Old 20th October 2008, 20:16   #46
naveen.kk's Avatar
Thanked: 29 Times
Looks cool, but will it really have such a high power light which can replace halogen atleast if not xenons?
naveen.kk is offline   Reply With Quote
Old 20th October 2008, 21:33   #47
anantnehru's Avatar
I'm not too sure if that was directed towards to me.
Umm..I'm not really looking at replacing my halogens/xenons with these I'm only making these my parking lights.
As for LEDs being able to outshine halogens/xenons, I cannot say much as my knowledge is still growing!
Someone who has a little more knowledge regarding the same would probably be able to elaborate.
anantnehru is offline   Reply With Quote
Old 20th October 2008, 21:58   #48
CaliforniaKnight's Avatar
Thanked: 46 Times
Originally Posted by anantnehru View Post
I dont know if that was asked in a good way or a bad way, but this is what I got done to my car yesterday.
Hey anantnehru,i asked this in a way asif its growing in the accessory scenario, reason being, in dubai all boy racer cars have them installed.
Anyways looks neat at night.
CaliforniaKnight is offline   Reply With Quote
Old 20th October 2008, 23:41   #49
naveen.kk's Avatar
Thanked: 29 Times
Thanks for the reply,
It looks pretty cool, I look at one audi A4,and LEDs will be on in the morning. They seem to be bright, but I was wondering if they can be as bright to power a high beam.
Lets see.
Old 21st October 2008, 00:12   #50
anantnehru's Avatar
Oh? That sounds cool. Lol. Thanks alot!!
Lets see.
Yea the Audo LEDs are pretty bright, I've seen up close and personal - friend of mine works for Audi. LEDs powering a high beam does seem feasible as LEDs for a high beam may be possible because the draw alot less power and take longer time to heat up. But I dont know if something like that exists or is being developed. Would sure require really powerful LEDs for that.
Old 27th October 2008, 16:29   #51
ImmortalZ's Avatar
Thanked: 312 Times
Originally Posted by shyamhegde View Post
Hi ImmortalZ, did you order anything from that website? Prices there are way too expensive there (as you did warn). Ordering from US might be cheaper than that on some of the components.
Yes I have. Quite a lot.
There are two advantages :
1) You can get parts you can't find in retail stores.
2) No customs hassles.
In return, you break your bank. Its a trade off really.
Old 18th November 2008, 15:25   #52
getsurya's Avatar
Thanked: 967 Times
Thumbs up LED white car roof lights
hi All, I have replaced the yellow lights of my Scorpio with white LEDs. The car looks awesome and is cool.
Very basic DIY, nevertheless wanted to post this information if any member finds it beneficial.
Procured: High bright white LEDs :50 nos
Resistors: 100 ohms 25 nos
Basic circuit boards: 10 nos, 5 of 2X2s 5 of 2X4s
one Soldron, flux & solder roll
The wiring diagram is attached. Connected 3 in series with the resistor at the +ve end and then connected all three of the negative and postive terminals for the right connections. Opened the roof light of Scorpio with a screw driver, took out the original yellow bulb and connected the positive and negative terminals(not without blowing a fuse). And Lo, the white pristine lights are awesome!. Did the same for the rear light too on the roof. The car feels and looks cool with white LEDs lighting!
Now I plan to do the same to the Scorpio's non functional tower lights. I plan to put in rows of the red LEDS, which shall glow up on braking!!
getsurya is offline   Reply With Quote
Old 18th November 2008, 15:56   #53
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Good stuff. Please elaborate on the following:
Individual costs of parts.
Why 50 LEDs and 25 resistors? Did you blow some while attaching. You have shown 9 (3x3)
How are the LEDs supplied? As an individual unit or strips of three?
Why the circuit boards?
Is it cheaper to buy in bulk?
What brand did you use of each?
Can you post pics of individual and assembled components?
If you do the scorpio tail lights then they will truly look like a christmas tree!!!
Tejas@perioimpl is offline   Reply With Quote
Old 18th November 2008, 16:08   #54
shyamhegde's Avatar
Did you use generic dotted PCB to assemble LEDs?
