Old 15th July 2006, 18:25   #1
Question New Indica Turbo - is the turbo on?
Hi Friends,
When I drove the test vehicle, I had enjoyed the turbo power which kicks in at around 2000 rpm.
Got the new Indica turbo last week. In my new car, I dont find this turbo lag at all! Its the same with my friend who also bought a turbo on the same day!
There is a strange rattling noise from engine bay while idling when I start the engine in the early morning. This rattling idling noise goes away after driving for 15 minutes.
Do you have any experiences to share before I head to the service station?
Thanks for your help!
best regards
Ganesh
Note from the Team-BHP Support Staff : This topic has been moved to the appropriate section.
We thank you for your thread, and would appreciate you taking the effort to post in the correct section.
gakudva is offline   Reply With Quote
Old 15th July 2006, 19:20   #2
nitrous's Avatar
Thanked: 285 Times
Isn't that a good thing??
Old 15th July 2006, 19:34   #3
condor's Avatar
Thanked: 4,897 Times
Ganesh, diesels need the warm-up. The engine will become smoother and quieter once it warms up. So what you notice is normal.
Open the driver's door, and you should find a sticker that says you need to idle the engine before switch off and after starting the engine. This idling will warm up the engine after you start it.
Old 15th July 2006, 22:26   #4
Well, if there is a turbo without lag its great (I also heard that the lag cannot be eliminated in turbo engines). I dont feel high torque at all. That makes me suspect if there is any turbo power!
Old 15th July 2006, 22:28   #5
Hi Condor, thanks for the answer. Smoother and quieter with time is okay. But, there is a metallic noise when I start. I also had a look at other Indica which was not turbo, it also makes a noise but not as the metallic noise I hear in my car :(
Old 15th July 2006, 23:00   #6
wolfinstein's Avatar
could you record that sound with your cell or so...! What kind of metallic sound are we talking about here...!
wolfinstein is offline   Reply With Quote
Indica Xeta LPG or Indica Turbo Diesel?? nobreaks Hatchbacks 12 1st September 2006 23:29
Indica Turbo or Indica Xeta BNB Hatchbacks 6 23rd April 2006 11:19
