| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #16 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ Psycho Modding != idea + <ctrl-c> + <ctrl-v> Modding = idea + <ctrl-c> + <ctrl-v> + Finagle's Law of Dynamic Negatives | |
| | #17 (permalink) |
| BHPian | psycho - to reduce the amount of air drawn in through the new vent - what I have done is make a pinhole for the vacuum suction. this happened by chance as the T-piece connector i bought had one end closed shut (during the moulding process) - so i pierced this end with a pin to make a 1~2 mm hole and thats what the ozone (or air!) is being sucked through. As a result - the vacuum is very slight. I suspect that I'll have to check it in a few days and might find it choked! ![]() |
| | #18 (permalink) |
| BHPian | Good experiment, and nice to know this has caused increased power to all who have tried... Just one concern cropped up.. You are connecting the Distributor box to the inlet of the engine.. Does any one see red here! Commutator produces lot of carbon dust, which is very hard and abressive, and this is being let into the engine through a pipe . This beats the purpose of the airfilter in place.
__________________ _____________________ 2004 Fiat Petra 1.6, 100 16V 2008 Suzuki swift ZXi |
| | #19 (permalink) |
| BHPian | Thanks DRC. made me think. Isn't Carbon highly flammable in powder form - and considering the high temperatures in the cylinder - what are the chances it'll burn up (adding calorific value) as opposed to increasing weardown on components? One could probably put a line filter (easily available / can fabricate with cotton and a tube) on the suction line to address this concern. Just two members have tried this so far (to my knowledge) - lets get in more criticques and pros / cons to this experiment. The good part - the set-up is very easily reversible - 2 minutes and at no cost. |
| | #20 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Hi all, One probable reason for FE gain using ozone may be we are leaking (adding T connection) the vacuum...hence air fuel ratio becoming lean....but we dont feel lack of power with such vacuum leak as now ozone is being sucked into the engine which increases performance.....so we are getting advantage of running car at leaner ration without degrading the performance...... There are many sources of vacuum....which one will be best can be decided by trial & error...earlier I directly connected ozone pipe to base of carburetor ...then checked by making "T" to this existing line.....as per the 1/4th tank consumption...and if my gas gauge is accurate & my reading is accurate then I m on upside of FE till now.....regarding the performance....feeling moderate increase in power..... Rightly said captain ping that if we want to revert to oroginal setting...it takes 2 minutes...without any trouble.... Enjoy.... |
| | #21 (permalink) |
| BHPian | Interesting experiment guys, but the "engineer" in me is playing spoil sport! :( I'm wondering: 1. What is the rate of Ozone production in the distributor? Is this enough to make a *significant* difference to the mix the engine is already burning? 2. Is the perceived improvement in performance because of less resistance during air intake? This kind of boost would come into play if one removed the air filter and retuned the carb. to compensate for the leaning out of the mixture. (Engine won't last too long this way though!) Can some of the guys / gals gifted with better math skills than I am work out the calculations for us? - T u r b o C - |
| | #23 (permalink) |
| Hi, So finally my gas tank was empty at 620km for 45kg of lpg.......earlier when I last refilled I got 545......this is after this ozone generator technique......driving remaining the same......also I made precaution not to touch carburetor setting or anything.....tyre pressure 30 all tyres.....expecting now to get 600+ consistantly......lets see.....after this tank reading I plan to run car without ozone technique full tank so that I can come to the conclusion......but its very difficult as no driving is same every day.....all this is only as & when it occurs basis.... |
| | #24 (permalink) |
| Senior - BHPian Join Date: May 2005 Location: TRV
| A lil doubt... won't we get better fuel efficincy just like this if we leave a vaccum line open to suck in more air to create a lean burn condition? Captain Pings said his Gypsy was heating up now quicker...doesn't a lean condition cause this? Isn't the lean burn condition the major cause for the improved fuel efficiency? Considering the jetting is un-altered. The stock jetting is usually on the richer side on a stock car and a little air bleed probably helps it to burn more efficiently and of course a bit more power is produced and more heat. I'm skeptial about the Ozone though. I liked the idea. |
| | #26 (permalink) |
| BHPian Join Date: Jun 2005 Location: ERNAKULAM
