View Poll Results: How important is it for u to know the behaviour of ur car ??
It plays a vital role .. 40 86.96%
At the spur of the moment reflexes tend to do just the same unknowingly.. 7 15.22%
What behaviour ?? How does it help ?? U must be joking .. 3 6.52%
Multiple Choice Poll. Voters: 46. You may not vote on this poll
Thread Tools
Old 19th July 2006, 21:10   #1 (permalink)
mclaren1885's Avatar
Default How important is to understand the behaviour of ur car?
Often i have come across instances where people keep driving at break neck speeds without having much knowledge about how their cars would respond to certain situations ..
For eg :
1. Lack of back end grip due to weight transfer under heavy braking ..
2. The importance of downshifting instead of sitting on the breaks ..
3. The way ur car handles around corners and bends at high speeds ..
4. Also there always seems to be a misunderstanding that RACING Lines are DANGEROUS .. What are racing lines ??
Arent they the safest yet the quickest way to get around a corner ?? How ??
Well if u go from outside to outside u loose speed , time et all and also could end up loosing the grip and oversteer badly (mostly incase of FWDs).. I have tried this on track to see the difference and the effects of running wide could be ghastly .. Specially to those who at times max out their speedos on winding public roads without taking the proper lines (read on roads with dividers in btwn such that ther is no oncoming traffic barring there are no vehicles around as well).. This could lead to eminent dangers of hitting the dividers and sommersolting on running wide ..
Also often i have seen many people doing a 3 digit speed , break hard on seeing a curve all the way until they get out .. Doesnt this lead to oversteer ?? And dangerous ??
5. Use of opposite lock in certain drastic conditions and how it works ..
6. Use of handbreaks in emergencies to avoid head on collisions .. Its better to go sideways into a barrier than head on .. If done right atleast saves u the engine ..
7. Importance of not turning ur steering wheel when the wheels are locked due to heavy braking .. This sudden change in steering inputs could make u loose control of the car completely ..
8. Importance of not spinning ur wheels to get good times either at drag launches or on tracks ..
How important is it for u to know how ur car handles ?? What factor could it play in ensuring u better control over ur car ??
PS : I have learnt quite a lot of these technicalities by going to track days and can see that they play a major role in driving either on city or highways too .. How much do u think it helps ??
__________________
ICNSAFYNCILWU. WMUL. AWLUFAEAE.
Old 19th July 2006, 21:19   #2 (permalink)
drifter's Avatar
I agree with almost everything here...
apart from going sideways into an accident...head on would always be safer than a side impact. Side impact may be prefrable if the speeds are low and provided if you hit on the side you arent sitting at. The car is not as strong on the sides as much as it is in the front or back. There simply isnt enough crush zone so to say, to absorb the impact.
And another thing...trying to take racing lines anywhere on public highways is like looking for trouble. You can never be too careful on our roads.
And also it pays to know the limits of your car. Can be a lifesaver.
So in other words, track days will teach you the limits of your car in a relatively safer environment.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline   Reply With Quote
Old 19th July 2006, 21:24   #3 (permalink)
theEnd's Avatar
Very good tips. I'd just disagree with one point.
Cars tend to have a lot more protection in front (crumple zones, airbags) than on the side where there's usually just a steel bar inside a 6 inch thick door. Think I'd rather save my head than the engine.
I also remember seeing this bit on Top Gear (BBC) where they said that racing lines weren't optimal on the road because of visibility issues. It makes sense because if you're on a two way road and come screaming past the apex your exit would take you all the way to the other side of the road in no time at all, and into the path of an oncoming car.
theEnd is offline   Reply With Quote
Old 19th July 2006, 21:26   #4 (permalink)
theEnd's Avatar
you beat me to it Drifter... good points!
what's the scope for track days here in India?
Old 19th July 2006, 21:26   #5 (permalink)
apart from going sideways into an accident...head on would always be safer than a side impact (provided if you hit on the side you arent sitting at).
And another thing...trying to take racing lines anywhere on public highways i think is like looking for trouble. You can never be too careful on our roads.
Drifter
Agree completely , if u can manage to go sideways such that the impact is nowhere near ur sitting side it should be safe .. Most often than not see if u can get ur dicky to bear the impact .. Even repairs are cheaper .. Albeit this is done at low speeds of not more than 60 in unavoidable circumstances ..
Also agreed that racing lines arent to be tried with traffic around or on public roads , best bet isto break before the curve if its sharp in a straight line , downshift if necessary and accelerate into the corner than brake the whole way which is dangerous .. Also i have seen guys go from outside to outside on a curve and get that inch closer to hitting the divider .. By racing line i meant having the conscious to hit the centre or left corner of the road instead of brazing close to the side of the divider throughout the curve .. Hope thats clears it out .. I repeat i didnt mean exact RACING LINES , but didnt quite know how to express the idea of not taking the entire curve from the outside lane .. Could anyone put it across in a more simpler way ??
__________________
Old 19th July 2006, 21:29   #6 (permalink)
drifter's Avatar
I understand what you meant when you talked about racing lines...
Yup its a good practice to finish all your braking before arriving at the corner.
EDIT: @theEnd: As of now, its only the boys down south who are able to enjoy track days due to the lack of facilities elsewhere in India.
EDIT2: @mclaren: I guess you mean to say that its better to stay on the inside of the curve and try not to understeer into a divider.
Drifter
__________________
Old 19th July 2006, 22:18   #7 (permalink)
Well atleast for most of us who have done track days , its worth every penny and we wouldnt mind going back to it again and again .. Actually all of us are awaiting for the next one eagerly .. Wish our friends from bombay and pune could make it to .. Im sure revvhead will agree with the fun factor .. Khaadu the drift king ought to make it once too ..
