Old 14th January 2014, 16:48   #16
tsk1979's Avatar
Thanked: 16,422 Times
Default Re: Tata Safari Brake Failure. EDIT: Solved
Originally Posted by narendra.vw View Post
TDs means? Get the wheel alignment done in particular toe in, toe out. Personally check cutting angle both ways with both wheels.(left & right). They should have equal gap with chassis & not touch any part. (Fingers can be used for gap checking.) Please check tie rod end life.
TDs mean test drive.
The vehicle was again put on lift after the fine tuning and checked for equal turning in both directions.
So hopefully, things should remain fine!
Old 14th January 2014, 17:36   #17
jkrishnakj's Avatar
Thanked: 323 Times
Hi Tanveer - Help me understand, did you ask the Service centre to decrease the turning radius beyond the prescribed limit, and therefore, this resulted in whatever you went through?
Reason i ask is two fold.
1. By improving the turning radius , is this such a drastic improvement?
2. Is it risky to do this or is it just that this service centre didnt do a good job of it
Glad that you could notice the issue and take action.
jkrishnakj is offline   Reply With Quote
Old 14th January 2014, 22:12   #18
tsk1979's Avatar
No. I went to the service center and told them oil is leaking. After 4 days I get my car back with no oil leaking. ZF(the mfr) did an overhaul for 5000, Tata took 1038, and 12% the govt stole. So 6700 rs later, there was no leak.
Little did I know, what kind of trouble I was going to get into.
Brakes Catch Fire / Brake Bed in procedure / Brake Shudder : Solved Indian1979 Technical Stuff 35 4th October 2013 13:42
Early indicator of brake pad failure? tsk1979 Technical Stuff 41 8th December 2009 10:15
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Turbocharger failure in new safari 2.2VTT(Edit: Solved; only a cracked rubber tubing) DDDHRUV Technical Stuff 104 11th May 2008 22:36
Brake failure in Indica V2 (2001) KVS Technical Stuff 9 11th October 2007 21:27
