Thread Tools
Old 17th August 2007, 15:36   #16 (permalink)
nitrous's Avatar
There are car-chargers available for Laptops. Unbranded car chargers are dangerous for the Laptops.
So, I would suggest getting good brands.
__________________
The Road less travelled, is less travelled for a reason
Old 17th August 2007, 16:21   #17 (permalink)
gd1418's Avatar
Go to - Inverters - Inverters under 1000 Watts
Originally Posted by amohit View Post
to make a laptop draw power from the car battery?
Not sure why any one wud do that...but still then.
If so how?
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 17th August 2007, 19:59   #18 (permalink)
chetanhanda's Avatar
Originally Posted by naveendhyani View Post
hi all!
is there a device which plugs in the cigerette lighter adapter & can b used 2 charge ny 220 v device?
i mean something like a power strip which takes in 12 V, amplifies it to 220 V & has normal extension cords on the other end. sometimes need to charge the laptop & other electronic devices while on travel.
there are lots of them... but dont go for a cheap ones from ebay..get a branded one with a decent fuse..
also make sure it has an in-built fan/cooling system, coz they will get pretty hot lying on the floor of the car..
go for brands like Cobra -they got a decent reputation with radar detectors and other car gadgets , pretty good.
I've been using one for past 2 years..
chetanhanda is offline   Reply With Quote
Old 17th August 2007, 20:30   #19 (permalink)
hellstar's Avatar
I recently brought one for about Rs 1.2 K from Hyundai A.S.S , comes with 6 month warranty and yes it has both a fuse and a Fan for cooling itself has been using it with my laptop and also my mobile and handycam charger. I have the 150 W version, but had i know about the existence of the 300W version i would have jumped at it :-).
But then again you have to check the fuse rating of he Car Ciggy Plug before you start attaching things on to it , or it might just blow you fuse .
you can find details of the product at AC DC Adapters Manufacturer,Switching Adapter Manufacturers,AC DC Adapters India,AC DC Switching Adapter,India
hellstar is offline   Reply With Quote
Old 19th August 2007, 00:40   #20 (permalink)
yuv
hi... I got belkin a 1000 watts... using it since last 2 years.
no problems at all and it "is" very handy.
yuv is offline   Reply With Quote
Old 19th August 2007, 09:40   #21 (permalink)
hydrashok's Avatar
@yuv, did you buy it from India or abroad? If from abroad, did you buy online? Could you say how much you bought it for? I was also looking to get a good quality power inverter.
The ones in hellstar's links also look to be way better than the typical ebay-type ones.
__________________
eXcesS!
Old 20th August 2007, 09:17   #22 (permalink)
rdkarthik's Avatar
I have used and blown 9 inverters so far, all different brands and made in china and inda, all of them rated over 150W and with cooling fans....
Now i use an APC inverter secifically made for laptops. This has been the most reliablle and robust system so far for me. Retails for around 2.9k.
rdkarthik is offline   Reply With Quote
Old 20th August 2007, 10:23   #23 (permalink)
hvkumar's Avatar
I use inverters (250 W) in my car that can be used to charge laptops, handycams and mobiles. For my Garmin GPS, I have a special adaptor supplied by Gramin (as an accessory). I bought the inverters in Bangkok, teh first one is over 2 years old, once there was burnout (thanks to an overload, my fault, tried to run a car vacuum cleaner off it!), but taht was locally repaired. I have tried finding teh inverters in India (Bombay, Lamingyon Road) but did not succeed. The inverter costs me less than Rs 1,500 equivalent in Bangkok.
After the adapter, I have no problems with charging any devices on the move. Particularly useful when I go on my long driving holidays.
__________________
Kumar
2005 Mahindra Scorpio 2.6
1999 Daewoo Matiz SE
1994 Mahindra Commander
1986 TVS Suzuki AX100
hvkumar is online now   Reply With Quote
Old 25th October 2007, 12:17   #24 (permalink)
Default Power invertors
I came across this product called as "Power Invertor". HomeShop18 .
