Wheel JAMMED.....
https://www.team-bhp.com/forum/technical-stuff/15022-wheel-jammed.html)
i have a M800 which i had bought from a friend of mine for my sister coz she wanned some vehicle on which she can lern driving and my City was a sure NO NO...
so since last 3-4 months the car is just lying idle the right rear wheel is jammed i donno why and what caused it as when i had driven it months back it was working fine.....
What should i do bout it....
Well buddy, that you will come to know only after removing the wheel from the hub. May be because of the hand brake or rust etc etc...
az
Was the hand brake engaged for the last few months when it was lying idle?
cya
R
Originally Posted by ~ H O N D A ~ i have a M800 which i had bought from a friend of mine for my sister coz she wanned some vehicle on which she can lern driving and my City was a sure NO NO...
What should i do bout it.... |
Nothing to worry about. Its a very minor problem. Get both the wheels/brakes serviced and you will be fine.
Viper
second Vipers opinion. it must be jamed due to rust of something. I was once told to free parts off, pour some kerosene onto it. helps free stuff. take off the wheel and get a mech to check it out, keep some kerosene handy!
you may not believe this, but a turkish fitter at sea once told me that cola (the same infamous brand which supposedly dissolves teeth dopped into it!) works as a good alternative to penetrating oil (WD-40 etc) , have tried it once- and seemed to work!
though mind you, i wouldnt recommend it on your wheels! would have to rinse off the stick residue for sure!
hey man i had the same problem in my 800 not a problem at all try driving ahead and then reverse keep doing it a few times it will get free it is caused due to the hand brake when it is engaged for too long!have fun!
had tha same probs with my fiesta wheels were in water during the recent deluge in mumbai and the handbrake was engaged and the car was parked till 2 days back had to make the building gurkha to push the car while i gave throttle(just a bit ) and the wheels were free now running just fine:)
thanks alot guy for your help...
I'll try the things tomorrow and let you know the results
