Old 30th November 2015, 22:46   #301
leprechaun's Avatar
Thanked: 33 Times
Default Re: VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread
That's an interesting one. This looks like a new BCM probably manufactured here in India by Continental which has support for cruise control. Even the 087 part doesn't guarantee cruise control since the 087 F unit doesn't have support.
Could you click a snap of the BCM unit and share it in this thread (2014 VW Polo 1.5L TDI: Test-Drive Thread)? I've mentioned the location in the DIY thread.
PS: Please edit your previous post to add more details if the 30 minute EDIT window isn't over yet. Been merging several back-to-back posts of yours. Thanks!
Yes Gannu, you are spot on , they are infact manufactured in india by continental! i have added the picture in the above mentioned thread, hope its of some help .
P.S : My apologies for posting back to back, kept missing the 30 minute window.
leprechaun is offline   Reply With Quote
Old 5th December 2015, 11:51   #302
Tanveer_2558's Avatar
Thanked: 2,123 Times
Need Help with PLA 2.0 Coding for my jetta, Have installed everything according to this http://forums.vwvortex.com/showthrea...t-8-Sensor-OPS
And as expected after the install, All the lights on the instrument cluster lit up, Basically i need to code the ABS module,
I am getting the fault codes saying "RPM errors" in the ABS module, Since i have not coded it properly for it to work well with the new ABS sensors,
Anyone has any info on this would be really helpful !
Tanveer_2558 is offline   Reply With Quote
Old 5th December 2015, 13:59   #303
Chethan B G's Avatar
Thanked: 697 Times
Arrow Re: VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread
Can you post the Autoscan data, so that we will try to find out the reason?
Did you replace Gateway? If so, did you entirely re-code it or just copy/paste long-code of the previous Gateway?
Also, let us know if you have changed any any thing else apart from the rear wheel speed sensors.
Chethan B G is offline   Reply With Quote
Old 5th December 2015, 14:03   #304
Will post the autoscan in a few hours,
Yes replaced the can gateway before doing anything else, Copy pasted the code, Selected everything from the installation list, Activated fatigue via adaptions and all worked well, Got the driver alert under assitance, and No fault code during the autoscan.
Have changed the rear ABS sensors with the new one i got with the PLA 2.0 kit, and have swapped the park assist module ( Which was earlier 8K one) with the new Parklife PLA one. Have installed 2 sensors at the front and 2 rear as needed and have wired everything too. Installed the new Parking switch as well.
Will just upload the scan by 5pm or so.
Old 5th December 2015, 14:48   #305
Thanked: 697 Times
New Gateway will have additional features. Copy / pasting long code will not help, but get us in to problems. Please check this and revert.
Old 5th December 2015, 14:54   #306
According to the seller just copy pasting the new coding will work, But lets see ill check again and revert also will provide a full autoscan in a while.
Old 5th December 2015, 23:10   #307
Gave the car to AVS tuning, They will sort out all the coding problems for me, Hoping for the best, I just hope PLA 2.0 works! Will let you know the final outcome.
Tanveer_2558 is offline   (1) Thanks Reply With Quote
Old 8th December 2015, 00:11   #308
Read on one of the Russian forums that with v15.7, someone was able to get mirrors' auto folding on the Jetta and Tiguan which otherwise would require some EEPROM tinkering.
Source
Was at AVS tuning today, And tried the following with the Original ross tech cable, But unfortunately did not work with my Jetta 2014, The system accepted the new coding, Both 95 and 99, But none of them worked to autofold the mirrors,
Also its seems, TPMS for some reason isn't possible in my Jetta, I really wonder why!
Old 8th December 2015, 19:30   #309
zen
Thanked: 12 Times
Anyone has any experience dealing with the below fault code?
03444 - Ignition Starter Switch - Implausible Signal - Intermittent
Don't have any other further information on the fault as I'm not using the Ross tech software.
zen is offline   Reply With Quote
Old 14th December 2015, 00:22   #310
Thanked: 12 Times
Received VCDS 12.12 from Aliexpress today and enabled lane-change indicater from 3 to 5. Also noticed Emergency Flashing (Turn Signals) active already, but not sure whether it is working.
msiva75 is offline   Reply With Quote
Old 14th December 2015, 10:42   #311
dkaile's Avatar
Thanked: 4,096 Times
Planning to get a VCDS cable for my Skoda Superb 3T (2012) 1.8 TSI 6MT. So what's the best current source and model to get it at the best price?
dkaile is online now   Reply With Quote
Old 14th December 2015, 11:00   #312
graaja's Avatar
Thanked: 2,854 Times
Thumbs up Re: VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread
A few weeks back I got version 15.7 which is the latest. It works great, and compared to the earlier version 12.0 I had, this version has opened up many more modules in my Jetta. I got it for $27 (it now sells for $25).
Regarding reliable source: At the time I placed the order, there was only one seller with 15.7 and only 9 orders had been placed. I took a risk and placed the order. Now I don't see that seller on AliExpress (When I click the link from my order history I get a "404 Page Not Found" error)!! But there are many new listings for 15.7 with no orders yet. Another surprise is that even 12.12 which is the mostly used one has all fresh listings with 0 orders. I would say take the risk and go for the 15.7.
graaja is offline   (1) Thanks Reply With Quote
Old 14th December 2015, 11:06   #313
dkaile's Avatar
This one looks interesting - http://www.aliexpress.com/item/VAG-C...rchweb201560_1
The seller also promptly replied to my message within 5 minutes that it was compatible with my model and has software included.
Should I bite the bullet? lolz
dkaile is online now   (1) Thanks Reply With Quote
Old 14th December 2015, 11:09   #314
graaja's Avatar
I would say "bite the bullet"
The one I bought had the same photos, screen shots etc. and works well.
Old 14th December 2015, 11:28   #315
dkaile's Avatar
Thanks. Just bought it.
Technical and diagnostic Guide: Hyundai's HVAC systems sidindica Technical Stuff 58 19th January 2018 01:11
Vag-com (VCDS) and Passat B7 exhaustpipe Technical Stuff 9 25th June 2016 16:04
Bangalore Meet: VCDS tweaks for VW & Skoda cars psuraj The Team-BHP Meet Section 52 26th January 2015 16:41
Affordable ODB Display & Diagnostic Tools (eg. GReddy Informeter, ELM 327, etc) dot Modifications & Accessories 33 12th March 2013 22:44
Android based Engine Perfomance/Diagnostic Tool SudhanshuSD Technical Stuff 3 2nd December 2010 16:10
