Old 20th July 2006, 15:53   #16
satish_appasani's Avatar
Thanked: 45 Times
I think the cabin light dimmer is present in car shipped since 2004. My 2004 Palio D has this feature.
satish_appasani is offline   Reply With Quote
Old 20th July 2006, 18:25   #17
DRC
DRC's Avatar
Thanked: 42 Times
Is it? I did not have the cabin light dimmer in my petra!, I got it fixed witht the auto cop.
DRC is offline   Reply With Quote
Old 14th April 2011, 09:36   #18
Thanked: 29 Times
Default Issue - Injector light staying on in Palio 1.6
Hi - This morning I noticed that the fuel injector light on the Palio dashboard goes off, & then comes back on after a few secs. , and stays on thereafter. There is no vibration or loss of power in the car.
I intend to take it to the service station this afternoon.
Some recent service details
Spark plugs: Replaced about 8 months back.
Service done : 5 months ago. Mainly oil change, moved to semi synthetic. No injector cleaning was done.
Breakdown : Last month I had a breakdown when the radiator fan gave way. I noticed it after driving about 3/4 kms, when the temp gauage nearly went to the top. Towed it to the service station. Fan replaced & vehicle was running smoothly since then. Could that momentary overheating caused injectors to be semi clogged etc ?
But any ideas what could be the cause.
Seeler_Rebeiro is offline   Reply With Quote
Old 14th April 2011, 10:53   #19
gypsyFreak's Avatar
Thanked: 188 Times
Default Re: Issue - Injector light staying on in Palio 1.6
I too have faced this problem in my mpfi esteem. In my case this usually happens when the car is parked direct under the noon sun for sometime. When i start the car, the injector light stays on and usually goes off after some restarts.
When the light stays on, i just monitor it for 1-2 stop/starts and even then if the light stays on, i take it to the nearest MASS.
Couple of times i have shown this to MASS, they checked everything and did not find any problem in the injectors. Finally, thry just disconnected the battery and reconnected it and the light was off.
gypsyFreak is offline   Reply With Quote
Old 14th April 2011, 10:54   #20
planet_rocker's Avatar
Thanked: 365 Times
better get it checked thoroughly - ask them to do a scan.
Did you try to reset the ECU?
planet_rocker is offline   Reply With Quote
Old 14th April 2011, 16:01   #21
Thanked: 29 Times
@planet_rocker - will go to FIAT service tomorrow. Tied up at work today. relating to ECU reset, is that something we can do, or something that the workshop will do ?
Old 14th April 2011, 16:07   #22
Thanked: 365 Times
pull out the negative terminal of the battery and wait for 30 minutes - reconnect the battery and see if the Injector light is still ON.
note: you will lose the ICE settings / clock setting if you disconnect the battery.
Old 15th April 2011, 07:38   #23
Thanked: 29 Times
Thanks. Disconnecting the battery didn't help. Taking it to the service station now. Will update you on the cause later.
Old 15th April 2011, 07:54   #24
Thanked: 110 Times
Injector light ON doesnt mean the fault in the fuel pump or injector. It could be loose wiring connection, faulty fuel pump relay, clogged fuel filter, worst case leaking fuel pipe. You told they replaced the fan. What made them to replace ? Does it throw any fault code. It could be a simple carbon brush change if the coil in good condition.
Stay with the technician during scanning and look for the fault code. Let us know the code if throws up. Also look for the above points I have mentioned.
Vijay
vijaycool is offline   Reply With Quote
Old 15th April 2011, 08:56   #25
Ravi Yadav's Avatar
My friends palio too had the injector light ON issue , a scan revealed that it was due to a loose connection. Just get a scan done ,it will revel the real issue.
Ravi Yadav is offline   Reply With Quote
Palio head lamp problem. Firebird Technical Stuff 9 4th September 2017 10:30
Palio GTX injector blocked solly Technical Stuff 16 31st July 2009 22:07
GETZ low fuel warning lamp- does it work arunkumar_rec Technical Stuff 0 13th December 2007 11:17
Varying Palio tail lamp price? sans33 Technical Stuff 15 25th August 2007 22:01
How long after fuel warning lamp is on thalavoy Technical Stuff 26 25th April 2005 12:50