| The lowest prssure when compared to atmospheric pressure is where the velocity of the incoming air is the highest and in carb based cars and also injector based cars the highest velocity is aft of the edges of the butterfly valve in case of carbs and butterfly valves again in case of throttle body of fuel injected cars. It is the sudden change in direction and concommitant increase in velocity over the top side of the wing of aircrafts that makes the wings get sucked up into the thinner atmosphere above the wing of the aircraft. If you thought that air prssure flowing under the wing pushed the plane up you are wrong and it is reduced prassure that sucks up the wing. So coming to your particular query fine tuning any whole drilled just aft of the butterfly valve should have the highest vacuum pressure. I am using the acetone in my diesel car and touch wood I am getting about 40 to 50 km extra per full tank. The petrol car did not gain any reportable figure more so because I do not have throw away cash to fill a 16 year old vehicle to the brim for testing but the knocking has reduced drastically. Thanks. Bye and wear your seatbelts |
| | #27 (permalink) | |
| BHPian | Quote:
__________________ "The greatest trick the devil ever pulled was convincing the world he didn't exist ." | |
| | #28 (permalink) |
| Dear drpullockaran, i want to hook the pipe to any existing vacuum line....earlier I tried bottom of carburetor without T joint....then with T joint I got good mileage......but still I want to try different vacuum source.....one at delco end is having vacuum...but i m worried if I make T there I might affect the ignition timing setting....any vacuumm leak at this end will affect firing of plugs.... keep using acetone....its so good to hear that using such simple additive u are getting 60Km+....will u share this translates into how much % gain apart from good throttle response & power? One more suggestion for ur old car.....if u found no knocking using acetone then keep changing the ratio...2ml...2.5..3..3.5 ....to check which is best for ur vehicle....this will not harm anything...beleive me...I m using it in old fiat premier padmini 87 model & getting very good benefit.... Enjoy.... Last edited by finetuning : 27th July 2006 at 00:33. |
| | #29 (permalink) |
| Ozone Update....... After using ozone from distributor cap & finding benefits......I tried countless time to check whether ozone thing really works or not by disconnecting the T joint & making usual vacuum connection & I found less power........I repeated this exercise to come to the conclusion that ozone is making improvement in performance as well as FE...............many time I thought that making a vacuum leak might improve the FE but what about the added power I m getting with ozone....so I ruled out that its not lean mixture that improves FE but essentially ozone............ Once we are addicted to higher torque then its difficult to discontinue any such practice............I made one thing sure that whatever car I will have in future....acetone...2T...Somender Grooves....& ozone is a must to improve whatever torque we have.........some one said in this forum that there are millions of techniques to improve performance of a car on the web...........so here is my effort to find a few which really helps in positive direction at no extra cost helping curbing pollution too..... Enjoy...... Last edited by finetuning : 1st October 2006 at 16:15. |
| | #30 (permalink) |
| Dear all, Recently I made ozone treatment with one of my friends old maruti 1000.....made a drilled hole in distributor cap & inserted a vacuum pipe.....connected this to intake manifold vacuum through T joint......results are wonderful........he checked mileage with 1 liter bottle making sure carburetor is totally petrol free & FE is 15 kmpl with two person driving without addition of any additives.....there is increase in power as well as FE........this is wonderful technique of leaning the mixture without affecting the performance......but we need to check at various vacuum available in different cars... Encouraged by his results I decided to find another vacuum source in my esteem & I tried making T joint at another location.......so far results are encouraging.........indication of yet higher FE as my first LED of lpg gas went off after 300KM......will share exact data after tank is empty.........FE calculation with my LPG is pretty accurate as I used to drive till tank is empty & car stops on the road......I have taken care of petrol driving with these figures.... Enjoy.... Last edited by finetuning : 1st January 2007 at 23:49. |
« What is Teflon Coating and does it really help?
Grinding noise coming from the front brakes of Swift Vxi when rolling back »
| Thread Tools | |
Similar Threads | ||||
| White alloys for swift ozone blue VDi | GeekSrik | Tyre & Alloy wheel Section | 47 | 23rd December 2008 14:50 |
| yokohama distributor/dealer in Delhi? which ply tyre? | sat | Tyre & Alloy wheel Section | 17 | 12th September 2008 16:02 |
| Distributor coil problem | xor83 | Technical Stuff | 0 | 26th September 2007 18:37 |
| Help Needed - Distributor Cap damaged. | manveet | Technical Stuff | 0 | 26th December 2006 14:18 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
