Old 18th July 2014, 15:19   #46
DerAlte's Avatar
Thanked: 2,879 Times
Default Re: The End of Left-Foot Braking? BTO - Brake Throttle Override
... How does a stepper know its position / prevent any kind of drift? Being an open-loop system I'd imagine this could be more dangerous? ...
Zoom out a bit, and you should realize that the actuator that controls the throttle flap gate is not an independent control system by itself, to warrant the term "open-loop" or "closed-loop". The actuator, and it's coaxial position sensor, form a part of the throttle control regulation loop (closed loop control). The actuator doesn't drift by itself, or even if it does the incremental error is miniscule. Air flowing past the gate exerts enough force to possibly cause an error, which the control loop normally corrects.
The most likely danger involved is gate shaft jamming due to contaminants and dust / dirt. That jamming is fine if it is at a position less than desirable (will show up as power loss), but if stuck more than desirable it can cause a runaway in some conditions.
DerAlte is offline   (1) Thanks Reply With Quote
Old 18th July 2014, 16:02   #47
DRC
DRC's Avatar
Thanked: 48 Times
Just my 2 cents to the pond...
Drive by wire is an intelligent closed loop system to relate gas pedal position to speed.
Either Servo or Stepper motor is a part of the above sub system. Both of them can be used to set desired throttle position valve by ECU
Among them, stepper motor is a open loop system and servo is a closed loop system uses a simple DC motor.
DRC is offline   Reply With Quote
Old 18th July 2014, 17:13   #48
Thanked: 168 Times
Whether a system is closed or open loop is not decided by the type of control mechanism. It depends on whether the system has a feedback signal in this case a throttle position sensor.
Whiplash7 is offline   Reply With Quote
Old 18th September 2015, 13:29   #49
Thanked: 121 Times
In other words, expect cars to become more safe on the roads, and less fun on the racetrack.
10 major automakers (namely BMW, General Motors, Mercedes-Benz, Toyota, Volvo, Tesla, Volkswagen, Mazda, Ford, and Audi) , collectively accounting for 57 percent vehicle sales in 2014 in the U.S. have committed to making automatic emergency braking standard on all their new vehicles in the U.S. !
Link: http://www.dispatchtimes.com/automak...ehicles/93146/
HolyDriver is offline   (1) Thanks Reply With Quote
Old 18th September 2015, 15:56   #50
blackwasp's Avatar
Thanked: 7,253 Times
This is sad news in general. I don't mind this system in automatics ( those without clutches), but in cars that have a clutch - manual or automatic , can simply disengage the clutch.
Also left foot braking is useful to keep the engine in turbo range when you have to take a take a turn or slow down.
blackwasp is offline   (1) Thanks Reply With Quote
Issue: Driver's foot (Accelerator foot) over a long drive joybhowmik Street Experiences 59 27th January 2018 23:44
Zen Pulls to Left And Under Braking Too Trust_In_Thrust Technical Stuff 5 7th June 2011 21:46
Braking - Left or Right Foot? aerohit The Indian Car Scene 46 12th May 2011 17:39
Left Foot Braking: Yes/No..? MaserQ Street Experiences 2 19th March 2007 05:16
