Old 27th December 2014, 11:58   #31
deepfreak15's Avatar
Thanked: 316 Times
Default Re: Brakes - A few tips that could help
I own a GT TSi that has done 12k Kms. With normal city driving the brakes are just fine. However once the brakes heat up even slight pressure on the brake pedal causes sever juddering (usually at speeds above 110 kmph). Whats weird is even if I break at 140 kmph there is no juddering if the brake temperature is normal. Its only when the temperature increases this occurs. The VW center guys say that even skimming wont help..not sure what to do now
deepfreak15 is offline   Reply With Quote
Old 28th December 2014, 19:08   #32
Thanked: 14,594 Times
I guess the thing that you are encountering is brake fade where the brakes won't be effective once they get hot but on normal temperature they work normally.
Anurag.
Old 28th December 2014, 19:56   #33
audioholic's Avatar
Thanked: 6,105 Times
Thats not something to do with brake fade. I face the same issue in my SX4 and the characteristics are the same. Upon spirited driving on the highway and after a round of few hard braking cycles, the brake disc heats up and the pedal judders like crazy even with the slightest braking. If driven sedately on the highway, with less brake usage there is no issue at any speed.
The service centre owner whom I spoke about this issue told that this is due to minute imperfection caused when only a few areas of the brake disc will rust. This minor imperfection becomes more prominent as the brake disc heats up since the metal may expand. He told skimming wouldnt work unless its done in a real precise manner. Hence I decided to change the brake discs this service since it doesnt cost much at all. A set of brake disc and pad will solve the problem I am told.
Moreover, another issue with us is since the car isnt driven daily, the discs will undergo irregular rusting on places exposed to air while the part of the disc covered by the caliper would rust less. Hence these days I use the car for a bit after its washed to get rid of moisture from the brakes.
audioholic is offline   (1) Thanks Reply With Quote
Old 28th December 2014, 21:41   #34
Santoshbhat's Avatar
Thanked: 3,885 Times
You can try bleeding the brake lines and replacing the brake fluid. Brake fluid over time absorbs moisture which reduces its boiling point as a result it vaporizes and doesn't provide the pressure that it ought to. I had experienced a sort of grinding noise while braking, only when the brakes were hot with my Laura. Brake fluid replacement completely solved the problem. Of course I also replaced pads at the same time. Its worth a shot before you try anything else as shot as brake fluid is quite cheap.
Santoshbhat is online now   Reply With Quote
Old 2nd January 2015, 19:28   #35
VeyronSuperSprt's Avatar
Thanked: 1,664 Times
1. Repace your pads and rotors.
2. Read the OP again as it covers the very same issues you are facing and are also likely to face even after you change the rotors and pads.
VeyronSuperSprt is offline   (1) Thanks Reply With Quote
Old 2nd January 2015, 19:50   #36
Samba's Avatar
Thanked: 6,029 Times
I had the same problem. You can find my post in the very first page of this thread. At that time, this was the reply i got from - VeyronSuperSprt
Originally Posted by VeyronSuperSprt View Post
This is something that most ASS's do. However, Insist that you want the rotors and pads replaced under warranty and that the car is not comfortable to drive at 120 kmph. Depending on the amount of pressure you put on them, they will agree to replace your pads. It is certainly not advisable to continue with the current level of judder as it will gradually increase with time.
That time my cars odo reading was at 31,000kms. At 34,000 kms i changed the brake pads and both the rotors. My problem is 100% solved now. At any speed i apply the brakes there is absolutely no judder. I have tested applying the brakes nearing the cars top speed too but its absolutly fine.
So from my experience i will suggest you to replace the brake pads and rotors.
VeyronSuperSprt, i should have replied to this thread after i changed the parts but i totally forgot to do so. My bad. But now i want to thank you for your valuable suggestion, it helped me.
Samba is offline   (1) Thanks Reply With Quote
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
Magnetic Non Friction brakes, could it be the future? Shan2nu Technical Stuff 2 12th February 2010 15:11
A few useful tips on Safe Off-Roading DKG 4x4 Technical 27 9th October 2009 21:42
Could someone identify a few songs for me? Sheruken Shifting gears 5 28th July 2004 18:58
