Old 17th September 2012, 10:13   #31
KSM-Vtec's Avatar
Thanked: 440 Times
Default re: Are gas shock absorbers really superior in absorbing bumps?
Originally Posted by Ragul View Post
Compare the stock factory fitted shocks for a new Gypsy with what? An older Gypsy with even older shocks? Not sure I understood your question.
--R
You got it right....the gen that came with stock oil shocks.
KSM-Vtec is offline   Reply With Quote
Old 17th September 2012, 10:30   #32
Thanked: 113 Times
Oh Even the new ones dont do any magic. The Gypsy is intolerable with stock suspension period. My buying decision rested purely on the existence of CFL product and its decent feedback. That was the one consideration on which I tipped over in favor of Gypsy considering its reputation for a poor ride. Even with CFLs front and rear its only tolerable not great. Hence I am going for Bilsteins.
HTH
--R
Ragul is offline   (1) Thanks Reply With Quote
Old 19th September 2012, 16:12   #33
invincible7's Avatar
Thanked: 154 Times
Need help with choosing the right set for Swift petrol.
Which Gas shockers are considered good for Swift Petrol, need to change all 4. Do I need to change the springs aswell. The car has completed 74K Kms.
I have head about the followings, which ones should I go for and also if someone can share the costs.
1. Gabriels.
2. TRW's
3. Monroe's
4. Delphi
invincible7 is offline   Reply With Quote
Old 4th July 2013, 15:55   #34
rkg
Thanked: 543 Times
My Vista has completed 72K. thinking of changing the shocks as there is some noise.
where do i can get Gabriel/Monroe shocks for Indica Vista in bangalore with approximate price , as iam planning to get them changed outside TASS.
rkg is offline   Reply With Quote
Old 5th July 2013, 19:23   #35
msaudf's Avatar
Thanked: 152 Times
Please don't get hasty and replace the shock-absorbers because of a noise. The noise could be coming from some suspension bush which will turn out to be a much cheaper repair.
Check with your mechanic or service adviser if your shock absorbers are actually weak.
msaudf is offline   Reply With Quote
Old 6th July 2013, 09:56   #36
rkg
Thanked: 543 Times
Shocks especially front left is indeed week. suspension bushes are all fine checked at Concorde in my presence.
Old 16th July 2013, 21:51   #37
Thanked: 154 Times
Thought about updating my experience with Shock Absorbers while I was looking out to replace them in Swift - tried switching over to TRW's Gas filled shock absorbers, however the ride was much stiffer in comparison to the oil filled ones from Maruti OEM.
I liked the car feeling planted while going over the potholes or bad roads, with the gas shocks I felt the overall ride has become very stiff and every single thing on the road was being felt in the driver's seat. I switched back to the OEM oil filled shocks (Dephi)from Maruti and am pretty satisfied with the ride quality which is much better.
Old 17th July 2013, 12:05   #38
vikram_d's Avatar
Thanked: 940 Times
If I remember correctly the Swift came with gas filled shock absorbers as OEM and not with oil filled ones. I replaced the shock absorbers on my car with OEM ones and they were gas filled.
Old 3rd August 2015, 16:42   #39
Hammer & Anvil's Avatar
Thanked: 684 Times
Old thread- needed an update
The Monroe Dealer for shocks in Mumbai is located at Opera House near Tiwari Mithai.
Rane Auto
Fateh Manzil
461 Dr DB Marg, Opera House,
Mumbai.
Contact Sales person:
Amit.
Manager:
Bhavesh.
Hammer & Anvil is offline   Reply With Quote
Old 3rd August 2015, 19:36   #40
sgiitk's Avatar
Thanked: 3,884 Times
Default Re: Are gas shock absorbers really superior in absorbing bumps?
Of course if cost is not a consideration you can also look at Bilstein. They are far superior to the run of the mill stuff, at a price of course.
Old 3rd August 2015, 20:17   #41
vasoo's Avatar
Thanked: 207 Times
I remember when I was learning to drive back in 80s on Amby cars, replacing the stock shocks with Sachs gas filled shock absorbers were a big thing. We did that in our 76 model Amby and the difference was amazing. I dont think the difference will be that much in these days considering the advancements happened in technology.
vasoo is offline   Reply With Quote
Shock Absorbers Leakage vebmetal Technical Stuff 13 22nd March 2010 17:24
gas filled shock absorbers Ironmarine Technical Stuff 1 24th July 2006 13:38
Shock absorbers n suspensions gbpscars Modifications & Accessories 1 10th May 2006 14:22
Hyundai Santro Shock Absorbers aquavelva Modifications & Accessories 3 3rd May 2006 15:21
Gas Shock Absorbers for Swift aseem Technical Stuff 26 26th August 2005 09:47
