Old 5th July 2006, 20:38   #1
islero's Avatar
Default A Land Rover speciality.....?
I was having a very intersting chat with my uncle who is a Land Rover freak (and one of the reasons behind my own obsession with the marque).He used to own a Defender 110 with the 2.5 turbo diesel engine.
We were just talking about the driving experience of the vehicles, when he told me about this incredible feature of a Land Rover 2.5 diesel, which he said not many diesel off roaders are capable of.
Well the deal is like this. Say he was at the bottom of the climb in a multi-storey car park. What he would do is, slot the gear into first, get the Landy just moving, and then leave all the pedals completley.
BUT THE LANDY WOULD NOT STOP MOVING. It would still trickle forward at a very low speed without its speed dropping or rising. Then all he would have to do was steer the vehicle around, no need to touch the throttle at all.
He said this was due to the torque characteristics of the engine, and was also possible in second, and maybe in third too.
This really got me thinking. Has anyone experienced this phenomenon in their diesel Landy/jeep etc?
I am not very experienced in these things, and I want to know more. What I want to know is, is this a common phenomenon, because I remember reading in some auto magazine that even the hummer was capable of something like this.
Cheers,
Islero
islero is offline   Reply With Quote
Old 5th July 2006, 20:57   #2
Captain Pings's Avatar
oh i love landys! tell u what, i'll try it with my gypsy and let you know if it continues to crawl up an incline!
Captain Pings is offline   Reply With Quote
Old 5th July 2006, 21:00   #3
Harrie's Avatar
Thanked: 25 Times
I am not sure about this but my GTX does the same. I do this in PVR... Forum. Forgot the damm name after 4 months.
I slot the car in first and let go off the pedals and car pulls forward speed breakers and all without a hiccup. But this the car would do only if I fill it up with Shell or BP or some good fuel. If i put IBP or ESSAR the car would start knocking...
In fact a combination of worn out clutch and low end torque made my wife say that the uno was the easiest car of the lot to drive. Almost like a automatic. First gear. Let go off the clutch and the car will crawl without jerking...
Harrie is offline   Reply With Quote
Old 5th July 2006, 21:07   #4
devarshi84's Avatar
Thanked: 119 Times
Our 68 fiat model was capable of this feat but only in 1st if I remember properly.
devarshi84 is offline   Reply With Quote
Old 5th July 2006, 21:19   #5
airfoil's Avatar
Thanked: 67 Times
My thoughts exactly - my GTX does it too.
airfoil is online now   Reply With Quote
Old 5th July 2006, 21:35   #6
Thanked: 151 Times
Our Padmini 137D does this handily. One of them (we had two, but literally gave one away), would climb slopes in third, with only the clutch being released, and no throttle at all.
I used to work in the hills around Neyyar Dam with Milma in '96. Those of you who know that area will know that there are a lot of really tough places there.
I've gone places with this Padmini that 4WD jeep taxis would not go.
This creep feature has helped many times on really bad terrain, where all I had to do was engage first, let out the clutch, and steer: the car would literally drive itself over the tough spots.
In fact, after a while, I learned a very valuable lesson - let the car be. I was doing a far worse job negotiating the rough spots than the car was by itself.
NPP
pillainp is offline   Reply With Quote
Old 5th July 2006, 22:40   #7
drifter's Avatar
And so does my accent crdi uptill 2nd gear...havent tried 3rd.
Drifter
drifter is offline   Reply With Quote
Old 5th July 2006, 23:10   #8
aah78's Avatar
Thanked: 1,751 Times
this happens in the older Discovery as well as the newer LR3 (Discovery 3) but both cars were petrol engined V8s with automatic transmission, not manual diesels.
with the Lo-Range gearbox engaged, and the transmission in Drive, the car does move forward on an upward slope at a speed of around 5mph (@ 8kmph), without any throttle pressure.
no magic here - any engine with a decent amount of torque can achieve this.
aah78 is online now   Reply With Quote
Old 5th July 2006, 23:22   #9
Mpower's Avatar
Thanked: 1,687 Times
basically first is a crawler ratio (real short).
Our 94 Tatamobile did that too. Great for learners coz you can never stall it by dumping the clutch.
Old 5th July 2006, 23:25   #10
islero's Avatar
Erm, I was talking about DEFENDER, not Discovery.
early 90's defenders had a 2.5 litre Turbo diesel engine. There was also the option of the V8 petrol.
Old 6th July 2006, 00:21   #11
aah78's Avatar
yes, i did read through your post before putting up my experience.
the Discovery 3 does have a diesel option too (2.7l V6 Turbo), however, unfortunately, it isn't sold in the USA - has to be specially ordered. the Defender isn't sold here anymore, either.
Old 6th July 2006, 09:53   #12
Thanked: 655 Times
Most of the older landy's have the 2.5 DI normally aspirated diesels. These have a fairly high idle rpm, which helps the vehicle move along at a crawl in first gear without acceleration. I do it all the time on my friends 90 defender 110.
Actually the 2.5 Turbo diesel was not a really reliable engine, with many cases of blown head gaskets and failure asthe engine could't really handle the turbo.
With an idling rpm of about 750 on the DICOR, the car won't do a crawl however!!
jyobeb is offline   Reply With Quote
Old 6th July 2006, 15:00   #13
ok. it's been verified ( had practised it long back when climbing loose slushy slopes, but didnt recollect gear etc- so experiment tried again)
T
he gypsy does the 'creep' upto the 3rd gear. If some members were irritated by a black gypsy driving peculiarly slow up delhi's fly-overs and every available incline - the inconvenience is regretted.
For non-members - it was in the interest of 'research.'
ofcourse, when i slot it in either 4H/L - it shudders less. and yup, the idling RPM on my gypsy could do with a little increasing. its at about 850 - 900 at the moment. (and I had to turn the air-con and my extra cooling fan off - reduce load!)
so many factors involved which help the creep - nature of torque curve ( flat? how much in the lower range etc) , gearing, idling RPM etc etc! and diesel's like the landy must have yummy torque curves!
a question for the members who've known defender's well - do they have any feature for climbing too ? ( like the new one's have HDC etc?) - just curious.
Old 6th July 2006, 15:08   #14
sumitkalindi's Avatar
Thanked: 13 Times
Well Sumo, as well as 407 does that, and all trucks manage to do this creep in first gear at almost any incline. And yes fiat(premier padmini) also could do it.
sumitkalindi is offline   Reply With Quote
Old 6th July 2006, 15:12   #15
satish_appasani's Avatar
Thanked: 45 Times
My Palio D will also do that with pressing any pedals in 1st gear. I never tested in 2nd gear
satish_appasani is offline   Reply With Quote
Pics: Silver Land Rover Range Rover SE Gordon Super-Cars & Imports in India 38 4th May 2011 17:06
Land Rover To Mark 40th Anniversary Next June With The Unveiling Of The Range Rover L AyAn! The International Automotive Scene 4 2nd September 2009 02:09
Land Rover Unveil 2010 Range Rover Sport with all-new 510hp V8 Engine hanmust The International Automotive Scene 2 8th April 2009 20:53
Land Rover unveil the LRX - to be badged Range Rover Tstag The International Automotive Scene 26 14th March 2009 16:17
