Old 9th February 2014, 20:26   #1
SS-Traveller's Avatar
Thanked: 11,630 Times
Default Technology @ Auto Expo 2014
A number of car makers take great pains to showcase the technology that runs their cars. This was so at AETMS 2014 as well. Yet, the effort largely goes unnoticed and unacknowledged, perhaps because these are displays that are somewhat beyond the comprehension of general visitors as well as the automotive media. Here, therefore, is a look at some of the engines, gearboxes and other mechanicals displayed at the Auto Expo 2014, with some explanations and interpretations.
Unfortunately, I had not carried a good camera to the Auto Expo, since this was an unplanned visit, and had to make do with using my cellphone. Apologies in advance for the poor quality of photographs. Distinguished BHPian Sutripta accompanied me there. Certain technical questions posed to the people manning the stalls went unanswered because of the absence of engineers / specialists, and certain answers by the marketing team members were hilarious, such as...
...discovered this sign for the Mahindra Mojo there - please take a look at the part circled in red.
What does SI mean here?
Sir, it is a single inline engine.
Duh...
I next discover the SI crop up again at the sign for the Dream Yuga. Let's find out...
SI means spark ignition.
Really, and diesels are called CI engines?
Right. How about if SI stands for 'stratified injection'?
I hope this makes all you bike fans go .
SS-Traveller is offline   (6) Thanks Reply With Quote
Old 9th February 2014, 21:30   #2
Default Re: Technology @ Auto Expo 2014
Volkswagen
On display at the Volkswagen stall was the famed (and much maligned) 7-speed DSG gearbox. How compact the actual unit is, can only be seen to be believed. It weighs in at 70 kg, and can handle upto 250 N-m of torque. Given the huge investment over the years that VW has made in developing the DSG 'box, it is not surprising that they are one of the few manufacturers that have decided to stay away from Magneti Marelli's AMT bandwagon.
Quick conversation with a gentleman in a suit and tie:
- What is the current status of this gearbox's Mechatronic unit failures?
- It's been sorted out. There are no problems with this gearbox.
Users believers. At least the VW guy didn't tell us that there have been NO problems with this 'box!
Also on display was a cutaway of VW's TDI engine. It is interesting to observe how the turbocharger and the emissions control attachments (catcon and DPF) have been integrated into the exhaust manifold, while on the inlet manifold side sits the water-cooled intercooler, which has been integrated into the inlet manifold. This of course helps to make the powerplant so much more compact and lightweight, but makes for higher repair costs in case of failures!
In our opinion, the intercooler being water-cooled leaves an Achilles' heel for the engine under Indian service conditions. We are not finicky about coolant quality and change intervals, and owners / drivers / FNGs are known to add plain tap water (usually alkaline / hard water) to top up the radiator. This can corrode the intercooler, leading to coolant / water ingress into the engine, with predictable results.
SS-Traveller is offline   (15) Thanks Reply With Quote
Old 9th February 2014, 22:11   #3
Nissan
The K9K 1.5L dCi engine and CVT gearbox were on display at the Nissan stall. The engine by itself is a conventional common-rail diesel unit, quite robustly built, which of course explains its popularity as the second most used small common rail diesel in the Indian market.
Neat and unusual arrangement of the common rail and supply lines to individual injectors.
The design of the CVT and my first view of its belt and pulleys was a revelation.
The huge amount of heat generated during CVT operation needs to be dispersed quickly, and a specially designed fan is evident here.
SS-Traveller is offline   (13) Thanks Reply With Quote
Old 9th February 2014, 22:42   #4
Isuzu
Isuzu had displayed their 3.0L diesel engine with variable geometry system (VGS) turbochager, along with the (huge) gearbox, which powers the Mu-7 SUV (the D-Max is powered by a 2.5L unit).
The company calls itself the "Diesel Engine Experts". And the design and construction of the engine doesn't leave much doubt about that.
It is a twin-cam 4-valves-per-cylinder unit, and from what we could figure out, it also appears to have variable valve timing.
SS-Traveller is offline   (12) Thanks Reply With Quote
Old 9th February 2014, 23:30   #5
Ford
We were overjoyed when we found a cutaway model of the 1.0L EcoBoost engine on display at the Ford stall. And quite a miniature engine this one is (apparently as large as an A4 sheet of paper!).
This is a 3-cylinder engine without balancer shafts - the balancing is reportedly achieved by running a deliberately unbalanced flywheel (no balancer shafts, which sap engine power). We could not figure out how this would be sufficient to achieve balance front-to-back.
Another interesting feature of this engine is the timing belt (not chain), which runs immersed in the engine oil itself. A belt is expected to be made of materials that should degrade on exposure to oil. We therefore wanted to find out what the timing belt was made of, that made it compatible with all types of engine oils. Or is it that the EcoBoost engine uses synthetic oil for engine lubrication, and the belt material is somehow compatible with synthetic oils? If the latter is the case, I dread to think what a top-up with mineral oil (again, the typical Indian chalta hai scenario when it comes to vehicle maintenance) would do to the timing belt.
The pistons have minimal skirt to make them lighter and more energy-efficient. Notice that the cylinder head and exhaust manifold are not separate, but a single casting, on which the turbocharger is bolted on. This, along with a cast iron cylinder block (as opposed to the all-aluminium engines that are considered to be 'modern'), helps to achieve warm-up and optimum operating temperatures much quicker, thereby improving fuel efficiency. The weight gained by using cast iron is far less disadvantageous than the thermal efficiency gained by using it.
