| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Nov 2004 Location: New Delhi
| hey guys my palio 1.2 developed a strange problem today. i tried to start the car but the engine refused to fire up. the starter motor did crank up but the car didnt start up. i looked in the instrument panel and the injector warning lamp which is supposed to go off after a couple of secs after switching the battery on did go off but came back immediately. now i am hell worried what happened to the car? can any bhp-ian help me out here. |
| | #2 (permalink) |
| Senior - BHPian | I am not sure of the cause since I have not faced this problem so far on my Palio 1.2. If you are a member of Palio Users Group [http://autos.groups.yahoo.com/group/paliousersindia], you can post your query there or just search the Archives of this Group, am sure you will find some resolution there.
__________________ Drive Safe, your loved ones need you!!! My Passion is not driving Cars, but driving a FIAT! Finney, Bangalore Palio 1.2 NV - 2004 |
| | #5 (permalink) | |
| BHPian Join Date: Oct 2004 Location: Bangalore
| Quote:
__________________ Deepak Honnalli. | |
| | #7 (permalink) |
| BHPian Join Date: Mar 2005 Location: Singapore
| This is a black thingy in the passenger side front foot well.. you may have to remove the floor mats and crawl under the dash to see it.. However, this switch is supposed to trip only in an accident and then needs to be replaced.. Also do this - remove the main battery leads for a few minutes and reconnect. Then try the ignition and see if the injector light stays on.. If that happens, it might be a fuel pump failure.. Try to listen for the pump sound when you switch on ignition..How many KM has your car done? |
| | #11 (permalink) |
| i did contact the service center. they said the car would be needed to be towed to the station. its just that i havent been able to take time out to go there. i will try to do that as soon as i can. will keep u all updated. btw anyone ever had the same problem here? |
| | #12 (permalink) |
| Newbie Join Date: Mar 2005 Location: Hyderabad
| Amit i faced the same problem for my GTX ( bought a used one last month) . however for me, it used to come while i m driving with AC on or high revving, never had starting problem though (starting problem must be due to low battery). I droved it down to anuroop (hyderabad) they said ignition coil for one valve is dead, replaced it for Rs.1890 + labour. here is what u can do 1. check the battery if its fine, get it started by pushing the car. i know its tough but u can engage some labour. 2. If its starts drive it down to dealer. drive slowly with caution lights on, The performance will be very poor and u will find the pick up is very slow. dont rev the car, dont use AC, dont drive about 50 kmph 3.If it doesnt start then last option left is tow it to dealer. |
| | #13 (permalink) |
| i finally called in the guys to tow the vehicle to the dealer (A-One Motors Rama Road). the guys came and after fiddling through some sensors and stuff (TD Sensor etc), ECM and all came to a conclusion that the car needs to be towed to the Workshop. I dont know what happened to the other guy who decided to check the Relay Box. turns out the damn relay was the culprit. replaced the defogger relay to the ignition one to get the thing started. i am just happy the car didnt need to be towed. also one more thing. the cabin light in my palio doesnt work smooth. many would know that it has an 8-sec dimmer feature. now if the engine is running the light goes out 8-sec after closing the door. but when the engine is off and the key is out and am finally locking the car up to goto my house the light refuses to go out. this problem has been there ever since i bought the car. but the damn "PARTS ARE COMING FROM MUMBAI" excuse of the dealer made it hard for me to get it replaced under warranty. Any suggestions as to what is the culprit. I am sensing another relay culprit. |
| | #15 (permalink) |
| BHPian | Sorry I didnot see this thread any earlier... May be I could have been of some help. I suspected this when I read the first post...I remember, when I took the delivery, the mech there mentioned about this likely failure. He showed me the relay, and asked me to replace the horn relay in case if I encounter a failure. He felt the Horn is trivial. However, the relay for fuel pump is supposed to be in the hood near the ECU for 1.6. not in the relay box!
__________________ _____________________ Stand on your head, upside down.. The world does not look any different, but you sure will look different! |
| Thread Tools | |
Similar Threads | ||||
| GETZ low fuel warning lamp- does it work | arunkumar_rec | Technical Stuff | 0 | 13th December 2007 10:17 |
| Poor quality Palio Tail lamp | sans33 | Indian Car Dealerships | 6 | 6th September 2007 01:20 |
| Varying Palio tail lamp price? | sans33 | Technical Stuff | 15 | 25th August 2007 22:01 |
| Palio head lamp problem. | Firebird | Technical Stuff | 4 | 11th July 2007 09:48 |
| How long after fuel warning lamp is on | thalavoy | Technical Stuff | 26 | 25th April 2005 12:50 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
