| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | I bought a free-flow for my Zen(carb) from auto-mech... there are a few problems that i am facing: 1. The exhaust-part that just follows the manifold is much lower than the stock one, reducing the clearance by almost an inch! it'll be the first thing to hit any obstacle getting under my car. will it break easily.... do you think i should get a new unit to replace this (though it'll be very cumbersome)? 2. It almost touches a body part (about 4-5mm from it) just below the gear lever. So whenever it vibrates, the vibrations are transmitted to the body.... will filling silicone gel in the gap solve my problem? 3. a part of the intake manifold touched the "cross"(well thats what the mechanics called it) that it passes through so i got abt 3mm of it cut, to enlarge the hole.... hope it wasn't a bad move!? PLEASE HELP....
__________________ Motorsport is the only 'REAL' sport.... all others are just Games! Aalap Patel '97 Zen '88 RD350 Last edited by dustDevil : 28th June 2006 at 22:13. |
| | #2 (permalink) |
| BHPian | I Believe the problem is of installation, I agree it reduces the clearance, but it must not by hitting road so often though on indian roads you can expect anything, there are some ways out.. first is checking the installation from bottom , you got to check in garage where they have car lifts, about Filling I think silicon gel may melt due to exhaust heat that 3 mm is the not worry issue, one jugaad i can suggest here to raise up ur car by adding 1"- 2" thick rubber to suspension.. Cheers Wadhwa Ajay
__________________ To live is not just to survive, but to thrive with Passion, Compassion, some Humor & your own Style ! |
| | #5 (permalink) |
| BHPian | No, nt exactly the cross-member....... cross-member is the part on which the steering rack n' pinion is bolted.... right!? The part i cut is in the front, just below the radiator. i'll post a pic soon...
__________________ Motorsport is the only 'REAL' sport.... all others are just Games! Aalap Patel '97 Zen '88 RD350 |
| | #7 (permalink) | |
| Senior - BHPian Join Date: May 2006 Location: Chennai..the city of cars..
| Quote:
__________________ RWD Rocks! | |
| | #8 (permalink) |
| BHPian | okay...... so u cud say, i enlarged the hole in the cross-member (through which the exhaust pipe passes) by about 3mm..... is it gonna have any adverse effects?
__________________ Motorsport is the only 'REAL' sport.... all others are just Games! Aalap Patel '97 Zen '88 RD350 Last edited by dustDevil : 29th June 2006 at 16:06. |
| | #9 (permalink) |
| BHPian | 1. This is the pic of the first cut: taken frm under the car.... blue thing is the manifold: http://imageshack.in/img1/index.php/...thumbnail=true 2.This is the second cut: pic taken from above... [COLOR=#22229c]http://imageshack.in/img1/index.php/...thumbnail=true[/COLOR] I'm still to give it a bit of finishing and apply paint to prevent rusting! should i use an epoxy paint or oil-paint should do?
« Whats This- Pipes on a BEST bus??
Trouble codes diagnosis for all current Suzuki cars - Link fixed »
| Thread Tools | |
Similar Threads | ||||
| Free Flow for esteem | pramodkumar | Modifications & Accessories | 6 | 20th December 2006 05:00 |
| Free Flow for esteem | pramodkumar | Modifications & Accessories | 1 | 19th December 2006 16:15 |
| Free Flow for OHC 1.3 | ~ H O N D A ~ | Modifications & Accessories | 17 | 11th September 2006 20:28 |
| Free Flow 4 Zen !!! | khaadu75 | Modifications & Accessories | 3 | 20th June 2006 19:59 |
| What is a Free flow? | Samurai | Technical Stuff | 1 | 4th April 2005 12:43 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
