Old 14th January 2014, 17:54   #121
Catamaran's Avatar
Thanked: 136 Times
Originally Posted by Jaggu View Post
Indeed good news to pay 30k instead of 450k BUT! what was the actual issue? and what all is being done to rectify the same? Has Skoda/Dealer given you clear info about the problem and the work that is being done? Do get this in writing to cover any future issues with the car.
No not yet. I only have verbal confirmation from Skoda and awaiting their official mail. Will see what is the actual issue and what works are being done on my car.
And of course it is good news when you hear that the car is getting repaired under warranty and they have said upto a maximum of 30K, so may be less. Will update on this once I have more information
Catamaran is offline   (3) Thanks Reply With Quote
Old 14th January 2014, 18:06   #122
Thanked: 1,642 Times
Default re: Skoda Yeti. 4.5 lakh repair bill! EDIT: Fuel system replaced under warranty
Good to hear you're moving towards a resolution, Catamaran. I still don't see why you should be footing 30k if it is actually done under warranty - is this the actual cost of parts to be replaced as per the Skoda rep, as against what Marikar wanted you to cough up before Skoda intervention?
Steeroid is offline   Reply With Quote
Old 14th January 2014, 20:47   #123
drmohitg's Avatar
Thanked: 3,838 Times
That's something to cheer about. And you still should not be asked to pay 30k if its not your fault. Do insist on the same. I feel it is lucky that there were multiple threads on the forum at the same time and probably that was too much for even skoda to turn a blind eye to.
drmohitg is offline   (2) Thanks Reply With Quote
Old 14th January 2014, 20:48   #124
Akshay1234's Avatar
Thanked: 7,242 Times
Nice to see some good news. I too would like to see what exactly is being done to your car. Also the 30k which is the maximum which you may have to pay would probably be for labour and consumables.
Old 14th January 2014, 21:51   #125
Thanked: 640 Times
Finally some good news. Looks like Skoda is watching Team-BHP threads explaining "Skoded" stories. Hope others also will get an amicable solution from Skoda.
Like other members said, you may be feeling relaxed as you got a big relief in the bill (from Rs.4.5 lakhs to 30K). But try to get the bill further reduced.
MaxTorque is offline   Reply With Quote
Old 14th January 2014, 22:03   #126
Thad E Ginathom's Avatar
Thanked: 8,376 Times
Nice to see some good Skoda News! But, with a possible debt of 30K, I'm not sure just how good it is...
Thad E Ginathom is offline   (3) Thanks Reply With Quote
Old 20th January 2014, 08:50   #127
Thanked: 308 Times
Originally Posted by Catamaran View Post
1. What would have been the real problem ? I do not believe the story of this adulterated fuel as the car had run for almost 90kms after filling fuel and then stopped. The agent has strange answer telling this that the fuel filter has certain capacity beyond which it will not perform. The filter is meant for stopping water and other impurities right ??
I have no idea why these things happen, but when my superb started getting this check engine light issue at about 3-4k kms, we found that there was coolant in the gearbox, engine oil mixed with coolant and other seemingly impossible plumbing mixtures.
Sadly after 3-4 years of trying to get it fixed, we had to just give our car away for no money.
Be very careful leaving your car at the workshop for extended periods of time. In my case, they took out a lot lf parts (sunroof switch, headlight bulb) and replaced with old or non genuine parts. Sadly there's nothing you can do to prove this -- all you can do is let them know that you're an 'aware' customer and take photos of the engine and interiors when you leave the car there, and take the pictures in their presence.
Don't try to go to the media -- Skoda is a big advertiser. Don't try to go to the consumer court. They have a huge commitment of resources to scuttle consumer court issues. Just try to be polite with Skoda people, get your work done, and sell the car ASAP. And we all know how useless it is to try to shame them on FB, twitter etc.
It sucks, but there's not much that you can do. Instead of feeling angry and upset over it, just focus on getting rid of this thing. Don't wait for the value to run to the ground. Good luck - keep your chin up and focus on what you gotta do - get this thing fixed somehow and Sell it.
Don't get distracted by media, consumer court, posting on Facebook etc. Just fix -- and sell.
torquing_points is offline   (6) Thanks Reply With Quote
Old 20th January 2014, 09:20   #128
wilful's Avatar
Thanked: 893 Times
My good God! That is indeed a very dark picture you paint about Skoda and unethical practices by service centres. Makes it sound like one long dark tunnel with no light at the end. Skoda had better do something and pronto to improve its image.
