Closed Thread
Old 10th July 2011, 10:52   #31
aks2010's Avatar
Thanked: 13 Times
Default Re: Upgrading stock headlights - confused
I would like to upgrade the headlights of my Swift VDi to 100/90. Which bulb should I use and how much would it cost?
aks2010 is offline
Old 10th July 2011, 11:14   #32
Thanked: 113 Times
For those that do not want to upgrade to 90/100 to void warranty or legal issues, here are the alternatives.
1. Add non yellow auxiliary lights for fog conditions with wide beam spread. Something around 4300K is best. (I intend to do the same as soon as I change the front bumpers). Combined with high beam in difficult conditions, the visibility provided by spare lights might improve confidence and also provide a backup in case main headlights conk off unexpectedly.
2 Philips extremevision 100+. I currently use 80+ and I have spare bulbs so can't upgrade to these yet :(
3. Hella or AutoPal Headlamp assembly. For example AP promise 40% more light over stock Lumax etc. http://www.autopal.com/HedLamp%201.html
Careful: There are also "duplicates" branded as AutoLAL for the unsuspecting buyer.
--Ragul
Ragul is offline
Old 10th July 2011, 12:43   #33
S.I.N.G.H's Avatar
Thanked: 40 Times
sir, i would recommend you to go for philips extreme power. it increases the visibility 25-30% more. it would cost you somewhere between 900-1000 bucks. its worth paying that much money. you wont need a relay for this and there would be no issues with the headlight cluster fading or melting.
S.I.N.G.H is offline
Old 10th July 2011, 22:41   #34
Thanked: 381 Times
Xtreme Power have been officially discontinued as per the info given by The Philips distributor in Mumbai and Bangalore.
Use Xtreme Vision instead (+100%) - they cost around Rs.900 for a pair!
keyur is offline
Old 12th July 2011, 01:26   #35
khoj's Avatar
Thanked: 1,258 Times
I am using Xtreme Vision H4 55/60W from Philips (made in Germany) in my Cedia and the Night breaker H4 55/60W from Osram (also made in Germany) in my Swift Zxi and the Nightbreakers are far superior in terms of the intensity, throw and brightness of the light beam, this when the Cedia has the better electric system of the two cars.
Both makes were sourced from the local markets via the company's authorized dealers. The Osrams at Rs. 1400 were Rs. 500 more than the Philips @ 900/- but worth the difference. Just wanted to share this with all of you guys who are considering an upgrade and may have to choose between the two options.
khoj is offline   (2) Thanks
Old 12th July 2011, 02:23   #36
Thanked: 381 Times
Is the white light of the NBs good in rains, fog and in street lighting? When I tried these, though the intensity was much more, the white light was not very effective when it came to sodium vapur street lamps (yellow)
keyur is offline
Old 12th July 2011, 02:30   #37
khoj's Avatar
The advert says "whiter' light or 'more white than others' and it is just that. It is actually yellow but more intense or should I say more dense for the lack of a better word. EDIT I think I meant to say 'brighter'.
Excellent in fog and under the sodium vapour lamps especially the yellow ones (which unfortunately prevail in our cites) wherein the Xtremes are just a lost case on a well lit road. In the sense it does not matter whether you have them on or not which on the flip side allows one to drive on parking lights thus easing the load on the battery (sorry OT).
The NBs were pretty good in the two monsoons that my Swift (MH 06) spent here before being bundled off to NCR. I am having a harrowing time with the Cedia in the current rains especially at dusk and on speeds in excess of 80~100 on the Xpressway when it is pouring.
khoj is offline
Old 12th July 2011, 07:02   #38
dot
dot's Avatar
Thanked: 714 Times
Thanks for sharing. As you know, during rains, Civic's stock headlight simply give up. I am planing to change all the six bulbs (low, high and fog). Civic needs H7 bulbs for the low and high and H11 for foglamps. Osram's website says direct replacement, relays not needed. Is it true from your experience?
dot is offline
Old 12th July 2011, 09:45   #39
LNK
I was initially using a Hella 100/90 with a relay. Found them pretty good, recently when I'd gone to buy a pair of aux lamps, to help in the rains, I was told that my Hellas were fake! (Apparently the bulbs need to come with a print stating "Germany", can someone confirm on this?)
Now I'm using Flosser 100/90. I find it brighter than the Hellas. Cost was Rs 600 for a pair.
LNK is offline
Old 12th July 2011, 15:36   #40
khoj's Avatar
Hi dot,
As long as the wattage of the new bulbs is the same as the OE bulbs you do not need a relay. The industry standard is 55W for low beam and 60W for the High beam. Fog lamps wattage can vary from one OEM to another but you can refer to the owner's manual for that.
khoj is offline   (1) Thanks
Old 13th July 2011, 10:09   #41
bnzjon's Avatar
Thanked: 125 Times
OSRAM Night Braker 'Plus' is availabe now in Indian market. Cost is Rs 800 per pair of H4.
NB+ has much much longer beam than stock. Light is slightly whiter. Specifications are same as stock one.
NB+ is an improvised version of NB.
bnzjon is offline
Old 13th July 2011, 12:50   #42
Thanked: 312 Times
Dot, your query to whether you need a relay or not has been answered, yes you will need one if you are going high wattage, but unfortunately we dont have high wattage after market bulbs for our civics (as per my info), it is very dis-heartning firstly that the company has given such low watt bulbs and secondly none of the after manufacturers have come out with a good high wattage bulb, knowing there are so many civics on the road.
I do lot o interstate and usually night drives, Delhi Mumbai 1500 odd kms, i have spent a lot on various bulbs and HID kits, also the civic seating is low so even a on coming car which is a Santro is straight into your eyes makes it more difficult for OEM wattage bulbs, you will come down to a speed of 30-50 speed as you cant see.
if you are willing to spend do you low beam HID, I would recommend P4 4300 kelvin as it is yellowish and which comes as stock in Audi's. Skoda etc. They are not the show HID's as anything above that is good for the looks but not as a light performance, It will cost you around 9K with one year warranty, though its been 2 yrs and i had no replacement whatsoever.
My 2 cents for you, hope it helps
The Saint is offline   (1) Thanks
Old 13th July 2011, 14:28   #43
Thanked: 381 Times
I find this surprising. The last I checked with the distributor, the NBs were available for around Rs.800 per piece (1600 per pair). Your pricing is half of that!
Please provide the vendor details. Also ensure that they are not fakes / cheap imitations!
keyur is offline
Old 17th August 2012, 14:30   #44
mac187's Avatar
Thanked: 333 Times
I had installed Philips Extreme vision last April. Yesterday when I was driving, first the right headlight gave away and 10kms later the left one gave away too. Looks like I got conned. Do headlight give away in just over a year? This one had relay too!
mac187 is offline
Old 17th August 2012, 15:23   #45
desigNation's Avatar
Thanked: 46 Times
hello anybody , i would like to change my toyota corolla bulbs to 90/100 , is there anyway i can do it? because availability in my home town [calicut] is next to nil .
desigNation is offline
Closed Thread
Upgrading Speakers : Confused between Pioneer Co-axials v/s JBL Components yogeshnagpal In-Car Entertainment 6 11th June 2011 21:46
want to change my 124 stock headlights to clearlamps imported from taiwan rah1735 Modifications & Accessories 3 11th March 2009 14:29
Getz Prime Headlights. Upgrading to Xenons.Help needed wmax Technical Stuff 17 3rd February 2009 16:20
Zen headlights Confused ! nicejits Modifications & Accessories 5 20th November 2007 11:44
