Old 2nd March 2010, 21:10   #106
vaisakhr's Avatar
Thanked: 136 Times
Originally Posted by shyamhegde View Post
You do not get more than a half watt in that' package' and the price you mentioned. Good ones. Do not cut the leads too short in your application, as it uses them as heat sink also.
Thanks, It was not in package, but in loose. I bought 10 nos.
vaisakhr is offline   Reply With Quote
Old 5th March 2010, 02:16   #107
torque.steer's Avatar
Thanked: 7 Times
hey i wanted to know that how much would LED cost in new delhi.. (karol bagh).
and are they sticked outside the headlights through double sided tape? if yes don't they get affected by the rain or dirt ,doesn't it start coming off ??
torque.steer is offline   Reply With Quote
Old 5th March 2010, 06:05   #108
vaisakhr's Avatar
Thanked: 136 Times
You are referring to led strips. It is coated with pvc so that makes it water proof.
Here in Kerala a pair of led strip costs Rs.650/-
Old 5th March 2010, 07:24   #109
greenhorn's Avatar
Thanked: 1,316 Times
vaisakh, when you say package for an electronic device, you mean the shape/size in which it was made
Old 5th March 2010, 15:46   #110
Thanked: 7 Times
thanks for the information vaisakhr. do you have any idea about the thing that LED bulbs also cost per piece, any idea how can they be used and about their cost ???
Old 5th March 2010, 16:18   #111
Thanked: 40 Times
Hey guys,
I am very keen to get these LEDs to my ANHC. would somebody help me out please.
I would be very nice if somebody could spare a little time and help me in this.i stay in Bangalore.
nandans2005 is offline   Reply With Quote
Old 5th March 2010, 20:51   #112
vaisakhr's Avatar
Thanked: 136 Times
Welcome.
Its costs Rs 16/- per led. A friend of mine is working on the circuit, which will give 3.2V per led. It will be ready by tomorrow.
And about the position I haven't decided yet. I am thinking of placing 2 set in the bottom grill near the fog lamp. Can anybody give some good suggestions?
Old 7th March 2010, 04:52   #113
ghpk's Avatar
Thanked: 192 Times
Welcome.
you should use a 150 ohm or 220 ohm resistor, as i've been using L.E.D. in car extensively for over 2 years now, and keeping a nice resistor will certainly give longer life to L.E.D. else in a few days the 3 L.E.D.'s will start blinking and them burn out.
Rs.16/- per L.E.D. looks like little expensive as compared to price i get in local market here, but i checked today itself, these types are not yet rolling here.
Old 7th March 2010, 05:13   #114
Thanked: 7 Times
Welcome.
hey u can try even i am thinking of putting it there
few car's bumpers have gaps in them i mean thats the design so put a nice mesh grille there and put LED'S behind them it will look awesome..i hope you got what i said..
Old 8th March 2010, 22:41   #115
vaisakhr's Avatar
Thanked: 136 Times
Update
Made a circuit which will throwing 3.6V per led, and lite it up for 1hr and went for food. When we were back those were gone kaput. It was too hot. So decreasing the voltage and the brightness also decreases viz.
Old 8th March 2010, 22:57   #116
greenhorn's Avatar
value of resistance = ?
you do not set a voltage for LED's - the LED's dont like being told what voltage to work at :P
rather, design for a particular value of current
Old 9th March 2010, 09:44   #117
devrajman's Avatar
Thanked: 116 Times
There are LED strips available in market. I seen it once in a car. I has very small LEDs like the ones in mobile and its properly shield.
What exactly it is and not preferred over own circuits? Any idea how much does it cost?
devrajman is offline   Reply With Quote
Old 9th March 2010, 20:14   #118
vaisakhr's Avatar
Thanked: 136 Times
I don't like it because it being so small. The light spread by those are very small, and personally i don't like the way it looks.
Those are usually detachable pair of 3 leds. It cost some Rs.600/- per M.
Old 4th April 2010, 23:50   #119
iamback's Avatar
Lightbulb LED Numberplate Light on My Scooty PEP +
Hey guys, got inspiration from all of you and created a Number Plate Light for my Scooty Pep+. I know its not a car but i thought first i will try on my pep+ and then after on my car. So here are the list of things required and total money spent.
Things Used :
  • 6 LED's (Rs.18)
  • 6 Resistors (Rs. 06)
  • Wire (Rs. 10)
  • Solder Wire (Rs. 20)
  • Insulation tape (Rs. 20)
  • Miscellaneous (Rs. 06)
Total = About Rs. 80
I am adding all the photos of my DIY. Sorry for the picture quality as they are taken at night and from my Nokia E71.
Things Used :
LED circuit
Front Side
Number Plate light removed
Connecting the Light to the port
Connection of the light to the stock Port
Testing it before Finishing.
Finishing
Looks of the bulb when in off mode.
Do remember to send me your suggestions and comments.
iamback is offline   Reply With Quote
Old 5th April 2010, 01:04   #120
ghpk's Avatar
Thanked: 192 Times
I recently purchased this Blue SMD L.E.D. Strip @ Rs.450/meter
1M = 60 LED's can be cut for each 3 LED to work on 12volts.
Auto Lighting thread : Post all queries about automobile lighting here Chevy Modifications & Accessories 10842 13th December 2017 13:40
LED Lighting Conversion for your Two Wheelers pssmath Motorbikes 35 29th August 2017 09:57
Review: Osram LED Ambient Lighting Kit smartcat Modifications & Accessories 15 19th August 2017 21:45
Instrument Panel RGB LED Lighting goelvaibhav Technical Stuff 17 13th August 2014 23:46
Audi's new matrix LED lighting & the NHTSA's dilemma! nitin.rai The International Automotive Scene 1 2nd January 2014 21:30
