read at www.briskoda.net that K&N filters cause problems to the MAF's of cars cuz they have more oil than standard filters.
Can someone explain/confirm this.
karthik247 is offline   Reply With Quote
Old 27th February 2006, 19:06   #112
wolfinstein's Avatar
although this has been asked a zillion times now..Don't mind my asking again..!
The K&N Filter- Will Increase Performance, But does it lower Fuel Economy-Even If I drive the same way I do now..will the filter increase consumption..!
How do you buy an orignal K&N Filter- There website mentions Fakes are available in the market...So how do you know the K&N you have is Orignal.
Any good place in Delhi where one can find an Orignal K&N filter.
It will fit like the OEM filter right- Whats the Estimated cost- The OEM filter goes for Rs 400 Showroom Price..! Will K&N be more expensive..!
Is the K&N filter washable or we still blow the dust out of it using an Air-Hose..! How long does it last...compared with OEM filter.
regards
wolfinstein is offline   Reply With Quote
Old 27th March 2006, 12:40   #113
shuhaib's Avatar
Thumbs up
My experience with K&N is not at all bad. I have installed in my swift and the car performs very well. Top speed I have not tested yet.
Fues efficient - cant say 100% coz on highways I have got mileage upto 16.5kms per litter after installation of K&N (before it was giving me max of 12.5 on highways. City driving, 10 to 11 before and after.
Cleaning the K&N filter with water or blowing air will spoil it. K&N cleaning solution kit is available and I have read some where that you can even clean it with petrol but im not sure about it.
shuhaib is offline   Reply With Quote
Old 2nd April 2006, 12:38   #114
freakrz's Avatar
Thanked: 50 Times
hey...i am looking to buy air filter for my swift...this one i am getting it from the U.S...can someone tell me if a filter with 3 inch inlet would fit in or what is the standard size of inlet opening i need to look for when buying for swift..
freakrz is offline   Reply With Quote
Old 4th April 2006, 18:48   #115
mail4ajo's Avatar
Thanked: 222 Times
regards
Check www.methodsonline.com for all your answers
mail4ajo is offline   Reply With Quote
Old 1st May 2006, 15:02   #116
Thanked: 24 Times
i have a non crde scorpio. Can anyone let me know the size/ model number of the k&n filter which can be used in place of the current one?
Rgds
indianrunner is offline   Reply With Quote
Old 1st May 2006, 22:08   #117
i have used the stock filter on my corsa feel the torque has increased because of which my fuel efficiency toobefore the filter with ac , my car used to feel very sluggish but now its awesome...i dont find any difference in the cars performance
racingismylife is offline   Reply With Quote
Old 1st May 2006, 22:39   #118
manson's Avatar
Thanked: 2,035 Times
i think its more or less safe to go in for a 3' dia filter, would be fine with most cars around here, you could surely check with someone whose installed a filter though on their swift. One of Aseem's (member on the forum from delhi) has fitted a K&N filter onto his swift, maybe you could check with him what diameter pipe did he use.
manson.
manson is offline   Reply With Quote
Old 1st May 2006, 23:40   #119
Jay
Jay's Avatar
Thumbs up
Originally Posted by imjimmy
How would just adding a stock replacement filter to a car be a modification that requires skill?
From what i understand it's just a simple matter of opening the clamps, removing your old filter and placing the stock K&N there.
That's why i had said Stock replacement K&N filter is a safe and easy option.
Also i don't think it can degrade the performace/FE - so even if you don't gain much, you won't loose anything. It should surely do a better job than the filters auto companies put in their cars as stock.
totally agree with you on this imjimmy, i recently put stock replacement filter ( K&N ) onto my santro... can surely feel the difference in the torque at low rpm.... not checked the FE but then i am sure it would have increased as the gear change is easily possible at low speeds without any problem... am easily able to drive at 30 kmph in 5th gear ( city traffic ) without any jerks, a gentle press on the throttle and the car picks up speed without any difficulty. No doubting its performance..... the installation too is very easy and i dont think needs a person with skills only. Can be done in 2-5 mins.
Jay is offline   Reply With Quote
Old 2nd May 2006, 16:48   #120
sumitkalindi's Avatar
Thanked: 13 Times
Originally Posted by protege
What's this Hosur guy stuff? Am I missing something?
BTW, I also have a K&N stock filter.. although I can't prove whether the BHP have gained or not.. I feel it has.. anyway.. my FE got improved by 2kmpl.. previously I used to get 12-13kmpl in my carb zen.. now it gives 14-14.4.. and I travel through the ver congested 100ft/Ring road in koramangla, B'ghatta road for my daily commute.. Probably.. K&N may be good for carb engines which are not optimally tuned as in MPFI. So MPFI engines don't see the gain.. and carb engines can see that.. any thoughts?
Carbs have to be tuned to perform with a K&N and it is very easy, you just fiddle with a screw here and a screw there and bingo. Well it is not so easy, but any mechanic worth his salt can do that. But MPFI, well in this it all depends on the chip, which is programmed to work with the airflow of the stock filters. So with the K&N it gets confused. Though it has a remedy, reprogramm the CHIP. well it is not everone's forte. and if not done properly can ruin everything.
However I have heard that what you need to do is disconnect the battery at night and leave it overnight, so that the programming gets erased. Then next day when you start the car the chip goes into learning mode. and you have to drive very cautiously, so that the chip can pick up your driving habits and reprogramm itself. How you Drive is how it gets tuned.
Though I never have been tried that.
sumitkalindi is offline   Reply With Quote
K&N filters & protection from water shazikon Modifications & Accessories 23 22nd December 2011 20:13
K&N Filters adityapd Technical Stuff 35 2nd November 2009 18:49
K&N filters V/S Proton filters mail4ajo Modifications & Accessories 1 25th April 2006 00:34
Does K&N Filters really enhance performance? finneyp Modifications & Accessories 2 12th December 2005 17:56
K&N Filters... help needed spdemon Modifications & Accessories 36 15th September 2005 15:44
