Old 7th July 2006, 15:29   #16
Thanked: 9 Times
Originally Posted by naveendhyani
how much do u think the baleno drive shafts cost??? the car is 4 years old.
How many KMs has it clocked. Thats more important than the time frame.
so long....
varunroy is offline   Reply With Quote
Old 7th July 2006, 15:43   #17
naveendhyani's Avatar
Thanked: 7 Times
car has clocked around 70k, how much is the usual life of the axles?
naveendhyani is offline   Reply With Quote
Old 7th July 2006, 17:28   #18
gave my car for service today, both the axles are gone & two of the four engine mountings are broken. the cost of repairs & service is approx 20k. i m told that the axles cost approx 6k each & mountings 3k each.
Are you sure you havent hit a pothole or a stone at significant speed recently?
The only way engine mountings can break is by some impact, unless they were already defective..
BTW, did you buy the car second hand? If so, its possible that it had been involved in an accident and the engine, transmission, drive train are out of alignment.
nitinbhag is offline   Reply With Quote
Old 7th July 2006, 18:10   #19
suman's Avatar
Thanked: 257 Times
If I remember correctly, you did buy it second hand? This could very well be a possibility!
Old 7th July 2006, 19:19   #20
Thanked: 7 Times
@ nitinbhag : i did buy it as a second hand, how can i check if this had ever been involved in an accident?
Old 7th July 2006, 20:40   #21
elf
elf's Avatar
Thanked: 9 Times
2 broken engine mountings & a busted pair of axles? Wow! Methinks you have bought a vehicle that was involved in an accident & the usual sloppy job has been performed on the repairs by the previous owner before disposing the car quickly. Have you had uneven tyre wear (especially the front) as well?
elf is offline   Reply With Quote
Old 26th November 2006, 21:14   #22
humyum's Avatar
Thanked: 2,502 Times
The axle noise has started on my 800 too.The left side one was replaced around 8000km back and now the right side one is makin a khat khat noise sometimes while takin a full right turn!!it comes once in a while taking a right turn.car has run 67000km.
The sound comes only while turnin to the right(full lock) and then after i turn the steering back to straight it pulls to the right slightly and then everythin is back to normal.
Can i run the car with this axle for another 2 to 3 k?
Old 27th November 2006, 06:46   #23
wolfinstein's Avatar
Axel generally have a fixed life, at some point or the other they need to be changed, But the mounting part is strange. Check for any underside body damage, Rust etc..Its better to have it all taken care of now.
wolfinstein is offline   Reply With Quote
Old 27th November 2006, 09:17   #24
danlalan's Avatar
Thanked: 135 Times
well you could drive the car for another 1500k more with caution, it shouldnt be a problem but you should get it replaced soon...carrying out repairs to your axle will only solve the problem for another few kms. its better to get them replaced which might be a costly affair..but still do get them done.
danlalan is offline   Reply With Quote
Old 27th November 2006, 09:50   #25
sreenivass's Avatar
Default Tire nflation check & lower arms
Do you over inflate tires by any chance ? I was talking to my work shop (FIAT Petra) finding out the right inflation (175/65R14) , the guy tells me its 28 PSI for city and 26 PSI for highway. I was surprised as it was against popular opinion on team BHP (on many threads our members seem to be of the opinion highway inflation has to be higher) and asked him more.
He mentioned this: inflating it to 30/32 PSI would cause damage to lower arms of the suspension/ axle system. So please watch out.
sreenivass is offline   Reply With Quote
Old 26th September 2010, 01:19   #26
9thsphinx's Avatar
Thanked: 467 Times
Anyone know how much would the front driveshaft/axle for an OHC Type 2 go for costwise including parts and labor? I believe my axle's cracked from the front passenger side - car heavily wobbles at 30-40 km/h and constantly pulls to the left if not manually maneuvered otherwise. I observed oil leaks right next to the axle boot.
9thsphinx is offline   Reply With Quote
Old 7th June 2011, 12:58   #27
Thanked: 106 Times
Default Re: Noise from the AXLE
My OHC Vtec is having khat khat sound when moving on turns. The sound has incresed drastically for last 2 days. Can someone tell me the problem and the solution and approx cost. Will also like to know a good workshop in south mumbai to get the job done.
saurabhkum is online now   Reply With Quote
Old 7th June 2011, 13:12   #28
dhanushs's Avatar
Thanked: 4,504 Times
Problem: Bust Drive shaft
Solution: Replace with new
Cost: IIRC, ~6-7k a piece.
Good Workshop: Check the directory section in Mumbai.
@Saurabh: IIRC means If I Remember it Correct.
Old 7th June 2011, 13:17   #29
Thanked: 106 Times
What is IIRC , sorry if question is too basic.
Old 8th August 2011, 21:53   #30
If I remember correctly, its If I Remember Correctly.
kaynmantis is offline   Reply With Quote
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
What do u do when the axle is gone speedsatya Technical Stuff 16 27th March 2009 00:09
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