Advantages of this device could be,
1. Can charge my laptop!
2. Can use my existing mobile charger.
3. Can use my existing camera battery charger.
4. Can use my existing charger for PMP,ipod!
My worries:-
1. How will it impact my car's batteries?(Lets assume that I use it just to charge various batteries, thus power consumption is not more than 50W and I use it while driving only.)
2. Is the cost of the product justified?
3. Any adverse impact on the AC devices?
4. Woudl you guys recommend buying this adapter?
__________________
Mohit
Finally...Esteem VXI.
amohit is offline   Reply With Quote
Old 25th October 2007, 13:03   #25 (permalink)
spadival's Avatar
I have this product lying unused in my car now.. Lemme know if you are interested via PM.
Reason for selling: I don't have a cigarette lighter in the car now. And I have a CarPC installed
I haven't really used it to charge the laptop. I have charged my phone and GPS off it without any problem.
spadival is online now   Reply With Quote
Old 25th October 2007, 13:32   #26 (permalink)
Team-BHP Moderator
tsk1979's Avatar
I have such a product too, but currently looking for MX audio dealerships in noida so that I can get a power cable to charge it from lighter socket.
__________________
Reclaiming.....!
Old 25th October 2007, 13:44   #27 (permalink)
thanks spadival,
will contact you once I get my car(shud happen by mid next week).
by the way, I wanted to know if its ok to use something like this with the standard car battery(of Esteem) or its advisible to have some high performance battery?
__________________
Mohit
Old 25th October 2007, 13:57   #28 (permalink)
spadival's Avatar
You need to check how much power does your laptop draw. shouldn't be a problem if around 100W. Remember that your laptop/mobile phones themselves are DC powered devices. So in a way, you are performing a unnecessary and lossy conversion to AC.
More details about this product:
1. It makes a screeching sound when powered up - Just an indication that its powering up.
2. It has a blue LED which I found irritating while driving.
3. It doesn't exactly snug fit on the Baleno cup holder.
4. Quality including finish is very good - it has all kinds of protection built in (Overload, overheat, short circuit, reverse connection and under voltage protection).
5. Built in USB charger port is very useful.
Old 25th February 2008, 22:57   #29 (permalink)
kb100's Avatar
Default Car Inverters
Fellow BHP-ians!
Over a period of time, between me and my wife, we have accumulated an assortment of phones all requiring different chargers. Given that we travel frequently, the potential of having to invest in all the respective car chargers - and the potential mess it'd create in a closed car environment - has driven us into investigating the 'Car Inverter' solutions available in India.
I keep reading about 'AXIOM Car Inverters' here and there. It comes in three capacities - 75/150/300 Watts. The first two cost 1200/1500 respectively. What might I need? Has anyone used these car inverters? Do they give stable supply? Are they reliable? Are there any other cheaper, yet reliable, options available in India?
Any and all inputs are welcome and much appreciated!
__________________
A closed mouth gathers no Feet.
kb100 is online now   Reply With Quote
Old 25th February 2008, 23:48   #30 (permalink)
low_bass_makker's Avatar
I have watts 250 model . It is not AXIOM but works fine. I use it to run my laptop during SPL sessions.
__________________
156.6 db, naa....time is coming to cross it......
low_bass_makker is online now   Reply With Quote
Thread Tools
Battery chargers akg7091 Product Discussions 32 1st October 2007 02:49
Turbo Chargers khaadu75 Modifications & Accessories 7 4th December 2006 00:42
Electronic wedge brakes[Lighter, better, shorter stopping distance & in cars near U] 1Day The International Automotive Scene 3 11th November 2006 22:05
Computer system for integrating car electronic devices harishsegar Technical Stuff 1 2nd June 2006 19:36
bluetooth in laptops? manaa45 Gadgets, Computers & Software 10 24th January 2006 13:49
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
