Thread Tools
Old 3rd July 2006, 19:13   #1 (permalink)
ess_a's Avatar
Unhappy Alto and the AirCon
hi guys.. i have an alto lx... one thing that has been really troubling me this summer is its ride with the AC on... mostly in the 2nd (sometimes even in the 3rd) gear, when i brake hard (without pressing the clutch), the car gives a big jolt.. even a sudden release of accelerator jerks the car..
its not that the car speed falls below the min. kph for that particular gear... even braking from 25kph to say 15 kph in the 2nd gear, the car gives a jolt.. but if i switch off the AC, the problem disappears completely... Also if i simultaneously press the clutch while braking (with AC on), there is NO jolt..
the maruti service station guy said that this happens with almost all cars due to a sudden decrease in RPM.. but i'm not too convinced as i recently drove the Xeta with NO such problem...
Please help me out... coz summers are at their peak and AC is a necessity... but to avoid the jerks i dont want to unnecessarily wear out my clutch plates..
thanx
ess_a is offline   Reply With Quote
Old 3rd July 2006, 20:23   #2 (permalink)
Team-BHP Moderator
Jaggu's Avatar
check idle rpm setting, with ac on and off.. clutch seetings also...
not to scare you or anything but my colleagues alto had the same problem, which they diagnized as clutch replaced it at 5 k kms, ran ok for couple of months and now again its re surfacing..
find a good garage and try replicating the problem with the mechanic riding along is the best suggestion.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 3rd July 2006, 21:54   #3 (permalink)
ess_a's Avatar
okay jaggu.. will do that, but maybe at a diffrnt service station..
Old 4th July 2006, 09:23   #4 (permalink)
revharder's Avatar
get your clutch checked thoroughly.
and avoid resting left foot on that pedal!
revharder is offline   Reply With Quote
Old 5th July 2006, 12:59   #5 (permalink)
Team-BHP Moderator
Technocrat's Avatar
I dont think there is any problem with the car, this quite expectedI mean on suddent braking w\o using clutch the engines rpm drops drastically & to be able to pick up from such a low rpm ins 2nd or 3rd gear teh engine would need all of it power which might not be available to it if the a\c is running.
__________________
180, 225, 150, ??? -> 159?
Old 5th July 2006, 13:43   #6 (permalink)
Joz
I agree with Jaggu. It could well be a clutch problem. I faced the same trouble some time back - the car used to jerk like crazy for no reason and also had trouble shifting gears. Each time i told the service guys about it, they came up with solutions like getting the belts tightened and what not. For the thrid free service, i blew my top off. Forced them to check the entire clutch assebly. They confirmed it was a manufacturing defect and not driver error. Got it replaced under warranty. Haven't faced the problem after that.
Joz is offline   Reply With Quote
Old 5th July 2006, 18:11   #7 (permalink)
mail4ajo's Avatar
I dont think its a clutch problem. I have a similar issue with my new Alto. The AC seems to be very powerful and while riding with it, releasing the throttle a bit means jerking the car.
I was waiting for the 1st service to ask this question to the service guys.
__________________
*2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135*
mail4ajo is online now   Reply With Quote
Old 6th July 2006, 08:31   #8 (permalink)
akroy's Avatar
It happened to me too when the car was absolutely new. May be the AC was powerful and the new engine was getting toned. But the thing went off after my first long drive before first service and with AC on.
I suggest dont put on the AC so much before first service. Let the engine tune up.
Now it is fine, also when the AC is on and u r in lower gears (or starting at a signal) make sure u put on the gas pedal a little harder than u normally do (simultaneously leave the clutch a little slower). It will not jerk. U will feel a smooth pickup.
Abhi
__________________
2003 Bajaj Caliber115 | 2006 Alto LXi
akroy is offline   Reply With Quote
Old 6th July 2006, 11:00   #9 (permalink)
mail4ajo's Avatar
Abhi
Yes, I have heard a lot of people say this. I am using the AC very less now. Why did they have to bolt such a powerful AC on Alto? It just takes the juices out of the engine while on the highway.
But I love the awesome cooling in Chennai's damn heat. BTW Abhi, what mileage figures you achieve with AC on?
__________________
Old 6th July 2006, 11:31   #10 (permalink)
SLK
SLK's Avatar
I think its something else. Happens to my 800dx (almost same thing as alto lx).
I can't really explain why.. but its normal for this engine to jolt at a particular rpm with a/c on.
Let me tell you the symptom I face..
--going in 2nd gear.. at say about 25km/h.. the moment you release the accelerator even a slight bit .. strong engine braking kicks in.. giving you the jerk.
