Old 26th August 2009, 09:51   #16
gpa
gpa's Avatar
Thanked: 282 Times
Originally Posted by abhibh View Post
I have the same problem in my Alto. In city drives or idling the AC wont shut off even for 2 hours, but on highways after every hour i had to turn off the blower for 10 mins and start it again.
Looks like the thermostat is faulty. Also try and not turn the knob to the coldest position but leave it one step above to prevent this frosting and the rise in temperature after a while of running the a/c.
Old 26th August 2009, 10:58   #17
Thanked: 17 Times
Hi
It is the thermostat problem which is at fault, due to which there is ICE formation. I had the same problem in my zen. My AC mech is comming this sunday to change the thermostat.
will keep you posted on the development.
Uday
udaydesai is online now   Reply With Quote
Old 26th August 2009, 13:59   #18
Jaggu's Avatar
Thanked: 8,693 Times
First check the gas level, if over filled the system will freeze up on extended run. This is what you can do for simple check: switch off the compressor for few minutes and see if the cooling returns, do this after the ac stopped working on its own.
Old 26th August 2009, 20:26   #19
deky's Avatar
Thanked: 1,051 Times
Originally Posted by jav View Post
This is mostly caused by a faulty thermostat which does not cut off when the temperature drops or can be blockage of the coils as mentioned in the above posts, Get it checked by a good A/C mechanic or service center.
Thank you, will do. The cars due for 20K service in a few days.
Originally Posted by SirAlec View Post
change the settings on the expansion valve. if found faulty replace.
What does an expansion valve do? can I change the setting myself or take it to the mechanic?
Thank You, but dont you think there should'nt be a problem at the knob being at the coolest? I mean if there is a coolest, the system should be designed in such a way that it should be able to stand those temperatures!!!
Originally Posted by udaydesai View Post
Hi
Uday
If my problem is rectified earlier will post it here too, thanks.
Its a gradual decrease in temperature. And yes after stoping the AC for a while, the colling gets back to normal.
deky is offline   Reply With Quote
Old 26th August 2009, 21:21   #20
Jaggu's Avatar
Ask a competent mech to check for all usual culprits for refrigerant freeze up.
Old 26th August 2009, 21:47   #21
SS-Traveller's Avatar
Thanked: 11,631 Times
IMO this issue faced by so many here is probably being caused by the high humidity in the atmosphere. With a partially clogged and dirty cooling coil (something like this),
http://www.team-bhp.com/forum/attach...2-abcd0015.jpg
the moisture tends to condense on it and freeze; this causes the thermostat to cut the compressor out, while the ice formation leads to a reduced airflow.
A simple AC service costing around 1.5 - 2k (including cost of gas) should solve this problem.
Old 26th August 2009, 22:45   #22
abhibh's Avatar
Thanked: 34 Times
Ok a bit of history of my car:
- Its 9 years old
- AC has been serviced maybe max 2 - 3 times (not sure) in 9 years
- AC gas never leaked and i have never got it refilled.
One thing i am still unable to understand is that if AC / engine or anything is getting overheated then why does the air from blower is less ? No matter AC on or OFF the blower should blow air at same speed.
Old 27th August 2009, 09:22   #23
- Its 9 years old
AC service once after every 3 summers is generally required - earlier if you tend to drive in fresh air mode.
When there's icing up of the cooling coil, the air flow through the coil becomes blocked - therefore blower output into the cabin reduces.
Old 27th August 2009, 09:41   #24
jav
- Its 9 years old
Does your a/c cut off when it gets cold or does the compressor keep running even when the air flow reduces, if yes then usually its the thermostat which is faulty.
jav is offline   Reply With Quote
Old 1st September 2009, 13:39   #25
deky's Avatar
I gave my Car for 20k service today and reported the same problem. The mechanic agreed its either the expansion valve or the thermostat which is faulty. And assured he will have a look and would not happen again.
I will let you know the outcome later.
Old 6th September 2009, 17:25   #26
Aashutosh's Avatar
friends,
my query is slightly off topic, but require your help. I own a 2001 santro, whenever I switch on the AC, the engine RPM shoots up. Is this normal?
Plus there is some noise when I switch on AC. As per mechanic, its clutch bearing of AC that is causing the noice.
Otherwise AC is perfect.
Can you please guide/help, how I sort this out.
Aashutosh is offline   Reply With Quote
Old 6th September 2009, 19:22   #27
gpa
gpa's Avatar
Thanked: 282 Times
Aashutosh,
The increase in the RPM of the engine is normal. However, if you hear noises that indicate the compressor bearings are on their way out (which might be the case as your car is 8+ years old) then you can either have the compressor serviced or replaced.
gpa
Long drives on my swift..left knee pain rajshenoy Technical Stuff 32 31st October 2012 22:33
How do front wheel drives and Rear wheel drives behave in a skid adrian Technical Stuff 10 29th June 2011 17:51
Esteem VXi '05 - My New Ride!! Update @ 80K Kms with a long drives & track day pics Venom_rider Long-Term Ownership Reviews 37 25th February 2011 03:47
Zen - Engine Switching off on long drives Tiger Technical Stuff 10 11th January 2008 10:28
Car or Motorcycle - for long, cross country drives ? GS300 Street Experiences 20 21st May 2006 21:37
