Thread Tools
Old 15th March 2007, 14:21   #16 (permalink)
Team-BHP Moderator
Technocrat's Avatar
Vid even I face some jerks but they are not jolts which I belive primarily happens when you accelarate & while accelarting the aircon starts then I do get a jerk but thats just one & I have now kinda got used to it.
__________________
180, 225, 150, ??? -> 159?
Old 15th March 2007, 17:52   #17 (permalink)
Knight Rider's Avatar
Okay, even I had the same problem, The Dealer told me that it was a manufacturing defect and the entire clutch assembly was changed, The problem started showing up again.
However after upgrading to K&N and headers, I do not face this issue anymore, Why dont you also do the same -
__________________
Wear your seatbelt (I will vouch for it)
Knight Rider is offline   Reply With Quote
Old 15th March 2007, 18:37   #18 (permalink)
vid6639's Avatar
lol... knight rider. I am trying to get the problem fixed within warranty. If i put headers and k&n i dont think ill be under warranty.
Maybe I can try the stock k&n filter. lets see.
Any other suggestions? has anyone got it solved from MUL.
maybe experts Viper or psycho can help us out as to what it could be.
MUL guys cant figure it out.
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Old 15th March 2007, 20:47   #19 (permalink)
rjstyles69's Avatar
Yuppp !! Guess the last resort is only to go according to knight Rider's suggestion headers and a conical K&N.
@vid6639, problem persists with every single Alto I guess. My bro's Alto has this problem and is very evident. I used to use the car initially and felt the same jerk with the AC switched on.Checked a couple of times with MUL and no joy.
After reading this thread ,drove a colleagues Alto LXI and heck it also has the same problem.So let the experts speak and see what they have to say.
__________________
rjstyles
You never really learn to SWEAR until you learn to DRIVE.
rjstyles69 is online now   Reply With Quote
Old 15th March 2007, 21:21   #20 (permalink)
vid6639's Avatar
Yeah so far I have gathered that the cut off is very sharp. So I'm guessing the idle air control IAC valve gets activated. Now with the AC on the deceleration i.e. engine braking is not linear you can feel on off feeling during decelaration.
This should be set in the ECU to get better mileage i.e. to have a sharp cut off. But there is a lag in the cut off.
For some reason it acts funny only when the AC load is present. Without the AC load its not as bad. It doesnt give that bad a jerk but you feel the sharp cut off.
Now i need to see a solution for this. I'm sure there is a workaround/fix for this.
Elf, is this problem still there with your alto? any workaround you got?
__________________
(o.o)
( X )
Old 20th March 2007, 05:23   #21 (permalink)
mithun's Avatar
So is there any solution for the sluggishness of the Alto when the AC is ON ?
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 20th March 2007, 05:48   #22 (permalink)
speedzak's Avatar
Talking Alto is an 800!!
1. You can try realigning the clutch. It does have an effect.
2. Gearbox realignment.
3. Bigger/better air filter.
4. Freeflow. Preferably with custom manifold and headers.
5. Switch off the AC!!
6. Get a Baleno!!!! Believe me, it doesn't jerk with AC on.
__________________
If you want to see a rainbow you must first sit through the rain.
(Hungarian Proverb)
speedzak is online now   Reply With Quote
Old 26th March 2007, 10:02   #23 (permalink)
vid6639's Avatar
Just checked mileage. 13.5 with AC on. There has to be something wrong as the car has never crossed this figure. This time there was a highway run as well as city driving with no traffic since i went to work at 7am and came back at 4pm.
I generally get 13-13.5 only. After clutch change and service. The jerking must be affecting the mileage.
__________________
(o.o)
( X )
Old 26th March 2007, 10:25   #24 (permalink)
abhibh's Avatar
Just get a Triphase...
__________________
For every idiot there is an equal and opposite gender idiot. Singles are people with incomparable intelligence!
abhibh is online now   Reply With Quote
Old 26th March 2007, 10:52   #25 (permalink)
elf
elf's Avatar
Got the same problem with wifey's Alto (800cc). When the car's cold, absolutely no problems whatsoever. She starts great, idles smooth & pulls away like a cat on cocaine.
Once she heats up she gets cranky. In serious heat with the air-conditioning on, I get clutch judder like you can't believe.
The clutch was allegedly replaced under warranty at about 5k by Maruti Udyog. No problem for some time, issue resurfaced again after about a thousand odd kilometers. Their response: "Alto aisa hi banta hai". @%^%#$#^$#
Am not going back to those A.S.S.es again.
Me got a theory, albeit unproven yet. Maybe it's because of some oil which drips onto the clutch (a/c or engine), causing it to judder like it's got epileptic fits. This only happens with the air-conditioning on. Switch it off, & she picks again like the aforementioned narcotic cat.
Experts, any input?
elf is offline   Reply With Quote
Old 26th March 2007, 10:58   #26 (permalink)
vid6639's Avatar
yeah exactly without the AC load she does give decent pickup. the minute you press the AC button thats it your driving a bucking bronco.
I'm not sure it's to do with the clutch. It doesnt happen only when you engage clutch only during acceleration or deceleration i.e. backing off gas.
Elf, you remember we discussed this in the throttle body thread:
http://www.team-bhp.com/forum/techni...tml#post299057 (RPM Surges-Throttle Body Cleaning)
I've threatened MUL to change my car if it's not fixed.
__________________
(o.o)
( X )
Old 26th March 2007, 12:00   #27 (permalink)
k36
k36's Avatar
Default Even in Swift
I face jerking while accelerating and decelerating with AC on even in my Swift VXi, but ONLY at low (below 1750) RPM. No problems at higher RPM.
My Theory: Probably at low RPM the engines do not product enough torque to drive both AC and the car well enough and hence the ECU tries to juggle between the two.
I've made a habit of driving at one gear lower in city traffic when AC is on, specially in summer, keeping RPM in 1750-2500 range and this works out fine. No jerks at these engine speeds. This should work even in Alto.
Any other Swift owners facing this?
__________________
k36
k36 is offline   Reply With Quote
Old 26th March 2007, 12:17   #28 (permalink)
vid6639's Avatar
k36 low rpm is pretty standard. since the engine cannot handle the AC load and drive the wheels.
this problem is midrange while accelerating or coming down the revs.
I dont know rpm as alto has no tacho.
__________________
(o.o)
( X )
Old 26th March 2007, 12:46   #29 (permalink)
Team-BHP Moderator
Technocrat's Avatar
Guys arent we expectinga bit too much from an entry level car ?
__________________
Old 26th March 2007, 12:53   #30 (permalink)
vid6639's Avatar
Nope it is clearly a problem with the car. My 6 year 800 AC model didn't have the problem.
My friend's alto doesnt have it. Why should the clutch plate of a car need replacement after 8K kms.
Service engineers say this will solve the jerking. but again after few hundres kms the problem resurfaces.
The car costs 3.5L of hard earned money. It is expected that the car should be trouble free.
How can a company sell a car with such a bad jerking problem.
__________________
(o.o)
( X )
Thread Tools
Accessories for my new ALTO sabret00the Modifications & Accessories 24 1st January 2008 11:14
Adding Aircon to Non-AC Matiz. Su-47 Modifications & Accessories 4 16th October 2007 19:48
Where's the Alto? SLK The Indian Car Scene!! 15 6th October 2007 08:27
Aircon and engine temperature- Inverse relation abhi182 Technical Stuff 9 4th October 2006 13:26
Icing a Alto ? abhibh Ask the Gurus 19 1st May 2006 23:46
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
