Old 28th December 2006, 11:31   #16
Originally Posted by kiranpashtakar View Post
There would be a button on the top portion of the seat where the head rest rods sink in, you need to depress this to release the head rest.
I know of similar buttons for the seats in the rear, but there's nothing like that for the front seats... i have done fumbling over the front seats for anything button-like.
Anything else ?
CheeseGuy is offline   Reply With Quote
Old 29th December 2006, 18:58   #17
dustDevil's Avatar
mail4ajo: i hav an old zen which initially did not have restraints in the rear seats... but when i got seat covers fitted, they had a pocket for built-in headrests like in the previous generation zen... so i stuffed them with the same material as of the cover and they seem hard enough! it might work for you too!
dustDevil is offline   Reply With Quote
Old 9th January 2007, 19:11   #18
found a solution to my problem: my M800's headrest when pulled up has a square switch which needs to be turned and then the headrest needs to be pulled up - voila - done.
Old 9th January 2007, 19:44   #19
Surprise's Avatar
Thanked: 272 Times
Wanted to find out whether the recommended seating position is with head leaned against these headrestraints. I rarely see anyone with their head leaning against these headstraints.
More details on wiki
When travelling in an automobile a properly adjusted headrest can reduce the severity of the injury.The top of the headrest should be in line with the top of the occupant's head. Maintaining an adequate separation from the vehicle in front while driving and pressing your back against the seat while facing forward if a collision appears imminent might also be advisable. This helps prevent the neck being forced backwards, and decreases the risk of whiplash
Whiplash (medicine - Wikipedia, the free encyclopedia)
Surprise is offline   Reply With Quote
Old 9th January 2007, 20:02   #20
khanak's Avatar
Thanked: 130 Times
Originally Posted by revharder View Post
one thing to lookout for before buying those after mkt fitments is that the window in them should be having a tightened "net" in the open area and just not the plain hollow area. this will serve almost as good as the company fitted head (rest) restraints.
How does the "net" make any difference?
khanak is offline   Reply With Quote
Old 10th January 2007, 16:56   #21
IMHO, not required to lean head against the restraint, it will be an uncomfortable driving position. The idea of the head restraint is to stop whiplash during a collision.
autoenthusiast is offline   Reply With Quote
Old 15th January 2007, 12:57   #22
nikhil3456's Avatar
Thanked: 11 Times
The latest technology which is coming up (being developed by a lot of companies, one of them being GM's subsidiary SAAB) is active mechanically moving headrests.
Originally Posted by [FONT=Arial, Arial, Helvetica
[FONT=Arial][COLOR=#00000b]The system is entirely mechanical and is based on the lever principle. An upper padded support is connected to a pressure plate in the backrest of the seat. In some rear collisions, the occupant’s body will be forced by the crash pulse into the backrest, which moves the pressure plate towards the rear. Subsequently, the head restraint is moved up and forward to “catch” the occupant’s head before the whiplash movement can start. The precise activation of the system is determined by the force with which the occupant’s back is forced against the backrest, the magnitude of the collision forces and by the occupant’s weight.[/COLOR][/FONT][/FONT]
Link: Saab's Head Restraint
nikhil3456 is offline   Reply With Quote
Separate or Integrated Neck Restraints (Headrests) : Which is the safer choice? mints21 Road Safety 37 19th April 2016 10:25
Mercedes S class owner goes to court after faulty headrests in S class. Vid6639 Indian Car Dealerships 18 25th January 2015 21:14
Power valves - What are they / how do they work? chetanhanda Technical Stuff 10 9th June 2009 16:51
Collapsible rear headrests for SX4 to improve rear visibility Rajnish_350 Modifications & Accessories 13 3rd March 2009 11:53
HeadRests for Rear seats of Palio Stile guyonblackybx Modifications & Accessories 9 28th May 2008 16:55
