| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #31 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Hi all, I think this is the thread in which I can share my latest FE........after changing the T connection of the ozone treatment I was expecting more FE as indicated by my lpg indicators.....as I mentioned in my last post my first LED went off after 300 km....... Finally my tank is empty at 880 km translating into FE of 19 kmpl........ Changes I made compared to my last lpg refill were....adding boric acid powder in petrol tank & changing T connection as mentioned above......now I m infact puzzling which is maing more difference...... I will share photo soon with new ozone connection......one thing is sure this is making air fuel mixture lean but then there is no loss of noticeable power.........so I assume that ozone is really very effective.... There are many vacuum sources in my car......And each one for the purpose of ozone experiments behaves differently......I m happy right now with current setting..... Enjoy... Note from the Team-BHP Support : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks. Last edited by Aditya : 11th October 2008 at 09:11. |
| | #33 (permalink) |
| Hi Ravi, Let me clarify on vent, there is already a vent in distributor cap for releasing ozone gas. If we use this vent for connecting vacuum pipe then spark will be scattered inside distributor as we are creating a kind of vacuum by sucking ozone gas. We naturally dont want this. We want spark to occur normally and to suck ozone hence another vent needed. This is such a wonderful and very effective technique of increasing FE and power as well. You will need 2 piece of rubber vacuum pipe both 2 feet long and a plastic T connector. You can take help of your local mechanic to identify vacuum source. Remember we want ozone to go into combustion chamber. Enjoy. Last edited by Aditya : 11th October 2008 at 09:13. |
| | #35 (permalink) |
| BHPian Join Date: Jul 2006 Location: pune
| if u fit the distributor breather to the the air filter then ull be sucking dry ,filtered air to the distributor, then suck ozone with it in the engine through the vacuum line, there will be less dust moisture and pitting in the distributor too!!! Last edited by Aditya : 11th October 2008 at 09:09. |
| | #36 (permalink) |
| BHPian Join Date: Mar 2009 Location: Bangalore
| Years have passed by..... ![]() All you ozone users want to add some of your experiences?? ![]()
__________________ Take Care....Drive Safe Devang 1999 Suzuki Zen Lx 1985 SS80 DX M800 1990 Kinetic Honda DX 2000 Hercules EZY Cycle 18-Gear |
« What is Teflon Coating and does it really help?
Grinding noise coming from the front brakes of Swift Vxi when rolling back »
| Thread Tools | |
Similar Threads | ||||
| White alloys for swift ozone blue VDi | GeekSrik | Tyre & Alloy wheel Section | 47 | 23rd December 2008 14:50 |
| yokohama distributor/dealer in Delhi? which ply tyre? | sat | Tyre & Alloy wheel Section | 17 | 12th September 2008 16:02 |
| Distributor coil problem | xor83 | Technical Stuff | 0 | 26th September 2007 18:37 |
| Help Needed - Distributor Cap damaged. | manveet | Technical Stuff | 0 | 26th December 2006 14:18 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