I did post similar DIY on this thread. The light is still working. I did make some more of them for my friends too. I used ceramic 5 Watt resistors (10 Ohms) to make it look neat and better heat dissipation with resistor.
http://www.team-bhp.com/forum/techni...tml#post942845 (LED lighting in cars)
shyamhegde is offline   Reply With Quote
Old 18th November 2008, 16:17   #55
getsurya's Avatar
Thanked: 967 Times
Hi Tejas,
Why 50 LEDs and 25 resistors? Did you blow some while attaching. You have shown 9 (3x3): getsurya: I have bought more because in Hyd the market to procure them is far from the place I stay. So, just to cut down my trips to that area!!
How are the LEDs supplied? As an individual unit or strips of three?:getsurya: the LEDs are individual units only.
Why the circuit boards?:getsurya: the circuit board helps us to hold the lights together and has a uniform pattern for soldering. Also assists as a heat sink.
Is it cheaper to buy in bulk? :getsurya: yes, the more the merrier!from a cost perspective.
What brand did you use of each?:getsurya: sorry, did not bother to ask. I am sure LEDs are manufactured in India in millions by many companies.
Can you post pics of individual and assembled components?:getsurya: I shall do that.
If you do the scorpio tail lights then they will truly look like a christmas tree!!!:Getsurya: I will ensure that the car looks good rather than a glowing LED scorp.
Costs:
1. LEDs: each white LED is Rs 1.50 (9 X 1.50=13.50)
2.Resistors: each resistor is Rs.4.50(3 X 4.50=13.50)
3.Wire, Soldron, flux, solder etc can be costed as another 2.00 per LED(9 X 2.00=18.00)
4. Circuit board: a 2X2 board is Rs.10
TOTAL COST for this DIY=Rs.55!! Pleasure of seeing it working...Priceless!!!
Old 18th November 2008, 16:29   #56
getsurya's Avatar
Thanked: 967 Times
Hi Shyam,
yes, I used the generic PCB. Sorry, I did not find your thread when I did a search!
Old 18th November 2008, 16:34   #57
theodore_ftw's Avatar
Talking
@ Getsurya - Great job....Please post pics asap so we can see. In the meantime I'll ask some basic questions in 'our' mutual language!
Cost (Individual Parts and Total)
Time Taken (End to End as well just for the soldering/fixing)
Knowledge of Circuits (Level of knowledge required)
Warranties (Does this void any kind of warranty?)
Performance (How long do these last?)
Replacement (Any info on warranty on the LEDs)
Quality (Any specific brand of LED)
Hey, thanks for the answers. I actually had to step away from my desk for a while and had not refreshed the thread.
Note from the Team-BHP Support Staff : Please use the "edit" button if posting within 15 minutes of the first post, instead of creating another back-to-back post
theodore_ftw is offline   Reply With Quote
Old 18th November 2008, 17:02   #58
getsurya's Avatar
Thanked: 967 Times
thanks for your questions...if you need more answers, please PM me!
Old 30th November 2008, 22:43   #59
Thanked: 53 Times
Hey shyam, this is what I have achieved so far,these are still in initial stages abut hope to get some good results soon [once I get time to work on this again] am uploading unfocused and focused designs.
This is a single 9 Watt setup that has worked at ambient temperature of 34-37 deg C and the LED temperature at 79.9 deg C, no AC and NO active cooling system.
The first two photos are of a 9 watt setup with any focusing of light beam, the next two are of the same setup with focusing lenses. the setup now uses around 12watts total with controller using around 1.7 watts and rest is dissipated as heat.
I am still working on improving the controller to control the temperature.
These are 3 watt rebel LEDs from luxeon. Natural light I have even tried the warm light LEDs.
dinar is online now   Reply With Quote
Old 1st December 2008, 10:40   #60
shyamhegde's Avatar
Do you have a snap of the set-up with power off?
How did you fasten the LEDs on to heatsink? Thermal glue/epoxy are pretty expensive I suppose. Idea on any 'cost-effective' workaround for this would be great.
You seem to be doing lots of experiments on LED lighting, so should have already found some solution .
Auto Lighting thread : Post all queries about automobile lighting here Chevy Modifications & Accessories 11118 21st July 2018 11:37
Review: Osram LED Ambient Lighting Kit smartcat Modifications & Accessories 16 8th July 2018 18:23
LED Lighting Conversion for your Two Wheelers pssmath Ride Safe 35 29th August 2017 09:57
Instrument Panel RGB LED Lighting goelvaibhav Technical Stuff 17 13th August 2014 23:46
Audi's new matrix LED lighting & the NHTSA's dilemma! nitin.rai The International Automotive Scene 1 2nd January 2014 21:30