Well , personally these track days have benefitted me a lot .. Once it thus happened that my entire family was out on a drive to tirupathi .. As we passed the toll gate dad proceeded further to overtake a zen which was on the centre lane .. We were on the right lane .. Doing speeds of about 120 with no other vehicle in sight for the next 1km atleast .. As he was about to overtake the zen guy cut us off (for no reasom) and came that close to hitting the car .. In trying to avoid the hitting dad braked hard and in trying to see how close the zen got to the baleno , in shock let go of the steering .. Car started to fish tail wildly as his hands were off the steering and he was braking inches from the divider .. Could have turned out to be very fatal ... Without much thinking i immediately grabbed hold of the steering from the passengers seat , kept moving it trying to get the car in a straight line while frantically shouting at dad to " POWER UP dad POWER UP , DONT BRAKE" .. Luckily he heard it and soon the car came back under control .. He then came to a halt and let me drive .. It all happened in a split second.. Since then he never hesitates to let me drive on the highways .. And mom prefers me driving all the time , though im sure nitrous and islero wouldnt want ..
I would attribute this solely to v1p3r and psycho who right from day one made it a point to make me understand the behviour of FWD's and for track day to give me oppurtunity to figure out how the theory worked in real life and also help me find the limits of my car ... Kudos to all of them ..
__________________
Old 19th July 2006, 23:22   #8 (permalink)
Shan2nu's Avatar
On public roads, they most definately are dangerous.
I'd say, i've learnt more about racing and car behavior through games like NFS5 and GT4.
Prior to my first track day, i had no track experience, what so ever. But, it didn't seem to affect me as much as it did to a few others.
I don't remember a single instance where i might have taken the car off track or caused it to lose control and it's not like i wasn't pushing it. Had it not been for NFS5, i'd probably have flown off on the very first corner. Trust me, never take racing games casually coz theres always something you could learn from them.
It's impossible to know for sure, how your car would behave under certain conditions bcoz vehicle behavior is never consistant. Factors like road surface, tyre wear, brake bite/fade, load etc could change everything.
It's vital to know your cars behavior but, it's even more important that you learn to improvise on your inputs, when needed.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 19th July 2006, 23:28   #9 (permalink)
.anshuman's Avatar
I voted for "it plays a vital role" because i think knowing your car is very important if you like to push your cars to their limits as sometimes we expect them to deliver too much far beyond their limits.
another things that are as important-
1.knowing your own limits
2.knowing the road,some cars give enough feedback but others are incapable of delivering the same.
__________________
Anshuman Bishnoi
Hyundai Elantra CRDi 2.0 DIESEL
Mahindra Scorpio VLX 2.2 DIESEL
Suzuki Swift VDi ABS 1.3 DIESEL
Old 19th July 2006, 23:38   #10 (permalink)
Shan2nu
Well said .. But to know the difference in factors like road surface , tyre wear etc make u still need to know the basics dont u ??
Like u said its vital to adjust according to the circumstances ... That is a sign of a good driver ..
__________________
Old 19th July 2006, 23:41   #11 (permalink)
F50
Team-BHP Moderator
F50's Avatar
It is very important to know the limits but advisable to be below your limits on public roads. Limits are explored on tracks and public roads are not tracks.
Because on public roads not only us but even others are in danger.
__________________
F50
When in doubt, throttle out.
F50 is online now   Reply With Quote
Old 19th July 2006, 23:53   #12 (permalink)
Let me give it another shot ..
Exactly .. Maybe that should clear all ur doubts ..
Also i mean finding the limits of ur cars on track not on public roads (which is why we make it a point to go to every track day and also kart during the weekends) .. But wanted to know if all this does indeed help u be a better street driver ..
And people still dont believe when i tell them i get 16+ km/ltr in my modded baleno in city.. How easy its to stereotype .. U do track days , drive a modded car , talk about this so ur rash ..
__________________
Old 19th July 2006, 23:57   #13 (permalink)
Shan2nu's Avatar
Yes it is important to know the basic behavior of your car but, thats only for reference.
There's a reason why racing cars can't maintain the same lap times throughout the entire duration of a race. It's just not possible.
Everytime an F1 car comes into the pits, the driver has to reset whatever he had been doing for the previous few laps, bcoz the car would now be heavier, the traction levels would have changed, the brakes would have cooled off a bit... the list goes on.
Shan2nu
__________________
Old 20th July 2006, 00:07   #14 (permalink)
Sam Kapasi's Avatar
Whooops!! Didn't realise I'd be the only one who would vote for "what behaviour of the car are you talking about?"
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Old 20th July 2006, 00:16   #15 (permalink)
shrivz's Avatar
I personally think its all easy to say this, but when ur in this kind of situation, you cant think so fast.. and nobody would think of saving their engine and going sideways when they're gonna experience a headon collission in 1/2 a sec...
This is just my personal opinion, since i've been in a similar situation, and have got saved by the skin of my teeth!!!
But I do agree that knowing the behaviour and limits of your car is as important as knowing how to release the clutch...
__________________
every speaker has its own flavour! as you let your tongue do the tasting, let your ears do the listening!
shrivz is offline   Reply With Quote
Thread Tools
Indus motors chennai - Unethical behaviour rrnsss Indian Car Dealerships 18 9th January 2008 08:44
How to understand customs statement kvish Shifting gears 0 26th October 2007 12:26
Petrol stations and their behaviour venkatrx The Indian Car Scene!! 44 17th June 2007 06:46
Special behaviour/characteristics & what you can expect from different speaker brands hydrashok Ask the Gurus 12 27th September 2006 10:29
Help me understand this. X-Machine Shifting gears 12 1st October 2004 21:44
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
