Thread Tools
Old 7th July 2006, 18:03   #1 (permalink)
~ H O N D A ~'s Avatar
Default Water Leakage
im in serious trouble guys and i need ur help.
I have a OHC and i have a water leakage.....
i donno from where maybe its gettin leaked from the front windsheld coz it was broken and i had replaced it at the HONDA showroom....
Plz help guys what should i do bout it....
Note from the Team-BHP Support Staff : Slang and SMS Language are STRICTLY prohibited on Team-BHP. Please type in full and proper English for the benefit of other community members.
We advice you to read the Announcements and Board Rules section before proceeding any further.
__________________
I dont believe in MIRACLES
I RELY on them
Budget: A method for going broke methodically !!!
~ H O N D A ~ is offline   Reply With Quote
Old 7th July 2006, 18:09   #2 (permalink)
Captain Pings's Avatar
need some extra information -
cold water / hot water?
does it look like coolant ?
drop-by-drop / stream ?
approximate location of origin ?
does it increase when you use the 'wash and wipe' on the wipers ?
Captain Pings is offline   Reply With Quote
Old 7th July 2006, 18:14   #3 (permalink)
Steady on there Capt'n... the lad's liable to go sit in the thunderbox if you go on and not come out.!
Have the same problem with my Accent... if it isn't too bad.. I suggest you live with it instead of going through the hassle of refitting your windshield.
2L8uLoose is offline   Reply With Quote
Old 7th July 2006, 18:23   #4 (permalink)
viper's Avatar
Hey,
Both you guys have you not heard of something called pluggin the leak. Two jobs first try and locate the source of the leak, if not successful give it to someone good. Then put some silicone solution to the affected area and plug it.
If you want a good & reasonable source pm me.
Viper
__________________
NO ONE DARES COME CLOSE
viper is online now   Reply With Quote
Old 7th July 2006, 19:56   #5 (permalink)
Originally Posted by viper
Hey,
Viper
The whole job can be done within 250 bucks and the best part is you can do it yourself.
So long....
varunroy is offline   Reply With Quote
Old 7th July 2006, 19:59   #6 (permalink)
heh heh .... sorry guys, jumped the gun there! a bit used to fire-fighting such problems!! sp. on the gypsy where it keeps raining inside....and different reasons each time!
and yup, silicon sealant does the trick.
Old 7th July 2006, 20:02   #7 (permalink)
Jaggu's Avatar
if its carpets getting wet, check the AC drain pipe for blockage
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 7th July 2006, 20:18   #8 (permalink)
Not neccessary, even the rain water could be seeping in through the front wing screen rubber beading.
So long....
Old 8th July 2006, 00:53   #9 (permalink)
Ford Rocam's Avatar
Didnt want to start a separate thread, even i am facing similar problem water coming inside in drops both at driver & passenger side during rains & carpet gets wet it stinks a bit everytime you open the car, eeek, also during recent rains our area was flooded & the muffler was submerged in water the tone has changed a bit now, but i need to fix the water problem asap any quick solution?
__________________
Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap.
Ford Rocam is offline   Reply With Quote
Old 8th July 2006, 13:32   #10 (permalink)
sumitkalindi's Avatar
Looks like the water is seeping in from the doors. try to locate the area from where the water seeps in and we can have some solution
sumitkalindi is offline   Reply With Quote
Old 8th July 2006, 13:41   #11 (permalink)
Ford Rocam's Avatar
Its coming from behind below the dashboard i can see it when it rains heavily i guess its coming from the front wing screen rubber beading. I had to remove my ECM from that location & wrap it up in an anti static bag and seal it & keep away from that location.
__________________
Old 8th July 2006, 13:41   #12 (permalink)
normally_crazy's Avatar
Check for the door beadings and windsheild beadings . many a time they are the cause of a leak as in my octy but then I did a patchup job inhouse and now voila no water in the car....
normally_crazy is offline   Reply With Quote
Old 8th July 2006, 18:33   #13 (permalink)
Ask someone to pour water with a hose but make sure that you pour over the roof area so that the water hits the rubber beading at all sides. Normally the water seeps in from the top portion of the beading where it meets the painted area. You could wet a coloured chalk and smear it on the inside. this will make it easier for you to spot the exact location of leak.
So long....
Old 10th July 2006, 19:58   #14 (permalink)
turbo_c's Avatar
Guys, I have have a pesky leak in the boot of my car... it shows up only when I drive / park in heavy rain.
I can clearly see the point where the water springs out, but I suspect that the actual leak may be somewhere else and that the water is travelling through the structural channels in the boot. I could just seat up the "drain hole" where the water comes out, but I'm sure it will at best just find another outlet in the boot or worse, it will corrode the metal structure and I might find myself with a hatch back!
I am suspecting one of the joints on the (bonded) rear windshield... but pouring water all over the car does not reconstruct the leak :( ... any ideas on how I could find the source?
Also, where do I get silicone sealant? The auto parts guys I have talked to "never heard of the stuff" !
- T u r b o C -
turbo_c is offline   Reply With Quote
Old 10th July 2006, 20:01   #15 (permalink)
viper's Avatar
- T u r b o C -
Ask any automobile shop or paint store for Silicon Tube the kind used to seal/fit windscreens. Price starts from Rs 350 a tube uptil Rs1500 based on what brand/quality you go for.
Viper
__________________
Thread Tools
Coolant liquid leakage wanderlustindia Technical Stuff 17 2nd May 2008 10:35
Shock Absorbers Leakage vebmetal Technical Stuff 11 30th December 2007 14:16
diesel leakage zenopio Technical Stuff 0 20th November 2007 22:18
Water Leakage in my OHC ~ H O N D A ~ Technical Stuff 11 16th November 2007 10:54
Diesel leakage in Indigo TDI raptor3624 Technical Stuff 2 5th October 2006 15:55
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