That said - don't you think the replacement of original parts with fake/old parts is a one off bad apple (service centre) thing? I am sure individuals make a difference - a couple of dishonest/sharp service or sales guys can create havoc.
wilful is offline   Reply With Quote
Old 20th January 2014, 09:23   #129
audioholic's Avatar
Thanked: 6,118 Times
What I am surprised to see is that there is no mention of what repairs will be carried out. Can the consumables alone cost 30k? Or is it a case of the dealer giving a high initial estimate to fleece Catamaran and once this issue is escalated, they just decided to do only what was necessary?
Catamaran, please ensure that you follow up the repairs closely so that they will not cut corners to reduce the bill and pose in front of you as if they did a good deed. Else you may face issues in sometime again. Also demand a written document on what the problem was and what was the solution to it.
audioholic is offline   Reply With Quote
Old 20th January 2014, 10:06   #130
Thanked: 308 Times
Who knows. I used to try to think the same when I read cases of what happened to others -- until it happened to my own car. Unfortunately I had no proof - except that the headlights suddenly looked older, the sunroof switch suddenly was scruffy and a different shade of grey etc.
Maybe it's a couple f guys. Maybe it's all of Skoda -- it doesn't matter. I don't drive a Skoda anymore, so i try to not get angry about these things anymore. I learned the art of 'zen' during my whole Skoda experience. It doesn't bother me anymore.
torquing_points is offline   (1) Thanks Reply With Quote
Old 20th January 2014, 10:25   #131
iliketurtles's Avatar
Thanked: 1,049 Times
Be very careful leaving your car at the workshop for extended periods of time. In my case, they took out a lot lf parts (sunroof switch, headlight bulb) and replaced with old or non genuine parts. Sadly there's nothing you can do to prove this...
Wow, sorry to hear of your woes with the Superb. Since you're from Mumbai, could you please let us know which dealer/workshop you're referring to so that we can all be wary/avoid it?
iliketurtles is offline   Reply With Quote
Old 20th January 2014, 10:31   #132
Thanked: 670 Times
Dear all
Finally some good news. Mr. Shakeel from Skoda had called. He has confirmed Skoda's decision to repair the car under warranty terms and maximum we may have to spend from our side will be 30,000 Rs. Think it's a fair deal and I am awaiting official confirmation from Skoda /
Dealer. The support from Marikar Engineering has so far been excellent. Although a little late Skoda has finally agreed and I am happy with their support. They were calling us regularly and updating and sent their expert to check the car again.
Congrats! I believe Skoda is trying its best to satisfy their customers. Good Move! Having said that, the issue is because of the adulterated fuel. A relative of mine told me his i10 has the same issue and the fuel pump had to be changed, costing him INR 15K.
I'd suggest you to be careful from where you fill.
nitinbose is offline   Reply With Quote
Old 20th January 2014, 11:09   #133
joybhowmik's Avatar
Thanked: 1,928 Times
Sometimes prevention is the best cure.
If the dealer opens up the car and finds a defective part that needs replacement which is out of stock, get them to put everything back in as before, make an advance payment for the part , and drive your car back home. If the car is not driveable, get it towed back home. Bring your car back when all the parts arrive.
Don't leave the car in the garage for extended period of time, especially when no work is getting done on it. These dealers often have little/no security, and many a time, they dont have secured area to hold wip cars. In Okhla, Delhi have seen dealers park cars waiting for parts out on the street, to free up precious workshop space.
What happens to the cars in such cases is anyone's guess.
Old 20th January 2014, 22:38   #134
Catamaran's Avatar
Thanked: 136 Times
The dealer has ordered all parts and it seems that except for the high pressure pump all other parts are readily available in india. The HP pump has to come from Europe. I think they are changing the injectors, fuel pump and related things connected to the fuel system, will have to get the confirmation though.
Hopefully will get the car in max two weeks time. May be I will have to bear the cost of filters, oil and miscellaneous which we have agreed.
Old 24th January 2014, 09:51   #135
Thanked: 308 Times
Hi this was delhi at Giriraj motors.
torquing_points is offline   Reply With Quote
Engine trouble in Mahindra Ssangyong Rexton EDIT: Turbo replaced under warranty .anshuman Technical Stuff 234 5th June 2018 12:31
6 months old VW Polo: 2 breakdowns, 2 parts replaced. Edit: Pics of fuel leak. shashank.nk Technical Stuff 32 17th December 2014 12:50
New Skoda Superb 2009 Breakdown. EDIT : Car being replaced by Skoda rohitioc The Indian Car Scene 140 2nd January 2011 12:06
Bill & Warranty carboy In-Car Entertainment 9 18th June 2007 06:14