Its very annoying but.. can't be helped! .. Maruti has put in all it had in this engine!!.. don't ask them for more.
__________________
Č╠╣€€Я$
$£Қ
SLK is offline   Reply With Quote
Old 6th July 2006, 12:21   #11 (permalink)
akroy's Avatar
mail4ajo: Dont blame that AC dude. It is too good when u r on highway under the scrotching sun. I hardly use AC in city (infact i hardly drive in city also in bangalore u dont require AC...)...During my trips to TN, i did put on the AC on highway and it worked well. I always keep it on No.2 with 3-4 for a few minutes initially to cool down. Believe me, it cools down fast and maintains that cool level throughout and all the 4 adults enjoy the fullest when the sun was scrotching outside in places like Krishnagiri, Salem etc.
After all this, the car was nicely running at 90kmph - 110kmph.
Now coming to fuel efficiency:
I used say 50-60% AC during these trips, I got 18.6*, 18.5* etc kmpl (basically 18+). This included hill climbs and high speeds of 120-130kmph with 4 adults and luggage. I maintain an excel sheet of petrol, mileage and variations just for my analysis. If u want more exact figures than i need to refer that to get the exact figures in every refill.
NOTE: Although my car has done 3500km, I have done the second service last week. This small things will become more smooth. I felt a great deal of improvement / smoothness after first service.
I strictly maintained to what mentioned in the Alto guide. I didnt cross speed above 70kmph (although given 100 there) and didnt use for small distances. hardly used AC eventhough blore got quite hot during march. Took the car to longer distances at lower speeds before first service. I took it to GQ only after first service.
__________________
Old 6th July 2006, 12:56   #12 (permalink)
Team-BHP Moderator
Jaggu's Avatar
start with basics, check idle rpm (ac on n off) then clutch settings, dont complicate matters.
if rpm difference is very high when ac on vs ac off, car will jerk with sudden change in rpm when accelerator is not depressed to outset the differnce
__________________
Old 15th March 2007, 06:13   #13 (permalink)
mithun's Avatar
For me it was exactly the opposite of what you've mentioned !!!
When I drive my brother's 2001 Alto which had cloaked about 38,000 KMS with the AC on the 5th gear at speeds of about 80-100 KM/H, I've always felt Alto was quite sluggish and I've to literally stand on the accelerator to stick to that speed !!!
Is it because of any problem associated with the older breeds of Altos or is it specific to my Alto ?
Other than these, there is no other headache with my Alto and the AC is really a chiller.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 15th March 2007, 08:18   #14 (permalink)
vid6639's Avatar
Same problem with my alto. have been harrowing every service centre here. I've taken up the matter with MUL. they changed my entire clutch assembly under warranty at 5K kms.
The problem resurfaced a few kms later. It's very irritating. My friends alto athough doesnt have the problem.
I am still fighting with MUL.
With the AC on the car does jerk very badly when you release accelerator suddenly but it's not like a cutoff jerk it's a jolt. this will also happen if you
release and then immediately press half throttle. it will jolt then again start accelerating. this is not normal at all and a pain in city traffic.
I brought up the matter at the time of delivery and they said it's new hence wont be smooth. they said by 1st service problem will go. Even after that it dint go. Second service they tried to fix it but couldn't.
I got bugged and I wrote a scornful letter to MUL. Solar auto contacted me for fixing the problem. they tried to fix it but said it seems normal.
I have taken it in writing from them that they are not able to diagnose the problem and if it aggrevates they will repair the problem free of charge.
But it's really irritating for me as well as any passenger in the car cause the jerk is really bad.
Does anyone have any contacts in MUL. it seems quite a few altos have this problem. maybe we can get this sorted out from MUL.
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Old 15th March 2007, 08:41   #15 (permalink)
vid6639's Avatar
I have mentioned this problem earlier.
http://www.team-bhp.com/forum/techni...tml#post299057 (RPM Surges-Throttle Body Cleaning)
Currently everything has been checked. sparks, throttle body, valve clearance, ECU has been connected to Tec2 and no error codes found.
__________________
(o.o)
( X )
Thread Tools
Accessories for my new ALTO sabret00the Modifications & Accessories 24 1st January 2008 11:14
Adding Aircon to Non-AC Matiz. Su-47 Modifications & Accessories 4 16th October 2007 19:48
Where's the Alto? SLK The Indian Car Scene!! 15 6th October 2007 08:27
Aircon and engine temperature- Inverse relation abhi182 Technical Stuff 9 4th October 2006 13:26
Icing a Alto ? abhibh Ask the Gurus 19 1st May 2006 23:46
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
