Old 20th March 2014, 23:03   #16
Thanked: 8,978 Times
Default Re: About Non-Linear Speedometers
Originally Posted by zenren View Post
Difference of 1-2km/h on a GPS based speedo has multiple reasons:
  • GPS always computes speed based on time and straight line distance travelled between two consecutive points that it measures. If the roads are slightly curvy, you actually travelled a higher distance in that time than your displacement indicates and hence the car speedo indicates slightly higher speed.
  • In most GPS devices, readings would have a slight time lag and hence what you see now would be your speed 1-2 seconds ago. You can check the speeds on the GPS speedo when you slow down - it'll take a second or so before starting to decrease.
Sorry, this is not entirely accurate.
Nearly all GPS units measure speed based on doppler phase shift effect. Even if it would measure time/distance (and some do) it would do that several times per second, so a curve road has no bearing on speed.
What is true is the fact that in order to get an accurate GPS speed reading you need to be traveling at a constant speed. So no acceleration or deceleration. At constant speed they are very accurate, much more accurate than your car's speedometer.
Whereas the absolute error in most car speedometer increases as the absolute speed increases the absolute error on the GPS remains (by and large) the same.
I have been thinking about these non linear speedometers. I have had a few cars that had those (VWs). I'm not yet convinced that they are more accurate. Because of the scale it appears as if you read the speed with great accuracy, but that doesn't mean that the actual reading itself is more accurate in that section of the scale than the "higher up" sections. Just because you have a more granular scale doesn't make the measurement itself more accurate, only the reading of the value.
It probably depends on how these non linear speedometers work. Is it driven by a motor, or is it in essence just a voltmeter? I.e. a coil in an electric field. The needle moves because of a different voltage applied.
Believe it or not, but I used to teach instrumentation, calibration and that sort of stuff nearly 30 years ago. It might come back to me. It probably doesn't really matter for the driver. For all intents and purposed you think you get a more of an accurate reading. As long as you don't break the speed limit nobody is the wiser as to what the real speed and or accuracy is. One of the reasons that typically car speedometer reads to high anyway all the time.
Truth be told, I never noticed that the speedometer was nonlinear until somebody pointed it out to me. So it appears, well at least on me, to work quite naturally.
Jeroen
Jeroen is online now   (2) Thanks Reply With Quote
Old 21st March 2014, 20:54   #17
Thanked: 2,403 Times
Correct. Which is also why the non realtime postprocessed speed which is essentially based on ds/dt is quite bad. That is until and unless you have raw data (like .sbn files for the SiRF3 chips) files. Most recreational GPSrs dont.
The 5Hz and 10Hz chipsets are a very recent phenomenon. Old ones are 1Hz.
Unless there has been a sea change in technology, it should be an air core (Sin Cos) movement, not steppers.
Any other pies which have your fingerprints we should no off?
(To know that GPSrs use the doppler shift speed (and Kalman filters) requires knowledge of another pie!)
Sutripta
Old 22nd March 2014, 07:43   #18
Sutripta
I just like to pick things apart. See how they work.
Jeroen is online now   Reply With Quote
Old 22nd March 2014, 19:10   #19
anoop_lamba's Avatar
Thanked: 93 Times
Originally Posted by sarathlal View Post
Does this mean that there is no relation between calculating speed and the wheels of the vehicle? Reason for asking is, on most cases related to changing the profiles or sizes of tires are discussed, one of the most common things listed as affected are, the speed indicated by the speedometer alters if oem tire specs are altered.
Yes. The speed indicated will change if tyre size is changed. For each revolution of the output shaft, distance travelled depends on tyre size. Bigger tyre size means more distance travelled per revolution of the output shaft.
The speedo is programmed to co-relate output shaft rotational speed (rpm) with vehicle speed and indicate it based on OEM tyre size. Increasing tyre size would mean vehicle will actually be tarvelling faster whiles the speedo thinks it to be slower and indicates lesser speed.
anoop_lamba is offline   (1) Thanks Reply With Quote
Old 22nd March 2014, 21:31   #20
You found out about the doppler shift, and the Kalman filter by taking apart a GPSr?
Sutripta
Old 23rd March 2014, 11:38   #21
Sutripta
Having lived in Kansas City near the Garmin HQ and knowing some folks there helps. I was also involved in the TomTom Live Traffic service. So I have had a few peeks under the hood so to speak. But in general I'm still fascinated by GPS and anything to do with navigation and charts. So I've done a bit more research than googling it and ending up on Wikipedia.
Old 23rd March 2014, 20:32   #22
And now that makes sense!
Sutripta
PS: Any observation on our (ie Indian) map reading abilities?
Old 24th March 2014, 09:18   #23
We have maps in India??? Not so I have noticed!
I can honestly say that during the 18 months I've been in India I have never seen a map being used by anybody. I have not seen a map in any car I have used so far.
I have been on several weekend trips with my Royal Enfield, usually with 10-20 other bikers and nobody brought a map ever!
I have a Garmin Etrex 30, fitted with maps from Openstreetmap.
(http://garmin.openstreetmap.nl/)
Notice the domain??
So far these maps have done me fine here in and around Delhi up to about 350 kilomter radius. Accurate enough. So I plan my rides on my PC and then upload them in the Etrex.
There is also a special openfietsmap for bicycle in the Netherlands. Incredible level of detail. There is a little alley next to our home and that is for instance visible and you can plan a route through it.
One of my favourite sites is this one: http://gpstracks.nl/
All in Dutch I'm afraid. In essence a huge collection of tracks for cars, bikes, hiking, bicycling etc. When I'm in the Netherlands I often use these when I want to go for a hike or a ride on my bicycle. I've contributed myself with some 15 odd bicycle tracks as well.
Jeroen
Old 24th March 2014, 20:17   #24
OT OT OT
Neatly, diplomatically sidestepped. (Necessary for self preservation from the torch and pitchfork carrying crowd.)
To be expected, given the cloggies love affair with their (pedal) bikes. And the fact that both Navteq and Teleatlas have strong Dutch DNA.
Sutripta
Non-VIP Registration Number. v12 Shifting gears 8 21st May 2010 15:01
Issues with Phase Linear HU akshaymahajan In-Car Entertainment 4 27th November 2009 18:04
My first Non Non-Stop Travelogue! 3 States, 10 Days Vacation! pulsar56 Travelogues 73 31st May 2009 23:32
How accurate are speedometers? 9216 Technical Stuff 18 21st May 2009 13:16
WAGON-R LX or SANTRO XK(Non AC) cdmanju Hatchbacks 27 5th March 2006 07:41
