Old 1st December 2008, 12:02   #61
Thanked: 52 Times
The rebel LEDs where solder using reflow soldering to a pcb from luxeon [this is cheaper then buying the soldered LEDs] the design of the pcb is such that you can screw them to the heat sink. I had used the heat compound available in the market commonly on the first prototype but now I have not used any thermal paste or epoxy, to reduce the thermal resistance, I have polished the heat sink to a get a flat surface and screwed the PCBs to it directly with copper powder inbetween the pcbs and the heat sink, have found this to be more effective, than the thermal paste available in India, and cost effective to the thermal compunds that are imported.There is an added advantage of having more metal area to desipate the heat.The dirver design also helps in contorlling the heat generated by the LEDs.
The new heat sink design which I mentioned has the PCB built into it so the LEDs get soldered directly on the heat sink.
As for the colimeters , I have designed some to give a suitable light spread and distance needed for Automotive use but still have to get the prototypes in my hand, the palstic used here in India is not that clear and also tend to fadeout with the heat from the leds, plus there are no manufacturers who understand what I want from the lenses.
At present the project is packed and kept in storage as I have no time to work on it and low on fund too. will post the the pic once I start the project again. these pics were taken 6 months back.
dinar is offline   Reply With Quote
Old 1st December 2008, 20:45   #62
vinayvtec's Avatar
Thanked: 9 Times
Guys can any one tell me who is installing the LED strips in the headlight of the car?
I am located in Bangalore and I have seen many Swift, Civic and Corolla with this LED strip headlight.
vinayvtec is offline   Reply With Quote
Old 2nd December 2008, 10:13   #63
dilipkumar7278's Avatar
Thanked: 23 Times
Default LED park lights in my Lancer
Guys
Here are the pics
dilipkumar7278 is online now   Reply With Quote
Old 2nd December 2008, 10:31   #64
greenhorn's Avatar
Thanked: 1,315 Times
hi dilip, where in ekm did you get them ?
Old 2nd December 2008, 10:51   #65
Thanked: 23 Times
Default LEd parklights
Hi Greenhorn
I fixed it from end effect...
Old 2nd December 2008, 11:17   #66
getsurya's Avatar
Thanked: 944 Times
Hi Dilip, the LED Eyebrows/eyelids on your car look nice. How much do they cost? can you please provide more details as I am interested for them for my cars too. How do they fix up to the current headlights?
getsurya is online now   Reply With Quote
Old 2nd December 2008, 11:37   #67
ASHISHPALLOD's Avatar
Thanked: 285 Times
hi dilip,
nice leds.
how much costed you?
ASHISHPALLOD is offline   Reply With Quote
Old 2nd December 2008, 12:37   #68
Thanked: 23 Times
Hi guys
It cost me around 1900 a pair. It has been connected to parking light switch. The LED strip is glued on top portion between the bonnet and HL so that it mounts neatly.
Old 2nd December 2008, 13:08   #69
getsurya's Avatar
Thanked: 944 Times
Thanks Dilip. I am just trying to find out if I can get something similiar in Hyd.
Old 2nd December 2008, 14:13   #70
Thanked: 52 Times
Look cool, is the strip mounted by cutting the bonnet, above the head lights? and is it screwed in place or stuck with adhesive, Quit expansive Rs 1900/- for LEDs. does this include the fitting also?
Old 2nd December 2008, 14:23   #71
shyamhegde's Avatar
Originally Posted by dilipkumar7278 View Post
Guys
Here are the pics
Hey! that is a nice one you got. Bright enough too I guess. LEDs are sitting so close and bright as well. Hope that place is not getting hot when engine is one, so that LEDs last long.
I wonder, can these be fitted inside the headlight assembly itself? heat might cause the LEDs to fail inside the enclosure when the headlights are on. I know 'anantnehru ' posted such install on this thread and he would be able to tell. But he got individual LEDs i guess and not the strip.
1900 is expensive (prompts a DIY work!), but i haven't seen a strip so bright and LEDs so close to each other. Dilip, can you post a day snap shot during the day please?
shyamhegde is offline   Reply With Quote
Old 2nd December 2008, 15:23   #72
gigy's Avatar
Thanked: 41 Times
dilipkumar7278, can you give a day time closeup photo of your install
gigy is online now   Reply With Quote
Old 2nd December 2008, 16:44   #73
anantnehru's Avatar
Nope nope, mine's a strip too.
They can be fitted inside the assembly itself, but opening the headlight for such a small change is a pain. Also, the heat inside would be alot more than outside.
Then comes the issue of sticking the strip. The strip is flat so you would need something to make the strip face outwards, rather than the bottom/top of the headlight assembly as the case maybe.
Regarding the cost, since I get these in dont know if I'm allowed to put up the cost here; but 1900 is a BIT on the higher side, wont be much of a difference otherwise.
anantnehru is offline   Reply With Quote
Old 2nd December 2008, 16:53   #74
shyamhegde's Avatar
Thanks Anant. So the way Dilip got it installed makes sense. Only I hope, it won't be visible too much during day. prices of all these accessories are low in Delhi as compared to other places as i have observed. So, anything that is 'bit' over the Delhi price should be alright.
Old 10th June 2009, 18:53   #75
Sportsmind's Avatar
Thanked: 28 Times
Cool I use the maximum led lighting, i guess so
I have shifted to maximum led lighting in my drive, and i thought i should share it here. Find the pics of the led powered drive. The tails have led on all its sockets.
Comments pls on Led Fog lamps, the blinklights stuff. Has anyone used them.
Sportsmind is offline   Reply With Quote
Auto Lighting thread : Post all queries about automobile lighting here Chevy Modifications & Accessories 10837 10th December 2017 21:00
LED Lighting Conversion for your Two Wheelers pssmath Motorbikes 35 29th August 2017 09:57
Review: Osram LED Ambient Lighting Kit smartcat Modifications & Accessories 15 19th August 2017 21:45
Instrument Panel RGB LED Lighting goelvaibhav Technical Stuff 17 13th August 2014 23:46
Audi's new matrix LED lighting & the NHTSA's dilemma! nitin.rai The International Automotive Scene 1 2nd January 2014 21:30
