Old 30th April 2014, 08:45   #31
::CMS::'s Avatar
Thanked: 470 Times
Default Re: Highway fuel economy less than in the city - Why?
Originally Posted by EcoBeast View Post
why would the clutch have wear and tear while rotating freely in neutral?
To shift to neutral and to another gear you need to use clutch twice, right? Instead, let the transmission do its duty and eventhough if you feather the accelerator to keep the momentum, engine load will be ~25-35% (depends on the gear and rpm).
::CMS:: is offline   (1) Thanks Reply With Quote
Old 30th April 2014, 09:10   #32
Thanked: 14,604 Times
To each change to 'neutral' from the gear that is being used the clutch needs to be (pressed and released) - 1st time.
Then to get onto the required gear the clutch needs to be (pressed and released) - 2nd time.
The first gear change set will not be that harmful as theRPM of theengine willdrop from 'X' RPM to idle RPM within seconds.
But the second one is where the car speed + engine RPM needs to match with the 'right' gear and to do that without jerking is a bit difficult. That jerk will be grinding the clutch and it's other parts leading to greater wear and tear.
I have seen drivers hold the clutch pressed and forcefully shift to the required gear and hold the clutch pressed. When needed they release it fast and at a go without trying to match the revs for a smooth shift. This causes load on the transmission to damage if done regularly.
Hooe this helps!
+1.
PS: Sorry MODS for going OT!
Anurag.
a4anurag is online now   (1) Thanks Reply With Quote
Old 30th April 2014, 13:53   #33
EcoBeast's Avatar
Thanked: 112 Times
Hooe this helps!
Anurag.
Yep. That's make perfect sense. That is exactly how I believed it works.
The point here is that, it's not the neutral driving that causes load on the engine. The real culprit is 'an improper step-2' which, if executed correctly, will not hurt the clutch plates & pads that much.
I thought the OBD data collected by CMS showed that the engine was under load WHILE in neutral. Which didn't seem to add up.
I think we are all on the same page now.
Thanks for the clarification.
EcoBeast is offline   Reply With Quote
Old 30th May 2014, 18:08   #34
ashlyak's Avatar
Thanked: 22 Times
Dear All,
Thanks a lot for the inputs!
Sorry, I was not able to reply in time, since I was banned for few days.
Would like to update that, my issue is now resolved, and I am able to get 22 km/l on highways.
ashlyak is offline   Reply With Quote
Old 30th May 2014, 18:41   #35
Good that the FE is back on track. May we all know how was the issue solved and how are you now achieving 22 kmpl?
Anurag.
a4anurag is online now   Reply With Quote
Old 30th May 2014, 19:59   #36
nim_peter's Avatar
Thanked: 98 Times
Mod Note : Post deleted.
Team-BHP strongly discourages unsafe driving practices that put yourself and other road users at risk. Please do NOT post about illegally high speeds on public roads.
We advise you to read the Forum Rules before proceeding any further.
nim_peter is offline   Reply With Quote
Kumaon: roads less traveled and forests less visited nilanjanray Route / Travel Queries 21 11th January 2013 12:25
GM India - Hope less? or Aim less? or both? rnidumolu The Indian Car Scene 16 17th September 2012 15:12
Why do we have less Fuel Efficient cars in India ? Karandeep81 The Indian Car Scene 25 14th June 2007 15:22
Why shouldn't I buy Tata Indica (Diesel) for less than 600 KM/Month running skamb Hatchbacks 14 6th August 2005 08:09
A8 for less than the E,what is EcoTimes talking about _Crazi4Speed_ The Indian Car Scene 11 18th April 2004 05:12
