Old 15th January 2014, 13:44   #1
sr_1445's Avatar
Question The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted?
So we all know that Atmospheric Pressure at sea level is 14.7 PSI. I do know that we fill our car's tyres in relation to atmospheric pressure.
So my question is :
When I fill my car's tyres at 33PSI , is it 14.7 PSI +18.3 PSI(Atmospheric + Actual(?) Tyre Pressure) or is it 33PSI above atmospheric pressure?
Thanks.
sr_1445 is offline   (1) Thanks Reply With Quote
Old 15th January 2014, 23:04   #2
aah78's Avatar
Thanked: 1,746 Times
Arrow re: The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted?
Your pressure gauge is calibrated to read 0 psi at sea level / 14.7psi atmospheric pressure.
So the absolute pressure in your tyres will be 33psi + 14.7psi.
(Ignoring the effects of temperature here).
aah78 is offline   (10) Thanks Reply With Quote
Old 16th January 2014, 11:05   #3
dhanushs's Avatar
Thanked: 4,504 Times
Default re: The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted?
So my question is :
The drop in atmospheric pressure is also one of the reasons that the pressure in your tyres increase as you climb to higher altitudes. Basically, the number of molecules of air remain the same, but the effective pressure and its effects on driving change as you climb up and air gets thinner.
dhanushs is offline   (7) Thanks Reply With Quote
What is your Actual Fuel Efficiency? normally_crazy The Indian Car Scene 5138 1st July 2018 18:03
What was your car's actual resale? yeis What Car? 255 27th July 2017 14:22
Tyre Size and the actual meaning behind it dhananjay Tyre & Alloy wheel Section 1 24th August 2006 11:06
