| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Jan 2006 Location: Bangalore
| Any car when accelerated at low gears increases speed upto a certain point, though the RPM of the engine will increase even beyond. In other words, while accelerating at low gears, speedometer stops increasing beyond a certain point, whereas the tachometer continues to increase. My question is, where is this extra revolution of the engine (RPM) absorbed? The natural answer is, it must result in clutch slippage. Does it? If so, it may result in unnecessary wear and tear of clutch liners every time we over-rev the engine.
__________________ Quench my thirst with gasoline --- Fuel, by Metallica |
| | #3 (permalink) | |
| BHPian | Quote:
__________________ Its not the age,Its the mileage | |
| | #4 (permalink) | |
| BHPian | Quote:
on the other hand if ur question is about rpm increase in each gear then ur above observation is right as this is entirely dependent on the gear ratios. tall and short design.
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN | |
| | #5 (permalink) |
| Thanks for your replies shan2nu, humyum and 2fast4u, but i feel I must clarify my question a bit more. 2fast4u, i think you got my question right. specifically, what in the gear's design gives rise to the following symptom? 1st gear - no matter how high the rpm goes (2000 or 3000) my speed can never go above 20 kmph (which has been reached at 1500 rpm itself!). So in effect the relation between rpm and speed is non linear, that is, beyond a point the revs continue to rise but the car is already going as fast as it can in that gear (maybe in the range when the engine is whining and the tacho is close to redlining?) and so will not go any faster. My question pertains specifically to this point. If the relation between rpm and speed IS non linear, then, are some rpms being wasted? OR rather, if the increased rpms do not contribute to increased speed beyond a point, then what are those rpms doing? where are they getting lost before transferring their rotation to the gearbox/driveshaft? Kindly let me know if I need to clarify my question any further.
| | #6 (permalink) |
| BHPian | zen-ith i understand what u are trying to say.The problem that u are staying that in 1st gear the speedo reaches 20kmph at 1500 rpm only but then the rpm keeps on increasing without any increase in speed.The car with a good clutch will reach max rpm and max speed in that gear at the same time.There will be no visible loss of rpm. The flywheel rototes the clutch and the pressure plate are in between and the gearbox on the other side.When u release the clutch pedal the flyhwheel tranfers the power to the clutch plate and the pressure plate pushes it against the flywheel.From the clutch plate power is tranfered to the gearbox.So if the cluch plate is worn out is worn out it will rub against the flywheel but not rotate at the same speed as the flywheel so there is rpm loss there and thus the gearbox wont rotate as fast as the flywheel.If the pressure plate is worn out it wont push the clutch plate onto the flywheel with enough pressure due to which again there will be rpm loss
__________________ Its not the age,Its the mileage Last edited by humyum : 4th July 2006 at 20:09. |
| | #7 (permalink) |
| Distinguished - BHPian ![]() | What those extra rpms are doing is, screw up your clutch even more. Your clutch has lost it's ability to hold onto to the flywheel at high rpms. On a normal car, the clutch (when engaged) should rotate at the same rpm as the flywheel. This isn't happening in your case, the flywheel is rotating way faster than your clutch plate. Your clutch plate rotates wrt transmission and the flywheel rotates wrt engine speed. This is causing the engine rpm to increase without increase in vehicle speed. I suggest you log onto howstuffworks.com and read what they have to say about clutches and clutch slip. http://auto.howstuffworks.com/clutch.htm Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE Last edited by Shan2nu : 4th July 2006 at 20:11. |
| | #8 (permalink) |
| OK, i agree humyum, but even in a perfectly good car, i have noticed this non linearity. Using the same 1st gear example, I find that the increase in speed (say from 10 kph to 15 kph) for a certain rpm increase (say 1500 rpm to 2000 rpm) is much greater than the increase in speed when pushed from 3000 rpm to 4000 rpm (the speed may increase from 20 kph to 25 kph, at the most, though the revs have increased by 1000 rpms, as against 500 rpms in the first case). In other words, the increase in speed per unit increase in rpm is not a constant across all ranges of the rpm curve. I somehow have a feeling that this non linearity DOES exist, even if the clutch has no problem. Which is why, when we plot a graph of rpm versus speed, we find that the rising slopy curve eventually flattens off at the top right corner. Maybe I am mistaken. I am sorry if I am hammering the same misconception using different words.
| | #9 (permalink) |
| Ok, thanks Shan2nu and humyum. I cleared my misconception now. My understanding was wrong. Further proof is available in Table 1: Road speed at various rpm in each gear of a '94 Harley big twin on this page, where the rpm and the speed appear to be pretty linear. I guess I was confusing the Torque Vs RPM curve, which is an entirely different issue altogether. Thanks and sorry.
| Thread Tools | |
Similar Threads | ||||
| 5.5 lac budget. Best in-class acceleration and handling? | senthildsk | Sedans | 57 | 5th August 2006 23:55 |
| santro acceleration | nirola | Technical Stuff | 4 | 4th March 2006 05:05 |
| Acceleration List - Worlds Quickest Cars | Stratos | The International Automotive Scene | 13 | 31st January 2006 17:13 |
| Autocar goofs-up acceleration figures...twice in a row? | Shan2nu | The Indian Car Scene!! | 19 | 6th December 2005 12:26 |
| zen acceleration problem | hellspawn | Technical Stuff | 3 | 10th September 2005 11:15 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
