Closed Thread
Old 19th August 2012, 01:01   #46
Thanked: 181 Times
Default Re: Upgrading stock headlights - confused
Hi everybody
I too would am interested in upgrading my headlamps as I find it difficult to drive at night.Due to this reason whenever I go on a crosscountry trip I call it a day just about at the time of sunset.
I have a Beat with OEM lamps which I think are 55/60.Instead of adding another pair of headlamps would prefer better bulbs.What safe choices do I have and how do I go about it?
Thanks a lot and regards
faustus77 is offline
Old 25th February 2014, 18:57   #47
girishglg's Avatar
Thanked: 426 Times
I would like to upgrade the stock headlights of my M800 since it is quite adequate. Please suggest the various options available and its cost and the best option in your view.
girishglg is offline
Old 25th February 2014, 19:00   #48
kutlee's Avatar
Thanked: 202 Times
Please check out the hella 500ff. There is a separate thread for that.
kutlee is offline
Old 25th February 2014, 19:28   #49
girishglg's Avatar
Thanked: 426 Times
Not sure if this was intended to my query. However I would like to upgrade the stock headlights in terms of bulbs or wattage etc and not add on another set of lights.
Hence suggestions on that end is welcome.
Old 28th February 2014, 04:13   #50
Thanked: 14,610 Times
The stock ones are 35/35W or 60/55W?
Whatever is the upgrade please don't cross 100/90W as the reflectors will blacken and eventually destroy due to the heat produced. I have seen cases using 130/100W setup and havibg the reflector turn blank in a few months of usage.
I urge you to try Phillips Xtreme Vision 60/55W or Osram NB 60/55W.
I will be upgrading the bulbs to Philips in a few days (Stock rating).
Anurag.
a4anurag is online now   (1) Thanks
Old 30th August 2014, 23:52   #51
Eddy's Avatar
Thanked: 5,078 Times
Note from Support - Please continue on the following thread.
http://www.team-bhp.com/forum/modifi...ting-here.html (Auto Lighting thread : Post all queries about automobile lighting here)
Eddy is offline   (1) Thanks
Closed Thread
Upgrading Speakers : Confused between Pioneer Co-axials v/s JBL Components yogeshnagpal In-Car Entertainment 6 11th June 2011 21:46
want to change my 124 stock headlights to clearlamps imported from taiwan rah1735 Modifications & Accessories 3 11th March 2009 14:29
Getz Prime Headlights. Upgrading to Xenons.Help needed wmax Technical Stuff 17 3rd February 2009 16:20
Zen headlights Confused ! nicejits Modifications & Accessories 5 20th November 2007 11:44
