Old 11th July 2015, 10:51   #196
Gannu_1's Avatar
Thanked: 10,519 Times
Default Re: VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread
While using VCDS last week to tweak the RCD 510 installation, I had enabled selective unlocking (under Cent. Elect. > Adaptation, drop down menu) of doors but disabled it due to the inconvenience. Enabling selective unlocking unlocks only the driver side door with the press of the keyfob’s unlock button while the remaining doors are still locked (including the boot). Since I keep the bag in the rear seat when I head to work, I found this option inconvenient thus disabled it. Some folks may find it useful.
Gannu_1 is offline   (2) Thanks Reply With Quote
Old 11th July 2015, 12:27   #197
ventoman's Avatar
Thanked: 166 Times
Hi Gannu,
Whilst going through your thread on RCD510 installation here, I realized you had to copy over few files for enabling in VCDS.
I'm getting Out of Range errors for quite a few options (changing reverse parking sound, volume to be replenished etc) and earlier ruled it out thinking my BCM could be incompatible. But now I'm tempted to attribute those errors to few missing files as well.
Could you please suggest?
ventoman is offline   Reply With Quote
Old 11th July 2015, 12:32   #198
Gannu_1's Avatar
Just one file - 3A-56.lbl so VCDS recognises the HU.
If the label files are missing from the Labels folder, you will get the out of range error. I shall upload the labels folder from my VCDS installation later today evening here. You can try adding the missing label files to your installation folder and see if it works.
Your BCM is a highline one ending in 087, the best you can get.
Old 11th July 2015, 14:21   #199
Gannu_1's Avatar
Here you go - Labels.part1.rar, Labels.part2.rar.
Merge them into a single folder Labels and add the missing ones to yours. Don't replace any file (just in case!).
Gannu_1 is offline   (3) Thanks Reply With Quote
Old 11th July 2015, 14:27   #200
ventoman's Avatar
Thanked: 166 Times
Here you go ..
Thanks a lot Gannu. You are a Star!
I'll reconcile the labels with mine and add missing ones.
Old 22nd July 2015, 06:05   #201
sunilsoft's Avatar
Thanked: 54 Times
I had also enabled the instantaneous consumption display yesterday. I checked it this morning and yes its working as well.
Its in Instruments >> Adaptation >> Instantaneous fuel consumption*
The Swift had it by default. Though not very useful its interesting to see the instant FE readout under various driving conditions.
*Or something like this, typing off my head.
I am in the process of buying a polo highline 90ps 1.5 diesel. Want to know if it is possible to enable Instantaneous fuel consumption via vcds and could you please provide a list of features that can be activated using vcds on polo. Please provide the software version no. as well and a link to buy the cable that is compatible with the polo highline.
sunilsoft is offline   Reply With Quote
Old 26th July 2015, 16:03   #202
Crazy_Bean's Avatar
Thanked: 198 Times
Hi Folks, I have been using the VCDS cable from aliexpress with 12.12 firmware for quite sometime now. It works well.
Recently encountered updated cables on Aliexpress and a Russian website with v14 and v15 respectively.
Does anyone know where I can find the updated software or will my cable not support the update?
Crazy_Bean is offline   Reply With Quote
Old 26th July 2015, 19:42   #203
sunilsoft's Avatar
Thanked: 54 Times
All the cables are clone cables. You cannot upgrade the firmware of the vcds cable. The max supported version for a clone cable is 12.12.3
Old 28th July 2015, 12:33   #204
ventoman's Avatar
Thanked: 166 Times
Here you go .
Gannu, Thanks again. I finally managed to update my VCDS labels with the missing ones from yours.
1. Volume to be replenished is now enabled.
2. Tried changing the tone of reverse parking buzzer. But no luck as VCDS is not able to deduct the controller. This was spotted by StarScream earlier as below.
Originally Posted by StarScream View Post
FYI, VW changed the reversing module to a non-Optical Parking System one, with limited functionality. The previous one (cars from last year) showed up in VCDS and interfaced with systems such as the Blaupunkt 835 to give you reverse parking sensor graphical display.
The new one is audio only, doesn't show up in VCDS and hence allows no customization. I learned this the hard way after my Blau 835 didn't give me reverse-sensor display. I think this is what is happening with your car.
3. Tried enabling static cornering lights. Got a positive confirmation that coding is accepted. But doesn't work.
Folks with the Vento TDI DSG and Rapid TDI DSG, have you tried enabling the static cornering light through the fog lights? It might just work since static cornering lights require the highline BCM (087 series) and both these cars have them. Do give it a try and report back. ..
Old 28th July 2015, 15:02   #205
devrajman's Avatar
Thanked: 116 Times
Guys, FYI, there is 14.10.2 ENGLISH working clone cable available and working!
But no v15
devrajman is offline   Reply With Quote
Old 28th July 2015, 16:13   #206
sunilsoft's Avatar
Thanked: 54 Times
But no v15
Please provide the link for purchasing the cable
Old 28th July 2015, 17:42   #207
Tanveer_2558's Avatar
Thanked: 2,448 Times
But no v15
Please provide the link and some more information if possible.
Also got the Rain closure and the honking confirmation working with ATA confirm on the MID, So i can disable or enable the honking confirmation anytime on my Jetta.
Tanveer_2558 is offline   Reply With Quote
Old 31st July 2015, 09:37   #208
ajaypjayaraj's Avatar
Thanked: 1,083 Times
Switched on laptop this morning and VCDS prompted that an update 15.7.0 is available. Updated same. So the latest version is 15.7.0.
ajaypjayaraj is offline   Reply With Quote
Old 31st July 2015, 12:16   #209
Thanked: 152 Times
Do you use original cable or is it Chinese clone? Can clones be updated?
B747 is offline   Reply With Quote
Old 31st July 2015, 12:51   #210
Prodigy07's Avatar
Thanked: 329 Times
Originally Posted by Prodigy07 View Post
Sorry for going OT
Is there something similar to a VCDS cable for Maruti vehicles?
The reason I'm asking is, I got the lane change indicator function changed from 3 blinks to 4 blinks at MSM Chennai.
Hello, Can someone please clarify?
Prodigy07 is offline   Reply With Quote
Technical and diagnostic Guide: Hyundai's HVAC systems sidindica Technical Stuff 58 19th January 2018 01:11
Vag-com (VCDS) and Passat B7 exhaustpipe Technical Stuff 9 25th June 2016 16:04
Bangalore Meet: VCDS tweaks for VW & Skoda cars psuraj The Team-BHP Meet Section 52 26th January 2015 16:41
Affordable ODB Display & Diagnostic Tools (eg. GReddy Informeter, ELM 327, etc) dot Modifications & Accessories 33 12th March 2013 22:44
Android based Engine Perfomance/Diagnostic Tool SudhanshuSD Technical Stuff 3 2nd December 2010 16:10
