Old 22nd June 2007, 13:01   #76
akroy's Avatar
Thanked: 29 Times
Although there were jerks initially for me but after the long trip (like the Kolkata trip where AC was on for say 8-9 hours), the jerks and all subsided....Even Lokesh (Service Engineer of MASS) told me about it after driving 5 km in AC....
As Techno also said, I puton K&N very early and that might help as well..
Abhi
akroy is offline   Reply With Quote
Old 23rd September 2007, 03:26   #77
ScarySkulls's Avatar
Thanked: 19 Times
The jerks everyone is mentioning, is it the same one I get.
I.E. while driving in city traffic in 2nd or 3rd gear with A/C on, the moment you leave the gas pedal, there is a very sharp engine braking happening, which eases off suddenly as soon as RPM's reach very low to near Idle levels>?
Also, sometimes I get these HORRIBLE shudders while moving from rest in frist gear at moderate throttle. Whole car, gearstick etc shudder like anything. This happens like 2 times out of 10.
Other times, even if I leave the clutch gradually without even touching the throttle, she will start moving smoothly.....
ScarySkulls is offline   Reply With Quote
Old 23rd September 2007, 10:15   #78
Vid6639's Avatar
Thanked: 20,986 Times
Man, looks like majority of teh Altos have this problem. I have had a clutch replacement for transmission whine at 3000kms on the odo.
Both the problems i.e. jerk with AC on when backing off gas and the shudder only when engine cold i.e. 2/10 times also happen with me as well.
Looks like quite a few altos have this problem.
Old 4th March 2008, 14:11   #79
abhibh's Avatar
Thanked: 34 Times
Summers are here and now i use AC with full blow. Lately from past 3 - 4 days i have been facing a problem regarding pickup with AC on.
If i am in 3rd gear and cruising @30 - 35 and press the accelerator the car picks up slowly. Now i understand it will pick up slowly but as soon as it hits the speed of 45 - 50 it jumps like anything. Pickup increases and it feels like AC is not on. But the problem is lot of times i have to break down to avoid rear ending someone. The sudden increase in pickup is like in diesel cars you get the feel of TURBO kicking in suddenly.
The car in picture is 800CC Alto.
http://www.team-bhp.com/forum/techni...ted-issue.html (AC related issue)
I don't know if this is a common problem but never faced this problem from past 7 years and it bugging since past 3 - 4 days only.
Maybe AC needs servicing ?
Old 4th March 2008, 14:29   #80
Vid6639's Avatar
Yup pretty standard issue in Alto. After a particular rpm the car shoots off. The jerks in my car has reduced after putting in the K&N stock replacement filter. The car is much more driveable and I can hold on to higher gear longer and don't need to downshift.
Old 4th March 2008, 14:31   #81
benbsb29's Avatar
Thanked: 4,276 Times
Vid, Abhi (akroy) also says he finds the issue has reduced after switching to a K&N filter on his Alto.
benbsb29 is online now   Reply With Quote
Old 4th March 2008, 14:49   #82
Technocrat's Avatar
Thanked: 2,589 Times
ben, its the same in my Alto too i.e. the car drives much better with the K&N
Old 4th March 2008, 15:57   #83
arpandiv's Avatar
Thanked: 27 Times
how much is the Alto K&N stock replacement filter for ?
I have had this jerking problem getting the fuel filter(the one which is located inside the tank and the fuel pump),injectors,TB cleaned.Should see the result soon.
arpandiv is offline   Reply With Quote
Old 4th March 2008, 16:26   #84
Technocrat's Avatar
Arpan with the 1.1 there should not be any jerking at all with ac.
The K&N costs Rs. 2990
Old 4th March 2008, 18:16   #85
NetfreakBombay's Avatar
Thanked: 402 Times
Does installation of K&N affect warranty?
Old 4th March 2008, 18:33   #86
akroy's Avatar
Thanked: 29 Times
No, K&N Stock Replacement Filter doesnt affect Warranty.
Abhi
Old 14th March 2008, 22:13   #87
svsantosh's Avatar
Thanked: 1,443 Times
Default LPG ALto + AC = Emergency Brakes
If this sounds funny - In case of a emergency, I just switch my LPG On and AC Full Blast, Voila and the car stops right there in the middle of the road.
I then took a risk and got the Mandovi Motors marketed Turbo Fan thing inside the Air filter pipe and VOILA... there is considerable difference in the pickup,still to check onthe FE.
I will update FE once I finish the trial runs.
svsantosh is offline   Reply With Quote
Old 30th April 2008, 11:58   #88
cyclops's Avatar
Thanked: 9 Times
Default Clicking Noise.
Okay, the power loss and the jerks seem to be a universal problem with alto's i guess.. even i face em pretty often in my 3 month old alto..
Off late, i have observed two things,
1. The car makes a loud screeching noise when i start the vehicle for the first time, and also screeches when I switch on the AC. I guess its a problem with the belt.
2. There is a very prominent "click" sound whenever I switch on the AC and the engine noise increases substantially, i'll say by 25 percent.
I will try to visit the service station asap, but I am a bit worried bout the problem, any solutions?
cyclops is offline   Reply With Quote
Old 30th April 2008, 14:30   #89
Rahulk76's Avatar
Thanked: 204 Times
My Wifes new alto less than 1k on odo also has this same annoying jerk... man this thing really brakes with ac on and foot off the gas pedal...
I need to buy this stock replacement airfilter for alto in pune.. Can anyone guide me on this..
Rahulk76 is offline   Reply With Quote
Old 30th April 2008, 14:38   #90
cyclops's Avatar
Thanked: 9 Times
even i am looking for a stock replacement air filter for my alto..
any suggestions? just a thought, looks like many of us are looking for a filter, why not get a bulk discount? say what?
Car Aircon: Unicool Car Aircon, Ghatkopar (W) parsh Mumbai 26 18th August 2017 00:47
A/C and fuel economy & How to use aircon optimally. Lukeskywalker Technical Stuff 115 15th June 2014 12:09
AirCon Servicing on an Alto amit_mechengg Technical Stuff 44 22nd February 2010 13:40
Adding Aircon to Non-AC Matiz. Su-47 Modifications & Accessories 4 16th October 2007 19:48
Aircon and engine temperature- Inverse relation abhi182 Technical Stuff 9 4th October 2006 13:26