Of course, Ford did not have any technical specialists at their stall either. A gentleman with a ponytail politely asked us to get in touch with Genesis, their media representatives, to have our questions answered. If we have to depend on media and PR people to have our technical queries answered, I suppose Ford would also use advertising gurus to service & troubleshoot our vehicles!
SS-Traveller is offline   (14) Thanks Reply With Quote
Old 10th February 2014, 00:00   #6
Eicher
The surprise of the day was at the Eicher stall. Trucks? Naah, not interested... goes many a visitor and journalist. So we found ourselves in an almost deserted section of the Auto Expo, where Eicher had taken up a large area to showcase their commercial vehicles, engines and transmissions. And wonder of wonders, there were a number of knowledgeable and enthusiastic people there to talk to and have questions answered.
Eicher's 4-cylinder and 6-cylinder DI and common rail diesel truck engines were on display, along with cutaways of a gearbox and differential.
For those who are interested, it would be enlightening to note (as it was for me) how the camshaft is driven in this engine, as can be visualized in the photograph below.
SS-Traveller is offline   (21) Thanks Reply With Quote
Old 10th February 2014, 11:20   #7
mobike008's Avatar
Thanked: 8,319 Times
Note from Mod : Thread moved to Auto Expo 2014 section. Thanks for sharing !!
mobike008 is offline   (1) Thanks Reply With Quote
Old 10th February 2014, 12:18   #8
mallumowgli's Avatar
Thanked: 760 Times
Lovely thread. Appreciate the effort. Hope you have more to offer
That was wonderful - able to visualise well
(Wish you had a better camera - few out of focus pics are a little painful to the eye)
mallumowgli is offline   (1) Thanks Reply With Quote
Old 10th February 2014, 14:36   #9
Thanked: 65 Times
Thanks a lot for sharing. I am learning quite a bit today.
Wish they had some electronics concepts also, like google driver less cars tech and safety mechanisms etc.
niv26 is offline   (1) Thanks Reply With Quote
Old 10th February 2014, 15:40   #10
avisidhu's Avatar
Thanked: 522 Times
Wonderful report, thanks for sharing. It's such initiatives that set team BHP apart from the rest.
So mechanicals aside, was there anything else in terms of automotive tech which takes things to the next level? I guess AMT and arrival of petrol turbo engines of smaller displacement would be ones, it would be interesting to know of more such trends.
avisidhu is offline   (1) Thanks Reply With Quote
Old 10th February 2014, 20:16   #11
mints21's Avatar
Thanked: 1,271 Times
All the pictures taken by SS Traveller are taken with exact precision. Not a single picture is painful for the eyes. Taking such pictures in a large gathering with so many focus lights is not an easy task.
I appreciate the efforts put in by SS traveller to come out with such nice thread with good pictures which sets our forum apart.
Thanks SS traveller for coming up with this thread which is unique in many ways and offers a lot of insight to the technology that drives us.
mints21 is offline   (2) Thanks Reply With Quote
Old 10th February 2014, 22:05   #12
Toyota
An interesting observation by Sutripta, that many wouldn't have noticed.
Here are the specifications of the GT86 on display at Toyota's stall. Clearly states that it is an inline four-cylinder engine.
Now look at the logo on the front quarter panel of the car itself. Shows a symbol of something that looks like a flat engine, or boxer engine.
Name:  gt86 logo1.jpg
Wonder why.
The race-prepared Etios had this interesting little switch sticking out at the lower edge of the front windscreen. It's an external battery cutoff switch, suitably labelled! Apparently a legal requirement for vehicles prepared for racing.
SS-Traveller is offline   (4) Thanks Reply With Quote
Old 10th February 2014, 23:09   #13
audioholic's Avatar
Thanked: 6,144 Times
Wonderful compilation. Did make me learn and also get to know some of the detailed or smaller yet significant aspects. Would love to read more of such significant info.
The info about the ecoboost is quite surprising. Firstly, I assumed that timing chains were more reliable and fail proof compared to belt. Given the amount of power that is squeezed out of the ecoboost, is the belt really a good idea?(I am Not any professional to claim its a bad idea though)
audioholic is offline   (1) Thanks Reply With Quote
Old 10th February 2014, 23:16   #14
Thanked: 9,017 Times
Great info. Trust the both of you to bring the technology into focus! Glad you did, many thanks!
By the way on the intercooler; I share your sentiment. Having said that, if you need to add water/cooling liquid, there is a problem already!
On the 3-cilinder balancing act; not sure, but I suspect that the fact it has such a short crankcase has something to do with the ability to only use an unbalanced flywheel.
Jeroen
Jeroen is offline   (1) Thanks Reply With Quote
Old 11th February 2014, 09:41   #15
thoma's Avatar
Thanked: 1,112 Times
I am guessing that the specification was either wrongly or loosely* mentioned as inline. The specifications from Toyota UK site mentions it as a flat boxer engine.
Name:  GT86 2.0 1 D4S boxer.jpg
* I didn't completely understand the 2nd para of the wiki explanation ["Another widely used form of flat engine consists of a straight engine with two, three, four or more cylinders canted 90 degrees into the horizontal plane, however this is not generally considered significantly different from other straight engines"]
thoma is online now   (1) Thanks Reply With Quote
Bajaj Auto @ Auto Expo 2014 parrys Motorbikes 33 19th February 2014 17:15
Facelifted Chevy Beat. EDIT: Revealed @ Auto Expo 2014 MAS The Indian Car Scene 71 18th February 2014 01:07
Lohia Auto @ Auto Expo 2014 Aditya Commercial Vehicles 14 10th February 2014 16:39
Wheelosphere at The Hindu Chennai Auto Expo The Hindu Chennai Auto Expo 2010 udayjani The Indian Car Scene 3 10th October 2010 16:54
