Thread Tools
Old 10th July 2006, 11:40   #1 (permalink)
madhav's Avatar
Default Fuel Efficiency
Guys,
I've had this question unanswered for a long time... hoping that some of you can throw some technical light on this one!
Consider the following...
A Tata Indica Turbo diesel vehicle 1405cc, weighing 1050 (kg) and producing 68 ps gives approx 15Kmpl of diesel.
A Tata Safari 2956cc, weighing 2650(kg) and producing 115ps gives approx 10Kmpl of diesel
Whereas a Volvo BR7 (bus available in India) with 6L engine, weighing almost 16200 kg and producing 260 ps returns almost 3.5-4Kmpl of diesel (Source: KSRTC volvo bus driver)
Now comparing the three the Volvo seems to be the most fuel efficient. Shouldn't the Safari which which weighs 1/6th the Volvo, has almost 1/2 the power and engine capacity be more fuel efficient?
madhav is offline   Reply With Quote
Old 10th July 2006, 11:45   #2 (permalink)
condor's Avatar
Madhav, the calculations dont work in such simple equations. Also, you have considered kerb weight for the Indica and GVW for the Safari and the Volvo.
Old 12th July 2006, 00:03   #3 (permalink)
What about Sakoda it has a efficiancy better than all of these ....
bhogalrajnish is offline   Reply With Quote
Old 12th July 2006, 11:30   #4 (permalink)
naveendhyani's Avatar
i m sure FE is only determined by the kerb weight & engine capacity. it will have lots of other parameters to it.
naveendhyani is offline   Reply With Quote
Old 12th July 2006, 11:36   #5 (permalink)
Psycho's Avatar
The key part for fuel efficiency can be broadly laid out to the following:
1) Torque : Higher the torque lower the operating RPM lower the fuel consumption and higher gearing can be used
2) VE: Volumetric Efficiency of the engine to convert chemical energy into mechanical energy... most passenger car only have about 75 - 85% VE, however cars with turbo's have a higher VE
Therefore high revving engines with shorter strokes give great BHP whereas low revving engines with long strokes give better torque. Therefore Higher torque means better pulling power, hence heavier vehicles focus more on torque rather than just BHP which leads to better FE.
__________________
Learning is a continuos job that keeps me busy.
Old 12th July 2006, 11:40   #6 (permalink)
sumitkalindi's Avatar
Fuel efficiency depends on many different parameters.
It is affected by shape of the vehicle, the weight of the vehicle, and as well as the matching of the engine to the intended vehicle.
A 800 cc engine is very efficient for maruti, but will drink like a fish if installed in a Indica. So, though the Indica gives 15 kmpl, actually the volvo engine may be more fuel efficient.
We usually cunfuse between an efficent engine and a efficient car.
It may happen that due to some technical reason, a really fuel efficient engine may result in a gas guzzling car.
There you go. Better leave all the compleceted calculations and enjoy the drive.
sumitkalindi is offline   Reply With Quote
Old 12th July 2006, 11:47   #7 (permalink)
FE depends on all the factors mentioned like the weight of the car, the shape of the vehicle, the TYRES which you put on the same, the DRIVING STYLE of the individual drivers but the most imp factor i think is the ENGINEERS. i.e how well they can balance the amout of FUEL being pumped in the engine compartment, how efficiently they can BURN the fuel and in WHICH WAY THEY CAN MAXIMISE the power from the same.
once that equation is set, the other parameters come in picture.
Skoda seems to have cracked it.
experts kindly correct me if m wrong.
ac 427 is offline   Reply With Quote
Old 5th June 2007, 17:26   #8 (permalink)
Larger engines will clearly have more FE (in terms of power/distance covered, etc). Looks like the principles of "economy of scale" apply to the engines too :-). Otherwise.. we would have had trucks made of 100s of small Luna engines!!
Just to compare... a Luna engine has about 60 cc, hardly 3-4 BHP, and gave 75-80 kmpl. Imagine a car with 10 Luna engines producing 30-40 BHP (eqv. to Maruti 800) and giving mere 7-8 kmpl. The larger the engine, more efficient it gets.
amu1983 is offline   Reply With Quote
Old 5th June 2007, 17:55   #9 (permalink)
Do you know that Airbus A380 is more fuel efficient than an Indica or even a Prius, that too while flying at 30k ft? Ofcourse, this is cost per person...
__________________
I am an eco-driver
2001 Santro LP - 16.8/18.2 kmpl in C/H
2007 Verna XXi - 14.2/16 kmpl
Visit ecomodder dot com
appuchan is offline   Reply With Quote
Old 5th June 2007, 18:36   #10 (permalink)
abhilashvk's Avatar
I think psycho has given the best explanation. Its the technology that goes into the car that determine the torque and hence the efficiency. Like a 5.5 Litre Beamer or a Bentley churns out 550 bhp and torque close to 50 KGM where as 1.4 litre indica churns out only 72 bhp....
__________________
Abhi
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.
abhilashvk is offline   Reply With Quote
Old 5th June 2007, 19:46   #11 (permalink)
@ sumitkalindi & psycho:
Really well explained. thanks for the posts
AkMar is offline   Reply With Quote
Thread Tools
What is your Actual Fuel Efficiency? normally_crazy The Indian Car Scene!! 1368 5th October 2008 08:02
AVEO U-VA 1.2, Fuel Efficiency? Woods Sedans 1 4th September 2007 12:02
Fuel Efficiency Tips nicejits Modifications & Accessories 2 28th June 2007 13:27
Why the heck do we care ONLY about Fuel Efficiency GTO A Collection of the best threads 86 22nd September 2006 18:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458
