Old 4th July 2006, 11:50   #1
naveendhyani's Avatar
Thanked: 7 Times
Default Noise from the AXLE
lately i have noticed that during sharp turns when the steering wheel is fully turned (& sometimes lesser turns but higher speeds) i get a knocking sound from near the axle. the 'khat' khat' sound. what cud this b?
thanx in advance.
naveendhyani is offline   Reply With Quote
Old 4th July 2006, 11:53   #2
Captain Pings's Avatar
is your ride a Maruti 800 ? a clicking (khat-khat-khat!) kind of noise on a turn could be the wheel bearing - most commonly with the front wheels!! rear wheels...hmmm! take it easy on the turns meanwhile!
Captain Pings is offline   Reply With Quote
Old 4th July 2006, 12:13   #3
humyum's Avatar
Thanked: 2,188 Times
Dude its not the wheel bearing its the axle noise.The khat khat noise that u say while taking turns shows that u need an axle change.Although if u change the axle bearing your problem will be solved.It will cost u 1100 to 1200 rs for an axle bearing change and a new axle of an 800 costs 2200 rs for the left side one and the right side one is a little more expensive.I highly recommend u get the whole axle changed asap as this sound will increase over a certain period of time and in sometime it will even start comming while u go straight.Meanwhile take it easy on humps and bad roads.
Old 4th July 2006, 12:39   #4
Rudra Sen's Avatar
Thanked: 4,093 Times
That noise is coming from your drive shaft. Change is the only way. Though some mechanics say that they can re-condition that drive shaft. Suggest don't fall for that.
Old 4th July 2006, 13:27   #5
drifter's Avatar
Thanked: 13 Times
yup your drive shafts (CV joints) have become weak and are ready for replacement.
Drifter
drifter is offline   Reply With Quote
Old 4th July 2006, 13:33   #6
speedsatya's Avatar
Thanked: 706 Times
Originally Posted by humyum
.It will cost u 1100 to 1200 rs for an axle bearing change and a new axle of an 800 costs 2200 rs for the left side one and the right .
dude its a baleno ....no way its gonna be that cheap .
speedsatya is offline   Reply With Quote
Old 4th July 2006, 14:03   #7
humyum's Avatar
oopppss sorry i thought it was an 800.The left drive shaft i replaced in my car cost me 2200 so i can imagine how much a balenos drive shaft will cost.By the way how old is your car?and does this sound come when u turn left or right?If both the drive shafts are gonners than u are looking at some serious expense there.
Old 4th July 2006, 14:11   #8
Thanked: 7 Times
how much do u think the baleno drive shafts cost??? the car is 4 years old.
Old 4th July 2006, 14:59   #9
drifter's Avatar
Thanked: 13 Times
Last when i had checked crdi axles (pair) costs about 25k. Yours should be cheaper.
Drifter
Old 4th July 2006, 15:12   #10
2fast4u's Avatar
its the cv joints or the bush but as long as u dont do any over roading (village roads) it will survive but better to change soon. Dont take sharp turns on the side affecting most.
2fast4u is offline   Reply With Quote
Old 4th July 2006, 19:36   #11
gigy's Avatar
Thanked: 41 Times
such noise can come from front lower arms, if it is obvious in turns it could also be axle. you are heading for a front end overhaul. bearing dont make this noise. bearing makes humming sound which keeps growing louder with time.
gigy is online now   Reply With Quote
Old 4th July 2006, 19:38   #12
gigy's Avatar
Thanked: 41 Times
baleno lower arms cost 3500 a pair if bought from opera house, go to maruti service center and you end up with a 10k bill
Old 4th July 2006, 19:42   #13
gigy's Avatar
Thanked: 41 Times
khat -kaht sound is from lower arms . do remember to chande associated rubber parts also, small things but matters to keep things in good shape. never reuse rubber components.
axle sound is more like heavy grinding with khat-khat sort.
Old 4th July 2006, 19:55   #14
humyum's Avatar
Baleno Lower arms for 3500 a pair .after hearing this i love 800 even more.My car lower arms cost 350 a pair.As for the axle from the sound u are telling its definately the axle but i doubt how can the axle wear out so soon.Check the axle boots.They get torn sometimes due to a stone hitting them and all the grease inside starts spilling out and due to the lack of lubrication to the axle joints they start failing.
Keep checking the axle boots on a weekly basis and change them if they are torn asap.This will save a lot lot of cash.
As for the axles i think 7 to 8 grand per piece sounds more like it.Although u get NON original axles too dont go for it as they will fail in no time.Thats why mass is a place to go for such parts.
Old 6th July 2006, 17:37   #15
Thanked: 7 Times
gave my car for service today, both the axles are gone & two of the four engine mountings are broken. the cost of repairs & service is approx 20k. i m told that the axles cost approx 6k each & mountings 3k each.
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
What do u do when the axle is gone speedsatya Technical Stuff 16 27th March 2009 00:09
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
